Plugin SDM630-Modbus
Haacher
Post by Haacher »
Hello and good evening,
i'm new to the whole Domoticz topic and just finished setting up my Raspberry Pi 3B and the Domoticz Software. Now I wanted to connect the Eastron SDM630-Modbus with the Raspberry via the Modbus to USB Adapter as seen in this video I found. I don't know if this video is right about everything it says but since it worked out for me so far it doesn't really matter to me. My problem is that if I just run Domoticz all is fine, but when I add the plugin and create a device in the "Hardware" tab, Domoticz crashes and in the webpage it just shows me a grey background and also says offline in the URL. The output that I get in the console when starting Domoticz via console is below.
I don't know if this is the place for this topic. Please correct me if I'm wrong.
Thank you in advance,
Haacher
log.txt
The output of the console
(57.31 KiB) Downloaded 81 times
monette999
Re: Plugin SDM630-Modbus
Post by monette999 »
Hello Forum
It looks to me as well that the Eastron SDM 630 Plugin is faulty in the value of current. It does not
Display the same value as on the meter directly.
Look at current and power L1
