DzVents script turning on dummy switches when power use is negative
Wilpshaar
Domoticz version: 2020.1
Post by Wilpshaar »
Who could help me out with a DZVents script for turning on dummy switches when power is negative? Seems blockly what I use can't work with negative numbers, don't get it work. Can someone create 2 Dummy switches called 'Dummy1' and 'Dummy2'. Then, if power is negative -750W switch on Dummy 1 and if power is negative -1500W switch on Dummy2. Of course is power becomes lower then -1500W Dummy2 should turn off and if lower then -750W Dummy1 should turn off. Who could help me out! ;-) Of course this is used for swithing on a 2-stage boiler. I power it on now telling power is <1 Watt and if solaredge is >1500W. But I want to be able to hImage[/img][/img]ave a simple script which can turn of 2 switches when power is -750 and -1500W (as example).
blockly example
blockly example
willemd
Domoticz version: 2026.3
Re: DzVents script turning on dummy switches when power use is negative
Post by willemd »
Blockly else-if is not really an else-if like you might be used to from other programming languages. Those else-if statements will all just be executed sequentially and tested. When true, the set statement will be executed.
So in the example:
Suppose power is -1000, then
First dummy1 will Not be switched on.
Second dummy2 will be switched on.
Third dummy one will be switched off.
Fourth dummy2 will Not be switched off.
So in the end dummy2 is on.
Is that what you want?
Suppose power is -500, then both dummy1 and dummy2 will be switched on (because > -750 and > -1500)
But if power is +500, then also they will both be switched on.
etc etc
So you need to add a few extra tests with and/or logic.
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I've setup quickly a simple script for you.
Not sure it will work, but give it a try.
Change the device number to your devices and try it.
local scriptVar     = '-=# Switch Hal #=-'
return
    on =
        devices =
            123,      -- Change the name to your device
    logging = { level = domoticz.LOG_INFO, -- change to domoticz.LOG_ERROR when all OK
                marker      = scriptVar
    execute = function(dz, device)
        local Stroom   = dz.devices(123) -- Change the name to your device
        local Dummy1   = dz.devices(234) -- Change the name to your device
        local Dummy2   = dz.devices(345) -- Change the name to your device
       if Stroom > -750 then
            Dummy1.switchOn().checkFirst()
            dz.log('Dummy 1 On', dz.LOG_FORCE)
        elseif Stroom > -1500 then
            dz.log('Dummy 2 On', dz.LOG_FORCE)
        elseif Stroom < -750 then
            Dummy1.switchOff().checkFirst()
            dz.log('Dummy 1 Off', dz.LOG_FORCE)
            dz.log('Dummy 2 Off', dz.LOG_FORCE)
            dz.log('Geen actie nodig ', dz.LOG_FORCE)
Wilpshaar
Post by Wilpshaar »
Thanks PAtrick, I just ready your reply now, I have the following now and see how it goes, will let you know,
Meaning should be;
If power use -250W turn on Dummy 1 (if more then -250 then switch off)
If power use -500W turn on Dummy 2 (if more then -500 then switch off)
This is for turning on or off 2 heating elements in a boiler, just how much power is consumed,
return
on =
devices =
Stroom, -- Change the name to your device
marker = scriptVar
local Stroom = dz.devices(Stroom) -- Change the name to your device
local Dummy1 = dz.devices(Dummy1) -- Change the name to your device
local Dummy2 = dz.devices(Dummy2) -- Change the name to your device
if Stroom > -250 then
elseif Stroom > -500 then
Dummy2.switchOn().checkFirst()
elseif Stroom < -250 then
Wilpshaar
Post by Wilpshaar »
HI PAtrick,
I am afraid nothing is happening? See nothing in the log, see no dummy switches changing, I could test when I remove the '-' (minus)
Thanks in advance, thanks for helping,
madpatrick
Wilpshaar wrote: Tuesday 20 September 2022 13:20 HI PAtrick,
Is the script being triggered by the device
Chamge otherwise the devicename for the IDX number
Please use CODE instead of image for script
Wilpshaar
Post by Wilpshaar »
HI Patrick, for testing I use in the evening now of course positive power consumption but we could check working of script. Bit more happening now, have error in log "<name > expected near '97'. Any idea? Thanks!
return
on =
devices =
97, -- Change the name to your device
marker = scriptVar
local 97 = dz.devices(97) -- Change the name to your device
local 944 = dz.devices(944) -- Change the name to your device
local 945 = dz.devices(945) -- Change the name to your device
if 97 > 250 then
944.switchOn().checkFirst()
elseif 97 >500 then
945.switchOn().checkFirst()
elseif 97 < 500 then
945.switchOff().checkFirst()
elseif 97 < 250 then
944.switchOff().checkFirst()
Wilpshaar
Post by Wilpshaar »
Here overview of names/IDX and log
madpatrick
Just a quick try
local scriptVar = '-=# TEST SCRIPT #=-'
        on      = { timer = {'every minute'},
        logging = { level  = domoticz.LOG_ERROR,
       		        marker = scriptVar
    local Stroom = dz.devices(94).WhActual  -- Change the name to your device
    local Dummy1 = dz.devices(944) -- Change the name to your device
    local Dummy2 = dz.devices(945) -- Change the name to your device
        dz.log('Stroom          :  ' .. Stroom ,dz.LOG_FORCE)
        dz.log('Dummy 1         :  ' .. Dummy1.state,dz.LOG_FORCE)
        dz.log('Dummy 2         :  ' .. Dummy2.state,dz.LOG_FORCE)
PLEASE use CODE for the script.
Otherwise it makes the thread unreadable
2022-09-20 19_57_54-(4) Domoticz - Post a reply.png (12.2 KiB) Viewed 2452 times
Last edited by madpatrick on Tuesday 20 September 2022 20:22, edited 1 time in total.
madpatrick
Wilpshaar wrote: Tuesday 20 September 2022 19:51 Here overview of names/IDX and log
Please copy/paste the text and an image
This not readable like this
Wilpshaar
Post by Wilpshaar »
Hi Patrick, looks better!
LOG:
2022-09-20 21:01:00.641 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Stroom : 460
2022-09-20 21:01:00.641 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 : On
2022-09-20 21:01:00.641 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 2 : Off
2022-09-20 21:01:00.642 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 On
Wilpshaar
Post by Wilpshaar »
       		        marker = scriptVar
    local Stroom = dz.devices(97).WhActual  -- Change the name to your device
    if Stroom > 500 then
    elseif Stroom > 1000 then
    elseif Stroom < 500 then
    elseif Stroom < 1000 then
        Dummy2.switchOff().checkFirst()
Wilpshaar
Post by Wilpshaar »
2022-09-20 21:08:00.211 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Stroom : 420
2022-09-20 21:08:00.211 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 : On
2022-09-20 21:08:00.211 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 2 : Off
2022-09-20 21:08:00.211 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 Off
Wilpshaar
Post by Wilpshaar »
2022-09-20 21:09:00.268 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Stroom : 1430
2022-09-20 21:09:00.268 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 : Off
2022-09-20 21:09:00.268 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 2 : Off
2022-09-20 21:09:00.268 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 On
Wilpshaar
Post by Wilpshaar »
       		        marker = scriptVar
    if Stroom > 250 then
        dz.log('Dummy 1 On > 250W', dz.LOG_FORCE)
        dz.log('Dummy 2 On > 1000W', dz.LOG_FORCE)
    elseif Stroom < 250 then
        dz.log('Dummy 1 Off < 250W', dz.LOG_FORCE)
        dz.log('Dummy 2 Off < 1000W', dz.LOG_FORCE)
Wilpshaar
Post by Wilpshaar »
I changed the log text a bit to understand and see what happens
Wilpshaar
Post by Wilpshaar »
I don't see the dummy2 switching on when power exceeds 1000W
2022-09-20 21:15:59.081 Status: boiler uitschakelen
2022-09-20 21:16:00.304 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Stroom : 1520
2022-09-20 21:16:00.304 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 : On
2022-09-20 21:16:00.304 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 2 : Off
2022-09-20 21:16:00.304 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 On > 250W
madpatrick
That is of the "elseif" function
Change it to "if"
       		        marker = scriptVar
Try to play with the script.
It is pretty easy and there are enough example or see : https://www.domoticz.com/wiki/DzVents:_ ... _scripting
Wilpshaar
Post by Wilpshaar »
HI Patrick, I think I am doing something wrong again, currently power is over minus 1200W
2022-09-21 10:08:05.841 ...cz/scripts/dzVents/generated_scripts/17_Test_DzVents.lua:39: unexpected symbol near '}'
2022-09-21 10:08:06.017 Error: dzVents: Error: (3.1.8) error loading module '17_Test_DzVents' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/17_Test_DzVents.lua':
2022-09-21 10:08:06.017 ...cz/scripts/dzVents/generated_scripts/17_Test_DzVents.lua:39: unexpected symbol near '}'
2022-09-21 10:08:15.835 EventSystem: Event triggered: 10_Electroboiler omvormer_1
2022-09-21 10:08:15.836 Status: boiler opwarmen
2022-09-21 10:08:15.784 Error: dzVents: Error: (3.1.8) error loading module '17_Test_DzVents' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/17_Test_DzVents.lua':
2022-09-21 10:08:15.784 ...cz/scripts/dzVents/generated_scripts/17_Test_DzVents.lua:39: unexpected symbol near '}'
2022-09-21 10:08:25.815 EventSystem: Event triggered: 10_Electroboiler omvormer_1
2022-09-21 10:08:25.816 Status: boiler opwarmen
2022-09-21 10:08:25.774 Error: dzVents: Error: (3.1.8) error loading module '17_Test_DzVents' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/17_Test_DzVents.lua':
       		        marker = scriptVar
    if Stroom > -1000 then
    if Stroom < -500 then
    if Stroom < -1000 then
madpatrick
See my previous post.
You are forgetting END after the IF function
This my log now:
2022-09-21 16:29:00.084 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Stroom : 923.758
2022-09-21 16:29:00.084 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 : Off
2022-09-21 16:29:00.084 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 2 : Off
2022-09-21 16:29:00.084 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 1 On > 250W
2022-09-21 16:29:00.084 Status: dzVents: !Info: -=# TEST SCRIPT #=-: Dummy 2 Off < 1000W
