I try too make use of the system event resetAllEvents.
But it looks like the event is not triggered.
Am i doing something wrong?
I used the attached script to test.
Gr. Bert
resetAllEvents not triggered
Bertvdw
- systemEvent.txt
- (1022 Bytes) Downloaded 184 times
- Domoticz version: 2026.3
Re: resetAllEvents not triggered
So if you save a dzvents script this script is not triggered?
What if you go less complex and just log if the script is run?
willemd
Is it not triggered or is it triggered but does not produce any output?
I have never created new local functions in DZvents, but looking at your text I wonder whether the line "local Main" is needed and does not create trouble, since on the next line you start the actual function definition "local function Main ( ipDev )". I don't recognise this construct when comparing to other languages. You need to declare it first? Is it in the documentation somewhere?
I would first add extra log statements to the script before and after running Main.
Bertvdw
Sorry for my late reaction, i've been away for some time .
@Waltervl:
indeed the script is not triggered when i save athe scripts.
I use the same construction also to test if the script is triggered by a device or a variable.
also the system events for start and backup are logged if i declare them.
However, when i remove all the extra parts, an just log the system event, i doesn't show up for the 'resetAllEvents' trigger and it does show up for the 'start' trigger.
@willemd
The script is not triggered by this event.
If i put some other events to it ( for example device or timer events) then the script is triggerd and produces the expected output.
Greetz Bert
@Waltervl:
@willemd
Greetz Bert
