Errors when try to Add Devices by using MQTT Auto Discovery
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
mastadook
Domoticz version: 2022.1
Post by mastadook »
Hi All,
I try to use the mqtt auto discovery Plugin also, but there I got very much Error Messages.
Anyone with Idea here?
Errormessages like this:
022-11-21 20:17:55.793 Error: Shellie3EMHauptstrom: (ShellyCloudPlugin) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/ShellyCloudPlugin/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2022-11-21 20:17:55.793 Error: Shellie3EMHauptstrom: Module Import failed, exception: 'ModuleNotFoundError'
2022-11-21 20:17:55.793 Error: Shellie3EMHauptstrom: Module Import failed: ' Name: requests'
2022-11-21 20:17:55.793 Error: Shellie3EMHauptstrom: Error Line details not available.
2022-11-21 20:17:55.793 Error: Shellie3EMHauptstrom: Exception traceback:
2022-11-21 20:17:55.793 Error: Shellie3EMHauptstrom: ----> Line 50 in '/home/pi/domoticz/plugins/ShellyCloudPlugin/plugin.py', function <module>
and this:
________________________________________________________________________
global chief of permanent lightning and strike detonator
Domoticz version: 2025.1
Re: Errors when try to Add Devices by using MQTT Auto Discovery
Shelly does not support the mqtt Autodiscover protocol so you can forget this.
For the plugin it is missing the python module requests. You need to install this. if you already did it, install it again but then with sudo.
mastadook
Post by mastadook »
Hi Walter,
thank you for your hint. :)
So for clarification:
mqtt Autodiscover will never work with shellies?!
this means the ShellyCloudPlugin? True?
And with this one, it will work with the shellies?
Do they need the shellie cloud for working or does it work locally?
Have you maybe some Link where I can find more?
I am asking, cause on the github Page I see no help how to install it...
https://github.com/mario-peters/ShellyCloudPlugin
Or maybe you have an Idea here:
viewtopic.php?p=294814#p294814
This will do all what i need :)
mastadook wrote: Tuesday 22 November 2022 14:40 Hi Walter,
Probably not, unless shelly decides to implement it.....
My answer was based on the error message in your first message "module import failed: Name: requests"
I dont have shellies so I dont know what to advise.
For the shellycloudplugin look here: viewtopic.php?p=291089#p291089 as the github page has indeed little information.
