Total Electricity usage
JosFr
Post by JosFr »
After adding the P1 Smart Meter USB the following devices are shown in the devices overview:
2022-11-21 11_39_02.png (75.96 KiB) Viewed 582 times
This overview shows the usage data is only available per phase while the wiki page https://www.domoticz.com/wiki/Dutch_DSM ... th_P1_port suggests there should also be a "Total Electricity Usage" sensor. How to get the usage for the three phases combined?
Domoticz version: 2026.3
Re: Total Electricity usage
That is the top one, named Power.
You have to activate it (click on the green arow).
JosFr
Post by JosFr »
I presume then "Power" is what in the "Dutch Smart Meter Requirements" is called "Actual electricity power delivered"?
Is there also a value available for the "Actual electricity power received"?
A cross-reference between the values in the dcoument "Dutch Smart Meter Requirements" and the Domoticz values might be useful. Perhaps such a cross-reference is available somewhere?
Please give it a try and you will see.
It is a P1 Smart meter device, it will show:
Total Electricity Usage (Current usage (W), Daily usage (kWh) and Total usage (kWh), idem Return values
When you click on the log button you will see the graphs. When you click in the log on the report button you will see the values and graphs per month and year.
JosFr
Post by JosFr »
Ah. I see! Coming from OpenHab this functions differently from what I expected. Thanks!
