Thanks for trying the script.
It doesn't update for this line:
2022-11-01 22:35:59.859 Status: dzVents: Debug: Hey solar battery: scriptInterval value increased to inf seconds to have a maximum deviation of 10 percent
It mentions that the time interval to update the solar battery is updated to 'inf' seconds. I don't understand where the infinity? word comes from, I think the dzvents 'round' function creates that for some reason.
Can you please check the domoticz user variables 'inverter power' and the value in the lua script for 'script interval'. I'd say to start with a 2000W simulated inverter power and a script time interval of 60 seconds. (decreasing the time interval too much will reduce the accuracy of measurement of Wh, due to small amounts of Wh in such a short time. The counters in domoticz can only handle a minimum value of 1Wh. If you measure every second, this means that 1Wh in 1 second means 3600W of power, a very rough way of registering data. Combine that with the fact that data gets compressed to 5 minute intervals by domoticz very quickly and you realize that very small intervals don't make sense.
LUA – Virtual Solar Battery: simulate the presence of a battery for storing harvested solar energy
Re: LUA – Virtual Solar Battery: simulate the presence of a battery for storing harvested solar energy
Hello Jake,
Thans for responding!
I tried different settings as suggested by you, unfortunately not the desired effect either. The Domoticz log also remains unchanged....
Apparently I'm the only user of your script with this problem?
Gr. Theo.
Gr. Theo.
- variables.jpg (77.95 KiB) Viewed 1325 times
- Devices.jpg (277.87 KiB) Viewed 1325 times
jake
Please share your script and make a screenshot of your user variables. Problems are there to be solved
jake
Oops, I only see now that you shared your user variables as well and there I see the problem: you chose an inverter capacity of 0 Watt. This means that your 'battery'won't be charged or used. If you don't want to deal with limitations to the amount of power that can flow from and to the battery, choose a big value of, for instance, 10000 W. That should do it.
I will have to add a warning for this in the script, to prevent this error searching, like we just did.
Hi Jake,
Yes, now it works!
Sorry for the inconvenience, my mistake, should have read better!
Thank you very much!
Regards, Theo.
Yes, now it works!
Regards, Theo.
jake
Nice, for me it is also a learning curve, since I originally developed the script for my own situation. Preventing errors due to user mistakes, takes about as many lines as the primary code
ubfssF
- Domoticz version: 2.2364
My log shows an error, while the calculation seems te be done just fine. Any ideas?
The code I use:
--version 0.1 02-04-2021: dzVents version of solar battery script
--version 0.1.1 03-04-2021: fix left behind variable and avoidance of power level > max inverter power level, due to rounding of calculation
--version 0.1.2 05-04-2021: changed a check for latest data storage from seconds to milliseconds to accommodate meters that update every second
--version 0.1.3 05-04-2021: Added a check to avoid big deviations in calculation when inverter power level is small while having
-- also a small script interval. Added more debug logging
--version 0.1.4b 10-04-2021: Description text fix + little preparation for future release
--version 0.1.5 11-04-2021: Lost energy due to battery and due to inverter size are now split and only combined during device update
--version 0.2a 14-04-2021: BREAKING CHANGE: -- 'Lost Energy' 'Electric + Instant + Counter' device need to be replaced by a 'P1-meter' device
-- New 'P1-meter' device needs to be added to trace losses in limited battery inverter
--To be created virtual devices in the hardware section of Domoticz:
local solarBattery_name = 'Virtual Solar Battery' -- (1) Virtual 'Custom Sensor' device name for the 'Virtual Solar Battery'. Change axis label to kWh
local batteryUsage_name = 'Virtual Solar Battery Usage' -- (2) Virtual 'P1-meter' device name for monitoring storage in and consumption from the solar battery
--local lostEnergy_name = 'Lost Solar Energy' (No longer needed, will be removed in later version -- (x) Virtual 'Electric Instant + Counter' device name for the 'Lost Solar Energy'
local lostBattery_name = 'Lost Solar Battery Energy' -- (3) Virtual 'P1-meter' device name for the 'Lost Solar Battery Energy'
local lostInverter_name = 'Lost Solar Battery Inverter Energy' -- (4) Virtual 'P1-meter' device name for the 'Lost Solar Battery Inverter Energy'
--To be created User Variable in the Setup - More Options - User Variable section:
local battery_capacity_name = 'SolarBatteryCapacity' -- (5) User Variable name for the 'Solar Battery Capacity'. Type 'Integer'. Value in Wh (4kWh battery = '4000')
local battery_inverter_power_name = 'SolarBatteryInverterCap' -- (6) User variable name for the 'Solar Battery Inverter Power'. Type 'Integer'. Value in W
--Energy meter(s) management
--name the device(s) used for counting energy from/to the grid
--when a P1 meter is used for both 'from' and 'to' the grid, fill in this name for both lines! Else, fill in the name for both requested devices
--Device name for consumed energy FROM the grid:
local consumedEnergyMeter_name = 'Energie kWh' --(7)
--Device name for delivered energy TO the grid:
local returnedEnergyMeter_name = 'Energie kWh' --(8)
--decide if energy consumption with an empty battery counts as 'lost energy'
local emptyBatteryIsLostEnergy = 1 --(1 = yes, 0 = no) --(9)
--decide if energy losses due to limited inverter power count with a full/empty battery
local emptyFullBatteryCountLostInverterEnergy = 1 --(1 = yes, 0 = no) --(10)
--Interval of running the Script
local scriptInterval = 60 --(seconds. Minimum interval depends on update frequency of P1-meter. 0 = P1-meter update frequency) --(11)
-- 1 trigger for P1 meter with both consumption and production meter integrated. Otherwise 2 meters
if (consumedEnergyMeter_name == returnedEnergyMeter_name) then
meterName = consumedEnergyMeter_name
meterName = consumedEnergyMeter_name ..', '.. returnedEnergyMeter_name
active = true,
devices = {
--timer based devices
--sensor based devices
meterName,
--setting devices
--actuator devices
-- timer = {'every minute'}},
data = {
returnedEnergy = {initial=nil, history = true, maxItems = 1},
consumedEnergy = {initial= nil, history = true, maxItems = 1}
logging = {
level = domoticz.LOG_DEBUG, --domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG or domoticz.LOG_ERROR
marker = "Hey solar battery"
---error checking functions ---
--check whether devices exist by veryfing their name
if domoticz.utils.deviceExists(solarBattery_name) == false then
domoticz.log('necessary device '.. solarBattery_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif domoticz.utils.deviceExists(batteryUsage_name) == false then
domoticz.log('necessary device '.. batteryUsage_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
goto endScript
--elseif domoticz.utils.deviceExists(lostEnergy_name) == false then
-- domoticz.log('necessary device '.. lostEnergy_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
-- goto endScript
elseif domoticz.utils.deviceExists(lostBattery_name) == false then
domoticz.log('necessary device '.. lostBattery_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif domoticz.utils.deviceExists(lostInverter_name) == false then
domoticz.log('necessary device '.. lostInverter_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif domoticz.utils.variableExists(battery_capacity_name) == false then
domoticz.log('User variable '.. battery_capacity_name ..' doesnt exist. Script will end. Please add the user variable to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif domoticz.utils.variableExists(battery_inverter_power_name) == false then
domoticz.log('User variable '.. battery_inverter_power_name ..' doesnt exist. Script will end. Please add the user variable to Domoticz', domoticz.LOG_ERROR)
goto endScript
--Devices exists, now define devices/variable within Domoticz:
local solarBattery = domoticz.devices(solarBattery_name)
local batteryUsage = domoticz.devices(batteryUsage_name)
--local lostEnergy = domoticz.devices(lostEnergy_name)
local lostBattery = domoticz.devices(lostBattery_name)
local lostInverter = domoticz.devices(lostInverter_name)
local consumedEnergyMeter = domoticz.devices(consumedEnergyMeter_name)
local returnedEnergyMeter = domoticz.devices(returnedEnergyMeter_name)
local battery_capacity = domoticz.variables(battery_capacity_name)
local battery_inverter_power = domoticz.variables(battery_inverter_power_name)
--Define script variables
local oldConsumedEnergyMeter
local oldReturnedEnergyMeter
local newConsumedEnergyMeter
local newReturnedEnergyMeter
local energyBalance
local solarBatteryValue
local newSolarBatteryValue
--local newLostEnergy
local newLostEnergyFull
local newLostEnergyEmpty
local batteryUsedEnergy
local batteryProdEnergy
local batteryUsedWatt
local batteryProdWatt
local batter
local deltaTime
local maxBbatteryInverterEnergy -- battery inverter power x (time since last time the script was ran / 3600) in Wh
local inverterLostEnergy -- lost energy to or from the grid due to limitation in battery capacity and/or battery inverter power
local inverterLostEnergyProd
local inverterLostEnergyUsed
local inverterLostEnergyProdFull
local inverterLostEnergyUsedEmpty
local inverterLostProdWatt
local inverterLostUsedWatt
local _ = domoticz.utils._
--check if new created virtual devices are the right type
if (solarBattery.deviceType ~= 'General' and solarBattery.deviceSubType ~= "Custom Sensor") then
domoticz.log('created device '.. solarBattery_name ..' is not of the type Custom Sensor. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif (batteryUsage.deviceType ~= 'P1 Smart Meter' and batteryUsage.deviceSubType ~= "Energy") then
domoticz.log('created device '.. batteryUsage_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
goto endScript
--elseif (lostEnergy.deviceType ~= 'General' and lostEnergy.deviceSubType ~= "kWh") then
-- domoticz.log('created device '.. lostEnergy_name ..' is not of the type RFXMeter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
-- goto endScript
elseif (lostBattery_name.deviceType ~= 'P1 Smart Meter' and lostBattery.deviceSubType ~= "Energy") then
domoticz.log('created device '.. lostBattery_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
elseif (lostInverter.deviceType ~= 'P1 Smart Meter' and lostInverter.deviceSubType ~= "Energy") then
domoticz.log('created device '.. lostEnergy_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
--check if variables are the right type and contain a good value
if battery_capacity.type ~= domoticz.INTEGER then
domoticz.log('User variable '.. battery_capacity_name ..' is not of the type INTEGER. Script will end. Please change the user variable to the type INTEGER and put a positive number in there', domoticz.LOG_ERROR)
goto endScript
elseif (battery_capacity.value == nil or battery_capacity.value < 0) then
domoticz.log('Solar battery capacity wrong or <0. Now set at 2000(Wh)', domoticz.LOG_ERROR)
battery_capacity.set(2000)
if battery_inverter_power.type ~= domoticz.INTEGER then
domoticz.log('User variable '.. battery_inverter_power_name ..' is not of the type INTEGER. Script will end. Please change the user variable to the type INTEGER and put a positive number in there', domoticz.LOG_ERROR)
goto endScript
elseif (battery_inverter_power.value == nil or battery_capacity.value < 0) then
domoticz.log('Solar battery inverter capacity wrong or <0. Now set at 4000(W)', domoticz.LOG_ERROR)
battery_inverter_power.set(4000)
if (emptyBatteryIsLostEnergy == nil or (emptyBatteryIsLostEnergy ~= 0 and emptyBatteryIsLostEnergy ~= 1 )) then
domoticz.log('internal variable emptyBatteryIsLostEnergy does not contain a value of 0 or 1. Script will use value 1 and count lost energy at an empty battery')
if (emptyFullBatteryCountLostInverterEnergy == nil or (emptyFullBatteryCountLostInverterEnergy ~= 0 and emptyFullBatteryCountLostInverterEnergy ~= 1)) then
domoticz.log('internal variable emptyFullBatteryCountLostInverterEnergy does not contain a value of 0 or 1. Script will use a value of 1 and count lost inverter energy at empty or full battery')
--check if persistent data exist and is a number. The new 'zero' value will be updated further down the script
if (domoticz.data.consumedEnergy.size == 0 or
_.isNumber(domoticz.data.consumedEnergy.getLatest().data)==false or
domoticz.data.consumedEnergy.getLatest().data < 0) then
domoticz.data.consumedEnergy.add(0)
domoticz.log('dzVents variable consumedEnergy was empty or did not contain a number. Now set as 0',domoticz.LOG_DEBUG)
if (domoticz.data.returnedEnergy.size == 0 or
_.isNumber(domoticz.data.returnedEnergy.getLatest().data)==false or
domoticz.data.returnedEnergy.getLatest().data < 0) then
domoticz.data.returnedEnergy.add(0)
domoticz.log('dzVents variable returnedEnergy was empty or did not contain a number. Now set as 0',domoticz.LOG_DEBUG)
--give a new virtual devices a start load of 0 kWh and 0 W
if solarBattery.sValue == nil then
solarBattery.updateCustomSensor(0)
domoticz.log('solar battery value is nil en will be updated to 0',domoticz.LOG_DEBUG)
if (batteryUsage.usage1 == nil or batteryUsage.return1 == nil) then batteryUsage.updateP1(0,0,0,0,0,0) end
--if lostEnergy.WhTotal == nil then lostEnergy.updateElectricity(0,0) end
if (lostBattery.usage1 == nil or lostBattery.return1 == nil) then lostBattery.updateP1(0,0,0,0,0,0) end
if (lostInverter.usage1 == nil or lostInverter.return1 == nil) then lostInverter.updateP1(0,0,0,0,0,0) end
--Check if scriptInterval value is valid
if (_.isNumber(scriptInterval) == false or scriptInterval < 0) then
domoticz.log('value for scriptInterval is invalid (not a number, or < 0). Script will use P1 update frequency (scriptInterval = 0)',domoticz.LOG_ERROR)
scriptInterval = 0
--Check if inverter power level in relation to script interval and the fact that the minimum energy count is 1Wh, is in balance
--(example: inverter power = 1800 @ scriptInterval of 1 second = 0,5 Wh.
--At 20 seconds ((3600/1800) x (100/10)) = 10Wh +/-0.5Wh(minimum counter value))
-- 10 +/-0.5 is a 10% deviation
local maxDev = 10 --percent
if (3600 / battery_inverter_power.value) * (100 / maxDev) > scriptInterval then
scriptInterval = _.round ((3600 / battery_inverter_power.value) * (100 / maxDev), 3)
domoticz.log('scriptInterval value increased to ' .. scriptInterval .. ' seconds to have a maximum deviation of ' .. maxDev .. ' percent', domoticz.LOG_DEBUG)
---end of error checking functions ---
--check if the script should continue, based on given scriptInterval timer
--check timestamp from persistent data
deltaTime = (domoticz.data.consumedEnergy.getLatest().time.millisecondsAgo)/1000
if (deltaTime < scriptInterval) then
domoticz.log("script trigger interval < than set value for scriptInterval (".. scriptInterval .. ")",domoticz.LOG_DEBUG)
goto endScript
---calculate new energy values
--check if device is a P1 meter
domoticz.log('energymeter type = '.. consumedEnergyMeter.deviceType, domoticz.LOG_DEBUG)
if consumedEnergyMeter.deviceType == 'P1 Smart Meter' then
newConsumedEnergyMeter = consumedEnergyMeter.usage1 + consumedEnergyMeter.usage2
newReturnedEnergyMeter = returnedEnergyMeter.return1 + returnedEnergyMeter.return2
--batteryProdWatt = consumedEnergyMeter.usage
--batteryUsedWatt = consumedEnergyMeter.usageDelivered
domoticz.log('P1 meter: usage and return values will be used', domoticz.LOG_DEBUG)
else -- other meter than P1 Smart Meter
newConsumedEnergyMeter = consumedEnergyMeter.WhTotal
newReturnedEnergyMeter = returnedEnergyMeter.WhTotal
domoticz.log('General Energy meters for consumption and returned: WhTotal will be used per meter', domoticz.LOG_DEBUG)
---load previous energy values for consumption and returnedEnergy
oldReturnedEnergyMeter = domoticz.data.returnedEnergy.getLatest().data
oldConsumedEnergyMeter = domoticz.data.consumedEnergy.getLatest().data
---check if the dzVents variable is new and if so, fill it with the current meter value
if oldConsumedEnergyMeter == 0 then
domoticz.data.consumedEnergy.add(newConsumedEnergyMeter)
if oldReturnedEnergyMeter == 0 then
domoticz.data.returnedEnergy.add(newReturnedEnergyMeter)
goto endScript
if (oldConsumedEnergyMeter == 0 or oldReturnedEnergyMeter == 0) then
domoticz.log('Script is gathering the value for the consumed / produced energy meter for the 1st time. Script will end and be continued at the next interval', domoticz.LOG_DEBUG)
goto endScript
---check for error when new value < old value
if newConsumedEnergyMeter < oldConsumedEnergyMeter then
domoticz.log('New value of consumed enery meter ('.. newConsumedEnergyMeter ..' Wh < previous value of '.. oldConsumedEnergyMeter..' Wh. Script will not continue',domoticz.LOG_ERROR)
goto endScript
elseif newReturnedEnergyMeter < newReturnedEnergyMeter then
domoticz.log('New value of returned enery meter ('.. newReturnedEnergyMeter ..' Wh < previous value of '.. oldReturnedEnergyMeter..' Wh. Script will not continue',domoticz.LOG_ERROR)
goto endScript
---calculate max. Wh that the battery inverter can handle (both directions)
maxBbatteryInverterEnergy = battery_inverter_power.value * (domoticz.data.consumedEnergy.getLatest().time.millisecondsAgo / 3600000)
domoticz.log('maxBbatteryInverterEnergy = '..battery_inverter_power.value .. ' x (' ..
domoticz.data.consumedEnergy.getLatest().time.secondsAgo .. ' / 3600) = ' .. _.round (maxBbatteryInverterEnergy, 1) .. ' Wh',domoticz.LOG_DEBUG)
---calculate the energy balance by: return - consumption
--a negative value means consumption
--a positive value means return
energyBalance = (newReturnedEnergyMeter - oldReturnedEnergyMeter) - (newConsumedEnergyMeter - oldConsumedEnergyMeter)
domoticz.log('Energy balance = '..energyBalance..' Wh (negative = consumption)',domoticz.LOG_DEBUG)
if energyBalance > maxBbatteryInverterEnergy then
inverterLostEnergy = energyBalance - maxBbatteryInverterEnergy
inverterLostEnergyProd = energyBalance - maxBbatteryInverterEnergy
inverterLostEnergyUsed = 0
domoticz.log('Positive energybalance above max inverter capacity. inverterLostEnergy = '.. energyBalance ..' - ' ..maxBbatteryInverterEnergy .. ' = ' .. inverterLostEnergy, domoticz.LOG_DEBUG)
energyBalance = maxBbatteryInverterEnergy
batteryProdWatt = battery_inverter_power.value
batteryUsedWatt = 0
elseif energyBalance < (-1 * maxBbatteryInverterEnergy) then -- more consumption than inverter can deliver
inverterLostEnergy = (-1 * energyBalance ) - maxBbatteryInverterEnergy
inverterLostEnergyUsed = (-1 * energyBalance ) - maxBbatteryInverterEnergy
inverterLostEnergyProd = 0
domoticz.log('Negative Energybalance below max inverter capacity. inverterLostEnergy = '.. -1 *energyBalance ..' - ' ..maxBbatteryInverterEnergy .. ' = ' .. inverterLostEnergy, domoticz.LOG_DEBUG)
energyBalance = -1 * maxBbatteryInverterEnergy
batteryUsedWatt = battery_inverter_power.value
batteryProdWatt = 0
inverterLostEnergy = 0
domoticz.log('Energy balance within capacity of battery inverter', domoticz.LOG_DEBUG)
---check the effect of the energy balance on the solar battery
solarBatteryValue = solarBattery.sValue * 1000 -- custom sensor registers in kWh, while internal calculations are done in Wh
newSolarBatteryValue = solarBatteryValue + energyBalance
domoticz.log('solar battery value = '..solarBatteryValue ..' Wh, battery capacity is '..battery_capacity.value ..' Wh, new solar battery value = '..newSolarBatteryValue, domoticz.LOG_DEBUG)
--initial variable values:
batteryProdEnergy = 0
batteryUsedEnergy = 0
newLostEnergyEmpty = 0
newLostEnergyFull = 0
inverterLostEnergyProdFull = 0
inverterLostEnergyUsedEmpty = 0
--decide what the new state of the battery will be
if newSolarBatteryValue > battery_capacity.value then --more energy produced than fits in battery
--newLostEnergy = newSolarBatteryValue - battery_capacity.value --count all energy that goes above the set capacity level
newLostEnergyFull = newSolarBatteryValue - battery_capacity.value --count all energy that goes above the set capacity level
--update battery level with max value
newSolarBatteryValue = battery_capacity.value
--check if the battery is not already full
if solarBatteryValue < battery_capacity.value then
batteryProdEnergy = battery_capacity.value - solarBatteryValue
if emptyFullBatteryCountLostInverterEnergy == 0 then --battery is already full without lost inverter energy
inverterLostProdWatt = 0
inverterLostEnergyProdFull = inverterLostEnergyProd
inverterLostEnergyProd = 0 -- reset value to zero, because 'ProdFull' is used instead
elseif newSolarBatteryValue < 0 then --more energy consumed than available in battery
--check if the battery is not already empty
if solarBatteryValue > 0 then
--first calculate the battery-used value (old value - 0)
batteryUsedEnergy = solarBatteryValue
if emptyBatteryIsLostEnergy == 1 then -- also count lost energy due to empty battery
--newLostEnergy = newSolarBatteryValue * -1 --(newSolarBatteryValue is negative, but it needs to be added UP to the counter)
newLostEnergyEmpty = newSolarBatteryValue * -1 --(newSolarBatteryValue is negative, but it needs to be added UP to the counter)
--newLostEnergy = 0
if emptyFullBatteryCountLostInverterEnergy == 0 then --battery is already empty without lost inverter energy, don't count (1 = count)
inverterLostUsedWatt = 0
inverterLostEnergyUsedEmpty = inverterLostEnergyUsed
inverterLostEnergyUsed = 0 -- reset value to zero, because 'UsedEmpty' is used instead
--update battery level to zero
newSolarBatteryValue = 0
else --new battery within bandwith of chosen battery capacity
--check if energy from battery is consumed
if energyBalance > 0 then
batteryProdEnergy = energyBalance
elseif energyBalance < 0 then
--negative value means consumption
batteryUsedEnergy = energyBalance*-1 --(energyBalance is negative, but it needs to be added UP to the counter)
--either no energy used or energy is returned
--newLostEnergy = 0
domoticz.log('battery Used Energy = '..batteryUsedEnergy .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('battery Prod Energy = '..batteryProdEnergy .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('battery Lost Energy empty = '..newLostEnergyEmpty .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('battery Lost Energy full = '..newLostEnergyFull .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('inverter Lost Energy production = '..inverterLostEnergyProd .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('inverter Lost Energy production when battery is full = '..inverterLostEnergyProdFull .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('inverter Lost Energy usage = '..inverterLostEnergyUsed .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('inverter Lost Energy usage when battery is full = '..inverterLostEnergyUsedEmpty .. 'Wh',domoticz.LOG_DEBUG)
--calculate battery power, based on battery energy
if batteryUsedWatt == nil then batteryUsedWatt = _.round (batteryUsedEnergy * (3600/deltaTime), 0) end
if batteryProdWatt == nil then batteryProdWatt = _.round (batteryProdEnergy * (3600/deltaTime), 0) end
--calculate lost energy power, based on lost energy
if lostEnergyWatt == nil then lostEnergyWatt = _.round ((newLostEnergyFull + newLostEnergyEmpty) * (3600/deltaTime), 0) end
--calculate lost inverter power, based on lost inverter energy
if inverterLostEnergyUsedEmpty == nil then inverterLostEnergyUsedEmpty = 0 end
if inverterLostEnergyProdFull == nil then inverterLostEnergyProdFull = 0 end
if inverterLostUsedWatt == nil then inverterLostUsedWatt = _.round ((inverterLostEnergyUsed + inverterLostEnergyUsedEmpty) * (3600/deltaTime), 0) end
if inverterLostProdWatt == nil then inverterLostProdWatt = _.round ((inverterLostEnergyProd + inverterLostEnergyProdFull)* (3600/deltaTime), 0) end
---update devices
--update battery level with new value
solarBattery.updateCustomSensor(_.round(newSolarBatteryValue / 1000,3))
--update battery usage with new value
batteryUsage.updateP1(batteryUsage.usage1 + batteryUsedEnergy, 0, batteryUsage.return1 + batteryProdEnergy, 0, batteryUsedWatt, batteryProdWatt)
--update lost energy with new value
--lostEnergy.updateElectricity(_.round(newLostEnergy * (3600/deltaTime),0), _.round(lostEnergy.WhTotal + newLostEnergy + inverterLostEnergy,0))
lostBattery.updateP1(lostBattery.usage1 + newLostEnergyEmpty, 0, lostBattery.return1 + newLostEnergyFull, 0, lostEnergyWatt, 0)
--update lost inverter energy with new value
lostInverter.updateP1(lostInverter.usage1 + inverterLostEnergyUsed, lostInverter.usage2 + inverterLostEnergyUsedEmpty,
lostInverter.return1 + inverterLostEnergyProd, lostInverter.return2 + inverterLostEnergyProdFull,
inverterLostUsedWatt, inverterLostProdWatt)
---Update dzVents variables with the new meter values
::endScript::
jake
On my phone I can't see what line 306 is. There is your answer hiddenubfssF wrote:
The code I use:Code: Select all
--version 0.1 02-04-2021: dzVents version of solar battery script --version 0.1.1 03-04-2021: fix left behind variable and avoidance of power level > max inverter power level, due to rounding of calculation --version 0.1.2 05-04-2021: changed a check for latest data storage from seconds to milliseconds to accommodate meters that update every second --version 0.1.3 05-04-2021: Added a check to avoid big deviations in calculation when inverter power level is small while having -- also a small script interval. Added more debug logging --version 0.1.4b 10-04-2021: Description text fix + little preparation for future release --version 0.1.5 11-04-2021: Lost energy due to battery and due to inverter size are now split and only combined during device update --version 0.2a 14-04-2021: BREAKING CHANGE: -- 'Lost Energy' 'Electric + Instant + Counter' device need to be replaced by a 'P1-meter' device -- New 'P1-meter' device needs to be added to trace losses in limited battery inverter --To be created virtual devices in the hardware section of Domoticz: local solarBattery_name = 'Virtual Solar Battery' -- (1) Virtual 'Custom Sensor' device name for the 'Virtual Solar Battery'. Change axis label to kWh local batteryUsage_name = 'Virtual Solar Battery Usage' -- (2) Virtual 'P1-meter' device name for monitoring storage in and consumption from the solar battery --local lostEnergy_name = 'Lost Solar Energy' (No longer needed, will be removed in later version -- (x) Virtual 'Electric Instant + Counter' device name for the 'Lost Solar Energy' local lostBattery_name = 'Lost Solar Battery Energy' -- (3) Virtual 'P1-meter' device name for the 'Lost Solar Battery Energy' local lostInverter_name = 'Lost Solar Battery Inverter Energy' -- (4) Virtual 'P1-meter' device name for the 'Lost Solar Battery Inverter Energy' --To be created User Variable in the Setup - More Options - User Variable section: local battery_capacity_name = 'SolarBatteryCapacity' -- (5) User Variable name for the 'Solar Battery Capacity'. Type 'Integer'. Value in Wh (4kWh battery = '4000') local battery_inverter_power_name = 'SolarBatteryInverterCap' -- (6) User variable name for the 'Solar Battery Inverter Power'. Type 'Integer'. Value in W --Energy meter(s) management --name the device(s) used for counting energy from/to the grid --when a P1 meter is used for both 'from' and 'to' the grid, fill in this name for both lines! Else, fill in the name for both requested devices --Device name for consumed energy FROM the grid: local consumedEnergyMeter_name = 'Energie kWh' --(7) --Device name for delivered energy TO the grid: local returnedEnergyMeter_name = 'Energie kWh' --(8) --decide if energy consumption with an empty battery counts as 'lost energy' local emptyBatteryIsLostEnergy = 1 --(1 = yes, 0 = no) --(9) --decide if energy losses due to limited inverter power count with a full/empty battery local emptyFullBatteryCountLostInverterEnergy = 1 --(1 = yes, 0 = no) --(10) --Interval of running the Script local scriptInterval = 60 --(seconds. Minimum interval depends on update frequency of P1-meter. 0 = P1-meter update frequency) --(11) -- 1 trigger for P1 meter with both consumption and production meter integrated. Otherwise 2 meters if (consumedEnergyMeter_name == returnedEnergyMeter_name) then meterName = consumedEnergyMeter_name else meterName = consumedEnergyMeter_name ..', '.. returnedEnergyMeter_name end return { active = true, on = { devices = { --timer based devices --sensor based devices meterName, --setting devices --actuator devices } -- timer = {'every minute'}}, }, data = { returnedEnergy = {initial=nil, history = true, maxItems = 1}, consumedEnergy = {initial= nil, history = true, maxItems = 1} }, logging = { level = domoticz.LOG_DEBUG, --domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG or domoticz.LOG_ERROR marker = "Hey solar battery" }, execute = function(domoticz, device) ---error checking functions --- --check whether devices exist by veryfing their name if domoticz.utils.deviceExists(solarBattery_name) == false then domoticz.log('necessary device '.. solarBattery_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR) goto endScript elseif domoticz.utils.deviceExists(batteryUsage_name) == false then domoticz.log('necessary device '.. batteryUsage_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR) goto endScript --elseif domoticz.utils.deviceExists(lostEnergy_name) == false then -- domoticz.log('necessary device '.. lostEnergy_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR) -- goto endScript elseif domoticz.utils.deviceExists(lostBattery_name) == false then domoticz.log('necessary device '.. lostBattery_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR) goto endScript elseif domoticz.utils.deviceExists(lostInverter_name) == false then domoticz.log('necessary device '.. lostInverter_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR) goto endScript elseif domoticz.utils.variableExists(battery_capacity_name) == false then domoticz.log('User variable '.. battery_capacity_name ..' doesnt exist. Script will end. Please add the user variable to Domoticz', domoticz.LOG_ERROR) goto endScript elseif domoticz.utils.variableExists(battery_inverter_power_name) == false then domoticz.log('User variable '.. battery_inverter_power_name ..' doesnt exist. Script will end. Please add the user variable to Domoticz', domoticz.LOG_ERROR) goto endScript end --Devices exists, now define devices/variable within Domoticz: local solarBattery = domoticz.devices(solarBattery_name) local batteryUsage = domoticz.devices(batteryUsage_name) --local lostEnergy = domoticz.devices(lostEnergy_name) local lostBattery = domoticz.devices(lostBattery_name) local lostInverter = domoticz.devices(lostInverter_name) local consumedEnergyMeter = domoticz.devices(consumedEnergyMeter_name) local returnedEnergyMeter = domoticz.devices(returnedEnergyMeter_name) local battery_capacity = domoticz.variables(battery_capacity_name) local battery_inverter_power = domoticz.variables(battery_inverter_power_name) --Define script variables local oldConsumedEnergyMeter local oldReturnedEnergyMeter local newConsumedEnergyMeter local newReturnedEnergyMeter local energyBalance local solarBatteryValue local newSolarBatteryValue --local newLostEnergy local newLostEnergyFull local newLostEnergyEmpty local batteryUsedEnergy local batteryProdEnergy local batteryUsedWatt local batteryProdWatt local batter local deltaTime local maxBbatteryInverterEnergy -- battery inverter power x (time since last time the script was ran / 3600) in Wh local inverterLostEnergy -- lost energy to or from the grid due to limitation in battery capacity and/or battery inverter power local inverterLostEnergyProd local inverterLostEnergyUsed local inverterLostEnergyProdFull local inverterLostEnergyUsedEmpty local inverterLostProdWatt local inverterLostUsedWatt local _ = domoticz.utils._ --check if new created virtual devices are the right type if (solarBattery.deviceType ~= 'General' and solarBattery.deviceSubType ~= "Custom Sensor") then domoticz.log('created device '.. solarBattery_name ..' is not of the type Custom Sensor. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR) goto endScript elseif (batteryUsage.deviceType ~= 'P1 Smart Meter' and batteryUsage.deviceSubType ~= "Energy") then domoticz.log('created device '.. batteryUsage_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR) goto endScript --elseif (lostEnergy.deviceType ~= 'General' and lostEnergy.deviceSubType ~= "kWh") then -- domoticz.log('created device '.. lostEnergy_name ..' is not of the type RFXMeter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR) -- goto endScript elseif (lostBattery_name.deviceType ~= 'P1 Smart Meter' and lostBattery.deviceSubType ~= "Energy") then domoticz.log('created device '.. lostBattery_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR) elseif (lostInverter.deviceType ~= 'P1 Smart Meter' and lostInverter.deviceSubType ~= "Energy") then domoticz.log('created device '.. lostEnergy_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR) end --check if variables are the right type and contain a good value if battery_capacity.type ~= domoticz.INTEGER then domoticz.log('User variable '.. battery_capacity_name ..' is not of the type INTEGER. Script will end. Please change the user variable to the type INTEGER and put a positive number in there', domoticz.LOG_ERROR) goto endScript elseif (battery_capacity.value == nil or battery_capacity.value < 0) then domoticz.log('Solar battery capacity wrong or <0. Now set at 2000(Wh)', domoticz.LOG_ERROR) battery_capacity.set(2000) end if battery_inverter_power.type ~= domoticz.INTEGER then domoticz.log('User variable '.. battery_inverter_power_name ..' is not of the type INTEGER. Script will end. Please change the user variable to the type INTEGER and put a positive number in there', domoticz.LOG_ERROR) goto endScript elseif (battery_inverter_power.value == nil or battery_capacity.value < 0) then domoticz.log('Solar battery inverter capacity wrong or <0. Now set at 4000(W)', domoticz.LOG_ERROR) battery_inverter_power.set(4000) end if (emptyBatteryIsLostEnergy == nil or (emptyBatteryIsLostEnergy ~= 0 and emptyBatteryIsLostEnergy ~= 1 )) then emptyBatteryIsLostEnergy = 1 domoticz.log('internal variable emptyBatteryIsLostEnergy does not contain a value of 0 or 1. Script will use value 1 and count lost energy at an empty battery') end if (emptyFullBatteryCountLostInverterEnergy == nil or (emptyFullBatteryCountLostInverterEnergy ~= 0 and emptyFullBatteryCountLostInverterEnergy ~= 1)) then emptyFullBatteryCountLostInverterEnergy = 1 domoticz.log('internal variable emptyFullBatteryCountLostInverterEnergy does not contain a value of 0 or 1. Script will use a value of 1 and count lost inverter energy at empty or full battery') end --check if persistent data exist and is a number. The new 'zero' value will be updated further down the script if (domoticz.data.consumedEnergy.size == 0 or _.isNumber(domoticz.data.consumedEnergy.getLatest().data)==false or domoticz.data.consumedEnergy.getLatest().data < 0) then domoticz.data.consumedEnergy.add(0) domoticz.log('dzVents variable consumedEnergy was empty or did not contain a number. Now set as 0',domoticz.LOG_DEBUG) end if (domoticz.data.returnedEnergy.size == 0 or _.isNumber(domoticz.data.returnedEnergy.getLatest().data)==false or domoticz.data.returnedEnergy.getLatest().data < 0) then domoticz.data.returnedEnergy.add(0) domoticz.log('dzVents variable returnedEnergy was empty or did not contain a number. Now set as 0',domoticz.LOG_DEBUG) end --give a new virtual devices a start load of 0 kWh and 0 W if solarBattery.sValue == nil then solarBattery.updateCustomSensor(0) domoticz.log('solar battery value is nil en will be updated to 0',domoticz.LOG_DEBUG) end if (batteryUsage.usage1 == nil or batteryUsage.return1 == nil) then batteryUsage.updateP1(0,0,0,0,0,0) end --if lostEnergy.WhTotal == nil then lostEnergy.updateElectricity(0,0) end if (lostBattery.usage1 == nil or lostBattery.return1 == nil) then lostBattery.updateP1(0,0,0,0,0,0) end if (lostInverter.usage1 == nil or lostInverter.return1 == nil) then lostInverter.updateP1(0,0,0,0,0,0) end --Check if scriptInterval value is valid if (_.isNumber(scriptInterval) == false or scriptInterval < 0) then domoticz.log('value for scriptInterval is invalid (not a number, or < 0). Script will use P1 update frequency (scriptInterval = 0)',domoticz.LOG_ERROR) scriptInterval = 0 end --Check if inverter power level in relation to script interval and the fact that the minimum energy count is 1Wh, is in balance --(example: inverter power = 1800 @ scriptInterval of 1 second = 0,5 Wh. --At 20 seconds ((3600/1800) x (100/10)) = 10Wh +/-0.5Wh(minimum counter value)) -- 10 +/-0.5 is a 10% deviation local maxDev = 10 --percent if (3600 / battery_inverter_power.value) * (100 / maxDev) > scriptInterval then scriptInterval = _.round ((3600 / battery_inverter_power.value) * (100 / maxDev), 3) domoticz.log('scriptInterval value increased to ' .. scriptInterval .. ' seconds to have a maximum deviation of ' .. maxDev .. ' percent', domoticz.LOG_DEBUG) end ---end of error checking functions --- --check if the script should continue, based on given scriptInterval timer --check timestamp from persistent data deltaTime = (domoticz.data.consumedEnergy.getLatest().time.millisecondsAgo)/1000 if (deltaTime < scriptInterval) then domoticz.log("script trigger interval < than set value for scriptInterval (".. scriptInterval .. ")",domoticz.LOG_DEBUG) goto endScript end ---calculate new energy values --check if device is a P1 meter domoticz.log('energymeter type = '.. consumedEnergyMeter.deviceType, domoticz.LOG_DEBUG) if consumedEnergyMeter.deviceType == 'P1 Smart Meter' then newConsumedEnergyMeter = consumedEnergyMeter.usage1 + consumedEnergyMeter.usage2 newReturnedEnergyMeter = returnedEnergyMeter.return1 + returnedEnergyMeter.return2 --batteryProdWatt = consumedEnergyMeter.usage --batteryUsedWatt = consumedEnergyMeter.usageDelivered domoticz.log('P1 meter: usage and return values will be used', domoticz.LOG_DEBUG) else -- other meter than P1 Smart Meter newConsumedEnergyMeter = consumedEnergyMeter.WhTotal newReturnedEnergyMeter = returnedEnergyMeter.WhTotal domoticz.log('General Energy meters for consumption and returned: WhTotal will be used per meter', domoticz.LOG_DEBUG) end ---load previous energy values for consumption and returnedEnergy oldReturnedEnergyMeter = domoticz.data.returnedEnergy.getLatest().data oldConsumedEnergyMeter = domoticz.data.consumedEnergy.getLatest().data ---check if the dzVents variable is new and if so, fill it with the current meter value if oldConsumedEnergyMeter == 0 then domoticz.data.consumedEnergy.add(newConsumedEnergyMeter) end if oldReturnedEnergyMeter == 0 then domoticz.data.returnedEnergy.add(newReturnedEnergyMeter) goto endScript end if (oldConsumedEnergyMeter == 0 or oldReturnedEnergyMeter == 0) then domoticz.log('Script is gathering the value for the consumed / produced energy meter for the 1st time. Script will end and be continued at the next interval', domoticz.LOG_DEBUG) goto endScript end ---check for error when new value < old value if newConsumedEnergyMeter < oldConsumedEnergyMeter then domoticz.log('New value of consumed enery meter ('.. newConsumedEnergyMeter ..' Wh < previous value of '.. oldConsumedEnergyMeter..' Wh. Script will not continue',domoticz.LOG_ERROR) goto endScript elseif newReturnedEnergyMeter < newReturnedEnergyMeter then domoticz.log('New value of returned enery meter ('.. newReturnedEnergyMeter ..' Wh < previous value of '.. oldReturnedEnergyMeter..' Wh. Script will not continue',domoticz.LOG_ERROR) goto endScript end ---calculate max. Wh that the battery inverter can handle (both directions) maxBbatteryInverterEnergy = battery_inverter_power.value * (domoticz.data.consumedEnergy.getLatest().time.millisecondsAgo / 3600000) domoticz.log('maxBbatteryInverterEnergy = '..battery_inverter_power.value .. ' x (' .. domoticz.data.consumedEnergy.getLatest().time.secondsAgo .. ' / 3600) = ' .. _.round (maxBbatteryInverterEnergy, 1) .. ' Wh',domoticz.LOG_DEBUG) ---calculate the energy balance by: return - consumption --a negative value means consumption --a positive value means return energyBalance = (newReturnedEnergyMeter - oldReturnedEnergyMeter) - (newConsumedEnergyMeter - oldConsumedEnergyMeter) domoticz.log('Energy balance = '..energyBalance..' Wh (negative = consumption)',domoticz.LOG_DEBUG) if energyBalance > maxBbatteryInverterEnergy then inverterLostEnergy = energyBalance - maxBbatteryInverterEnergy inverterLostEnergyProd = energyBalance - maxBbatteryInverterEnergy inverterLostEnergyUsed = 0 domoticz.log('Positive energybalance above max inverter capacity. inverterLostEnergy = '.. energyBalance ..' - ' ..maxBbatteryInverterEnergy .. ' = ' .. inverterLostEnergy, domoticz.LOG_DEBUG) energyBalance = maxBbatteryInverterEnergy batteryProdWatt = battery_inverter_power.value batteryUsedWatt = 0 elseif energyBalance < (-1 * maxBbatteryInverterEnergy) then -- more consumption than inverter can deliver inverterLostEnergy = (-1 * energyBalance ) - maxBbatteryInverterEnergy inverterLostEnergyUsed = (-1 * energyBalance ) - maxBbatteryInverterEnergy inverterLostEnergyProd = 0 domoticz.log('Negative Energybalance below max inverter capacity. inverterLostEnergy = '.. -1 *energyBalance ..' - ' ..maxBbatteryInverterEnergy .. ' = ' .. inverterLostEnergy, domoticz.LOG_DEBUG) energyBalance = -1 * maxBbatteryInverterEnergy batteryUsedWatt = battery_inverter_power.value batteryProdWatt = 0 else inverterLostEnergy = 0 inverterLostEnergyProd = 0 inverterLostEnergyUsed = 0 inverterLostEnergyProd = 0 domoticz.log('Energy balance within capacity of battery inverter', domoticz.LOG_DEBUG) end ---check the effect of the energy balance on the solar battery solarBatteryValue = solarBattery.sValue * 1000 -- custom sensor registers in kWh, while internal calculations are done in Wh newSolarBatteryValue = solarBatteryValue + energyBalance domoticz.log('solar battery value = '..solarBatteryValue ..' Wh, battery capacity is '..battery_capacity.value ..' Wh, new solar battery value = '..newSolarBatteryValue, domoticz.LOG_DEBUG) --initial variable values: batteryProdEnergy = 0 batteryUsedEnergy = 0 newLostEnergyEmpty = 0 newLostEnergyFull = 0 inverterLostEnergyProdFull = 0 inverterLostEnergyUsedEmpty = 0 --decide what the new state of the battery will be if newSolarBatteryValue > battery_capacity.value then --more energy produced than fits in battery --newLostEnergy = newSolarBatteryValue - battery_capacity.value --count all energy that goes above the set capacity level newLostEnergyFull = newSolarBatteryValue - battery_capacity.value --count all energy that goes above the set capacity level --update battery level with max value newSolarBatteryValue = battery_capacity.value --check if the battery is not already full if solarBatteryValue < battery_capacity.value then batteryProdEnergy = battery_capacity.value - solarBatteryValue end if emptyFullBatteryCountLostInverterEnergy == 0 then --battery is already full without lost inverter energy inverterLostProdWatt = 0 else inverterLostEnergyProdFull = inverterLostEnergyProd inverterLostEnergyProd = 0 -- reset value to zero, because 'ProdFull' is used instead end elseif newSolarBatteryValue < 0 then --more energy consumed than available in battery --check if the battery is not already empty if solarBatteryValue > 0 then --first calculate the battery-used value (old value - 0) batteryUsedEnergy = solarBatteryValue end if emptyBatteryIsLostEnergy == 1 then -- also count lost energy due to empty battery --newLostEnergy = newSolarBatteryValue * -1 --(newSolarBatteryValue is negative, but it needs to be added UP to the counter) newLostEnergyEmpty = newSolarBatteryValue * -1 --(newSolarBatteryValue is negative, but it needs to be added UP to the counter) else --newLostEnergy = 0 end if emptyFullBatteryCountLostInverterEnergy == 0 then --battery is already empty without lost inverter energy, don't count (1 = count) inverterLostUsedWatt = 0 else inverterLostEnergyUsedEmpty = inverterLostEnergyUsed inverterLostEnergyUsed = 0 -- reset value to zero, because 'UsedEmpty' is used instead end --update battery level to zero newSolarBatteryValue = 0 else --new battery within bandwith of chosen battery capacity --check if energy from battery is consumed if energyBalance > 0 then batteryProdEnergy = energyBalance elseif energyBalance < 0 then --negative value means consumption batteryUsedEnergy = energyBalance*-1 --(energyBalance is negative, but it needs to be added UP to the counter) else --either no energy used or energy is returned end --newLostEnergy = 0 end domoticz.log('battery Used Energy = '..batteryUsedEnergy .. 'Wh',domoticz.LOG_DEBUG) domoticz.log('battery Prod Energy = '..batteryProdEnergy .. 'Wh',domoticz.LOG_DEBUG) domoticz.log('battery Lost Energy empty = '..newLostEnergyEmpty .. 'Wh',domoticz.LOG_DEBUG) domoticz.log('battery Lost Energy full = '..newLostEnergyFull .. 'Wh',domoticz.LOG_DEBUG) domoticz.log('inverter Lost Energy production = '..inverterLostEnergyProd .. 'Wh',domoticz.LOG_DEBUG) domoticz.log('inverter Lost Energy production when battery is full = '..inverterLostEnergyProdFull .. 'Wh',domoticz.LOG_DEBUG) domoticz.log('inverter Lost Energy usage = '..inverterLostEnergyUsed .. 'Wh',domoticz.LOG_DEBUG) domoticz.log('inverter Lost Energy usage when battery is full = '..inverterLostEnergyUsedEmpty .. 'Wh',domoticz.LOG_DEBUG) --calculate battery power, based on battery energy if batteryUsedWatt == nil then batteryUsedWatt = _.round (batteryUsedEnergy * (3600/deltaTime), 0) end if batteryProdWatt == nil then batteryProdWatt = _.round (batteryProdEnergy * (3600/deltaTime), 0) end --calculate lost energy power, based on lost energy if lostEnergyWatt == nil then lostEnergyWatt = _.round ((newLostEnergyFull + newLostEnergyEmpty) * (3600/deltaTime), 0) end --calculate lost inverter power, based on lost inverter energy if inverterLostEnergyUsedEmpty == nil then inverterLostEnergyUsedEmpty = 0 end if inverterLostEnergyProdFull == nil then inverterLostEnergyProdFull = 0 end if inverterLostUsedWatt == nil then inverterLostUsedWatt = _.round ((inverterLostEnergyUsed + inverterLostEnergyUsedEmpty) * (3600/deltaTime), 0) end if inverterLostProdWatt == nil then inverterLostProdWatt = _.round ((inverterLostEnergyProd + inverterLostEnergyProdFull)* (3600/deltaTime), 0) end ---update devices --update battery level with new value solarBattery.updateCustomSensor(_.round(newSolarBatteryValue / 1000,3)) --update battery usage with new value batteryUsage.updateP1(batteryUsage.usage1 + batteryUsedEnergy, 0, batteryUsage.return1 + batteryProdEnergy, 0, batteryUsedWatt, batteryProdWatt) --update lost energy with new value --lostEnergy.updateElectricity(_.round(newLostEnergy * (3600/deltaTime),0), _.round(lostEnergy.WhTotal + newLostEnergy + inverterLostEnergy,0)) lostBattery.updateP1(lostBattery.usage1 + newLostEnergyEmpty, 0, lostBattery.return1 + newLostEnergyFull, 0, lostEnergyWatt, 0) --update lost inverter energy with new value lostInverter.updateP1(lostInverter.usage1 + inverterLostEnergyUsed, lostInverter.usage2 + inverterLostEnergyUsedEmpty, lostInverter.return1 + inverterLostEnergyProd, lostInverter.return2 + inverterLostEnergyProdFull, inverterLostUsedWatt, inverterLostProdWatt) ---Update dzVents variables with the new meter values domoticz.data.returnedEnergy.add(newReturnedEnergyMeter) domoticz.data.consumedEnergy.add(newConsumedEnergyMeter) ::endScript:: end }
