resetAllEvents not triggered
Bertvdw
Post by Bertvdw »
I try too make use of the system event resetAllEvents.
But it looks like the event is not triggered.
Am i doing something wrong?
I used the attached script to test.
Gr. Bert
systemEvent.txt
(1022 Bytes) Downloaded 182 times
Domoticz version: 2026.3
Re: resetAllEvents not triggered
So if you save a dzvents script this script is not triggered?
What if you go less complex and just log if the script is run?
willemd
Post by willemd »
Is it not triggered or is it triggered but does not produce any output?
I have never created new local functions in DZvents, but looking at your text I wonder whether the line "local Main" is needed and does not create trouble, since on the next line you start the actual function definition "local function Main ( ipDev )". I don't recognise this construct when comparing to other languages. You need to declare it first? Is it in the documentation somewhere?
I would first add extra log statements to the script before and after running Main.
Bertvdw
Post by Bertvdw »
Sorry for my late reaction, i've been away for some time .
@Waltervl:
indeed the script is not triggered when i save athe scripts.
I use the same construction also to test if the script is triggered by a device or a variable.
also the system events for start and backup are logged if i declare them.
However, when i remove all the extra parts, an just log the system event, i doesn't show up for the 'resetAllEvents' trigger and it does show up for the 'start' trigger.
@willemd
The script is not triggered by this event.
If i put some other events to it ( for example device or timer events) then the script is triggerd and produces the expected output.
Greetz Bert
