no ip adress install on pi Topic is solved
badair
when i install domoticz , i don't get an ip adress. any idea?
The Pi has an working static ip address.
Is there an config file i can change?
- Schermafbeelding 2022-12-26 om 13.51.08.png (389.59 KiB) Viewed 1561 times
willemd
- Domoticz version: 2024.1
Re: no ip adress install on pi
When you log in into the Pi and type "ifconfig" at the command line, you will see the IP address of your Pi at the second line after wlan0, starting with inet (if it is connected via wifi).
Just put the IP address in front of the port number 8080, separated by a colon ":' and that will be the complete address for domoticz.
badair
The Pi has an working ip address, static ip address, this address doesn't work.willemd wrote: Monday 26 December 2022 17:37 When you log in into the Pi and type "ifconfig" at the command line, you will see the IP address of your Pi at the second line after wlan0, starting with inet (if it is connected via wifi).
sailmich
@badair
According to your screenshot of your domoticz installation is domoticz installed! What is the message when you write http://yourstaticipadress:8080 into Firefox or chrome or edge ......?
badair
1x2 1x8 XX XX refused to connect.sailmich wrote: Tuesday 27 December 2022 11:23 @badair
127 0 0 1 refused to connect.
- FireWizard
Follow the procedure described at: https://www.domoticz.com/wiki/Lost_Username_Password.
Let us know.
Let us know.
badair
FireWizard wrote: Tuesday 27 December 2022 14:21 Hi,
Let us know.
- Schermafbeelding 2022-12-28 om 10.52.23.png (364.16 KiB) Viewed 1468 times
- Sjonnie2017
- Domoticz version: Latest ß
Almost looks like you built from source. Did you?
It seems your pi is missing some packages. glibc springs to mind. What if you install the required packages?
YouLess Energy meter
- Domoticz version: 2025.1
Is it on a fresh RPi OS? If yes, what OS is it? Seems like you are using a very old or a very new OS.
willemd
The instructions are with 3 times w, you typed 2x w.
-nowwpwd instead of -nowwwpwd
badair
I used the easy instal from domoticz.comSjonnie2017 wrote: Wednesday 28 December 2022 11:10 Almost looks like you built from source. Did you?
badair
same resultwillemd wrote: Wednesday 28 December 2022 11:28 The instructions are with 3 times w, you typed 2x w.
badair
linux 4.19.66waltervl wrote: Wednesday 28 December 2022 11:14 Is it on a fresh RPi OS? If yes, what OS is it? Seems like you are using a very old or a very new OS.
- Sjonnie2017
Your kernel (mid 2019) corresponds to "Stretch" which is pretty outdated. Should you wish to update you could try:
sudo apt update
sudo apt full-upgrade
sudo rebootConBee II - TRÅDFRI lights + switches, loads of ChingLing dimmers and switches, Heiman and Xiaomi sensors
- FireWizard
Kernel 4.19.66 dates back to August 2019.
So this is more than 3years old!!!
What distribution is this? And on what device are you running this kernel?
- Sjonnie2017
Pi 3B (+?)FireWizard wrote: Wednesday 28 December 2022 14:38 Hi,
Raspbian Stretch
badair
solved it , new os.
thanks to all
thanks to all
