Hi guys,
Just a question you might help me with.
I am trying to get the readouts of the nodoshop opentherm gateway (using the fixed LAN interface).
But i am struggling to get the readouts. I do see a nice valuestring in the log, but in the devives i only see 4 devives an named GIOAPulkledToGround/GIOBPulkledToGround/GIOAStatusIsHigh/GIOBStatusIsHigh. Why are all the other devices not inserted?
To my knowledge:
- I allow devices in the domoticz setting.
- there is communication as i do see the log values
I installed Domoticz on a Synology DS212...
Anby idea?
Thanx in advance!
Vreak77
USR-TCP232-T2 values in log but no devices
Vreak77
- Domoticz version: 3.8153
- Log with values.png (95.65 KiB) Viewed 6014 times
- Hardware.png (133.72 KiB) Viewed 6014 times
- Devices.png (49.36 KiB) Viewed 6014 times
- Domoticz version: 2026.3
Re: USR-TCP232-T2 values in log but no devices
No idea what is happening here but there was at least 1 person with the same issue: viewtopic.php?t=28097
Vreak77
I will ask him if he found a solution.. But his log shows erros. I do see values...
Thanks for the tip!
If he has found something which will help me I
will report it here...
Thanks for the tip!
Vreak77
Mayby also to consider an upgrade... seems my domoticz version is kinda old...
But also the DS212 cannot be upgraded to DSM7.x and will not get any security updates after Q2 2023...
Perhaps you can use docker on your synology. Then you can use latest stable 2022.2
https://www.domoticz.com/wiki/Synology
Vreak77
I will have a look. But i understood/read somewhere that when using Docker some additional internal memory is required... and DS212 is not expandable.
Also like to keep a little-bit in the default installions because my knowledge is not on a experience level....(yet..
Maby to try to find a latest jadahl version...
