KNMI API in Dashticz
NilsNijenhuis
Does anyone know a way to get a KNMI api working in dashticz instead of the Open Weather Map.
I like the layout of the Open Weather Map widget, but the Open Weather Map does give a lot of inaccurate weather forecast. if the sun is shining the widget says cloudy, etc.
and i know from a knmi app on my telefone that KNMI is a lot more accurate.
it's possible to get the API at https://weerlive.nl/delen.php
see the attachment for al the data fields the API gives.
regards Nils
regards Nils
- knmi.jpg (192.25 KiB) Viewed 3385 times
Lokonli
Re: KNMI API in Dashticz
In latest beta I've added KNMI as weather forecast provider.NilsNijenhuis wrote: Wednesday 19 October 2022 15:25 Hello,
regards Nils
Can you test?
blocks['knmi4'] = {
type: 'weather',
provider: 'knmi',
city:'amsterdam',
apikey: 'xxx',
layout: 4,
width: 6,
count: 3
- kiddigital
@lokonli , why not build a Domoticz module for KNMI and let Dashticz display it? Then the values can be used for other automation scenario’s as well
Lokonli
Good suggestion.kiddigital wrote: Tuesday 15 November 2022 21:35 @lokonli , why not build a Domoticz module for KNMI and let Dashticz display it? Then the values can be used for other automation scenario’s as well![]()
Data collection is the easy part.
Rendering weather information from different sources (OWM, KNMI) in a consistent way while the weather data is not the same is more challenging.
The rendering part had to be made anyway.
Further,
For weather integration in Domoticz I have to create a Domoticz device for every information element. That will create a lot of additional devices. And then I've to find an easy way to transfer all applicable device info from Domoticz to Dashticz. Maybe in the future I'll have a look at this.
- EdwinK
- Domoticz version: BETA
just added the block
(looks like I need to fix the layout some more
NilsNijenhuis
Hello Lokonli, sorry for the late reaction. I have tested the block and it gives the following result.
The tekst part below 'Wisselvallig en zacht' is a little crowded but the rest looks nice
- Schermafbeelding 2022-12-24 151632.jpg (235.23 KiB) Viewed 3198 times
NilsNijenhuis
with al little styling it looks a little better.
Is it also possible to make a layout with only the 4 days forecast from knmi, like i use below the KNMI4 block?
- knmi.jpg (59.03 KiB) Viewed 3178 times
Lokonli
Did you already try with layout:0 as block parameter?
NilsNijenhuis
I tought that lay-out 0 gave an error, but i will check it again
jake
I also tested the knmi. It works fine. I found these differences with OWM, while having taken over all the same parameters:
Only 3 day forcast, including today. The forth day gives 0 numbers and a non existing image
The description is not available
Wind force is visible, but not wind direction.
- Sjonnie2017
- Domoticz version: Latest ß
I am struggling to get this to work. I have defined the KNMI weather blocks in two different ways. The way I am used to (i.e. create a declaration at the start) and the way which is used in this thread. Unfortunately both types of declaration do not work. I am having problems showing weather forecasts ever since the new Domoticz update. I can'tbelieve it has anything to do with it but there you have it
I changed to branch beta so that shouldn't be a problem.
Here is my config.js (in part):
Any tips?
// Weer
//// Open Weather Maps actueel weer
//blocks['currentweather_big_owm'] = {}
//blocks['currentweather_big_owm']['width'] = 8;
// Open Weather Maps 5 daagse voorspelling
blocks['weather_owm'] = {}
blocks['weather_owm']['width'] = 12;
blocks['KNMI'] = {
type: 'weather',
provider: 'knmi',
apikey: '12345678',
city: 'amsterdam',
layout: 4,
width: 12,
count: 3
// Made a declaration of block weer at the beginning of my js file. Looks like this (without the slashes
// var weer = 'weer'
blocks[weer] = {}
blocks[weer]['type'] = 'weather';
blocks[weer]['provider'] = 'knmi';
blocks[weer]['apikey'] = '12345678';
blocks[weer]['city'] = 'Amsterdam';
blocks[weer]['layout'] = 4;
blocks[weer]['width'] = 12;
blocks[weer]['count'] = 3;
YouLess Energy meter
- HansieNL
Can you try with a minimal config.js with just the following block and see if this works:
blocks['KNMI'] = {
type: 'weather',
provider: 'knmi',
apikey: '12345678',
city: 'amsterdam',
layout: 4,
width: 12,
count: 3
Blah blah blah
- Sjonnie2017
Tx for your reply. I created a new config file and only added the weather block(s) to it. Unfortunately I get the same results.
The code I used:
Additional info: using Dashticz latest beta, tested on tablet, desktop and different browsers.
If there is a problem in my config file, I just don't see it
EDIT: And just when you think you can't see it, you see it
I disabled in my config file and now all is working as it should. Thanks HansieNL for your support and tip!
The code I used:
// Algemene configuratie
var config = {}
// Aanpassing om Weather icons op oude tablet te laten zien
config['use_cors'] = 1;
// einde aanpassing
config['domoticz_ip'] = 'http://111.222.333.444:2080'; ,-fake of course ;-)
config['login_timeout'] = '60';
config['user_name'] = '';
config['pass_word'] = '';
config['app_title'] = 'Home Control';
config['room_plan'] = '0';
config['dashticz_refresh'] = '1440';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = '0';
config['standby_call_url_on_end'] = '0';
config['theme'] = 'default';
config['background_image'] = 'bg14.jpg';
config['standby_after'] = '0';
config['start_page'] = '1';
config['enable_swiper'] = '2';
config['vertical_scroll'] = '2';
config['auto_swipe_back_to'] = '1';
config['auto_swipe_back_after'] = '0';
config['auto_slide_pages'] = '0';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = '0';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = '0';
config['gm_zoomlevel'] = '0';
config['gm_latitude'] = '0';
config['gm_longitude'] = '0';
config['speak_lang'] = 'nl-NL';
config['switch_horizon'] = '0';
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['hide_off_button'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 1;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['hide_mediaplayer'] = 0;
// Graph settings
config['graph_zoom'] = 1;
// Scherm configuratie
var max_resolution_desktop = 'default';
var max_resolution_tablet = 'tablet';
var max_resolution_phone = 'phone';
// Apparaat definities
// Weer block
var weer = 'weer'
// Buttons
var buttons = {}
// Blocks
var blocks = {}
// Weer
blocks['KNMI'] = {
type: 'weather',
provider: 'knmi',
apikey: '12345678',
city: 'amsterdam',
layout: 4,
width: 12,
count: 3
blocks[weer] = {}
blocks[weer]['apikey'] = '04281a95aa';
// Columns
var columns = {}
// Aangepaste invulling voor de titelbalk
columns['bar'] = {}
columns['bar']['blocks'] = ['logo','miniclock','sunrise']
// Screen 1 voor tablet
columns[1] = {}
columns[1]['blocks'] = [weer, 'KNMI']
columns[1]['width'] = 8;
// Screens
var screens = {}
// Tablet
screens[max_resolution_tablet] = {}
screens[max_resolution_tablet]['maxwidth'] = 1280;
screens[max_resolution_tablet]['maxheight'] = 800;
screens[max_resolution_tablet][1] = {}
screens[max_resolution_tablet][1]['background'] = 'bg14.jpg';
screens[max_resolution_tablet][1]['columns'] = [1]
config['use_cors'] = 1;ConBee II - TRÅDFRI lights + switches, loads of ChingLing dimmers and switches, Heiman and Xiaomi sensors
Daro1003
- Domoticz version: 2023.1
I am from Poland, from the town of Szerzyny, how can I add Poland and such a town to have the weather? Generally the block works and the weather from amsterdam is shown
- kiddigital
KNMI is the Dutch weatherservice. You can use the OpenWeatherMap (OWM) service which has support for most (larger) cities around the world.Daro1003 wrote:I am from Poland, from the town of Szerzyny, how can I add Poland and such a town to have the weather? Generally the block works and the weather from amsterdam is shown
tested KNMI for some months. Pretty bad. Says cloudy on sunny days.
Back to OpenWheatherMap for me
NilsNijenhuis
Yes unfortunately I also notice that knmi deviates quite a bit, I also have continuous clouds while the sky is clear blue or similar....
But it seems like all weather stations are pretty wrong lately.
