Zigbee in Domoticz (win10) Topic is solved
Re: Zigbee in Domoticz (win10)
It is just the coordinator version which looks strange
This looks an old firmware. You might want to look after @koenkk Z-Stack-firmware git repo to get the latest master version.
Otherwise I think you are good
Wiki is available here.
Zigbee for Domoticz FAQ
My MOES dimmer module has finally arrived. I upgraded the firmware to the latest (20220219) using this guide: https://zigbee.blakadder.com/Sonoff_ZBDongle-P.html
However, the MOES Dimmer is initialized as a TS0601 valve thermostat!? Any ideas on what to do?
Yes please le us know what version of the plugin you are running, provides the export.json file from Plugin device RAW in Webui > tools
Version is 6.3.006 (but the web ui is indicating that it's not up to date since the version number is in red text but I can't update further).
- export (1).zip
- (1.56 KiB) Downloaded 22 times
Is that that one https://zigbee.blakadder.com/Moes_MS-105B.html ?
can you switch to dev branch
git pull
git checkout dev
git pull
then you'll have to restart the plugin and remove the device/widgets and redo the pairing
git pull
git checkout dev
git pull
Thanks for all your fast help
Yes, it's that Dimmer module.
Ok, version 6.4.045 and after following the guide on how to completeley remove a device it's now working. I'm particularily pleased with the sycnhing between the module and DOmoticz. If I change the dimmer level on the wall switch or switch it of it's immidietly reported in Domoticz - fantastic
One thing though. Zigbee for domoticz have only created one widget for Domoticz but since this is a 2 gang Dimmer shouldn't it create two? I actually don't have anything connected to the second gang, could that be the issue?
How or when should I switch back to the more stable versions of the plugin?
I was not aware there is a 2 gangs one. I need to do some investigation then , and unfortunately you might have to redo the pairing when I would have fixe it.
to return back to stable, you will just have to do
Most-likely it will continue to work, as the issue was on the creation, but for the 2nd gang, when fixed you will have to remain on dev until it is merged on stable6
Can you drop me once more the export.json as you previously did ?
git checkout stable6
Can you try teh following
Still on dev branch just update it with a git pull
then restart the plugin, remove the widgets/devices which have been created in Domotic. Check that it is correctly removed via the WebUI
then redo the pairing
No problem to have to go back and forth, I'm in a testing phase now and will install these in our new house in about 3-4 months
Ok so I ran a "git pull" again and followed your instructions twice just to be sure but it still seems to make only one widget.
Just to be clear about this dimmer modules specifications. There's a 1 gang version and a 2 gang version. The 2 gang version ends with "B" in the model name. (https://moeshouse.com/collections/dimme ... 0565807185)
- export (3).zip
- (1.49 KiB) Downloaded 18 times
just made a mistake. Give me 5 mins to fix it
if you can try once more
git pull
restart
then remove the widget and make sure this is removed from the plugin side
the you can start the pairing
git pull
restart
It now creates two widgets for the two two dimmers, great! I noticed, however, that I can't control the dimmer. It synchs with the module and shows me the present state in Domoticz but I can't control it from Domoticz. Nothings happens...
I tried removing the devices and then adding them again but now I get this error message:
2022-12-19 19:26:11.123 Error: Zigbee: Something wrong on Device 377d dc8e95fffe5f105a pairing process. (aborting)
2022-12-19 19:26:11.134 Error: Zigbee: DeviceExist - Found inconsistency ! Not Device e951 not found, while looking for dc8e95fffe5f105a (377d)
The device never registers under "Device management". This is the error code I get in domoticz while trying to pair the device once again. I have nothing in Domoticz that corresponds to this device and I can't find anything related to it in Zigbee web GUI either.
I did remove A LOT of unused devices from the Domoticz database yesterday since the device page was very sluggish. I have no other problems after I did this and I did not remove any devices related to Zigbee.
You might check if dc8e95fffe5f105a, you most-likely have some remainins stuff somewhere
exists in Domotics
exists in Plugin
If I summarize the
sync module -> plugin -> domoticz works for boths
commands from domoticz -> plugin -> module works only for the 1st one
I guess it is more on the plugin side, I'll check
exists in Domotics
exists in Plugin
If I summarize the
Yep, found it something is missing, but I need some help/inputs from you
1) can you enable debugTuya with the WebUI > Tools > Debug
2) then do on the module side only
Switch On Gang1
dimmer action on Gang 1
Switch Off Gang1
Swich On Gang 2
One dimmer action on Gang 2
switch Off Gang2
3) drop me the Logs/PluginZigbee_xx.log file
Switch On Gang1
Switch Off Gang1
Swich On Gang 2
switch Off Gang2
I have looked everywhere in the web interface for both Domoticz and Zigbee4Domoticz. No devices whatsoever in Zigbee and only the "status" and "notification" widgets in Domoticz.
I have only tried 1 of the "gangs" since I don't have anything to connect ot the second one at the moment. So I can only confirm the following for gang 1.
sync module -> plugin -> domoticz works for gang 1
commands from domoticz -> plugin -> module does not work for gang 1
I will try but I have to find a way to add the device in Zigbee4Domoticz firstpipiche wrote: ↑Monday 19 December 2022 19:49 Yep, found it something is missing, but I need some help/inputs from you
Switch On Gang1
Switch Off Gang1
Swich On Gang 2
switch Off Gang2
could you update to the latest version of the plugin with a git pull, this should be better
did you try to restart the plugin ?
Yes, that new version got it working again.
One thing I noticed from the domoticz side.
*When switching on gang 1 in Domoticz > gang 1 shows as "switched on" in Domoticz.
*When switching on gang 2 in Domoticz > gang 1 AND 2 shows as "switched on" in Domoticz.
Log file attached, I hope I got this right now. If you see any inconsistencies it may be due to the fact that I don't use a "reset" switch to control the dimmer right now. I use normal "rocker" switch and switch it back and forth to mimic a reset switch.
- Logs.zip
- (33.93 KiB) Downloaded 16 times
I think I'm progressing on the discovery of the behaviour of that 2Gang dimmer.
Could you kindly do a git pull to update
At that stage you don't have to redo the pairing, just see if from Domoticz , you can command the dimmer.
Yes, works like a charm and the 2nd gang doesn't seem tied to the 1st gang anymore because nothing happens when I try to control that one.
I'm sorry but at this stage I have no way of testing the 2nd gang but I will get back to you with that one sooner or later
Thanks once again for all your help!
