Upload gas usage to mindergas.nl  [Solved]
jvdz
Domoticz version: 4.107
Re: Upload gas usage to mindergas.nl
Post by jvdz »
Are you running this as a DzEvents script?
mvveelen
Post by mvveelen »
Yes, I tried. But saving scripts gives me a "save error" so I prefer to use a bash script.
I also tried the slave-master construction, but I keep getting errors because I use an RPi 3B+ and a Synology with Domoticz in Docker.
jvdz
Post by jvdz »
It is an DzEvents script as you can see in the scriptsource, so will not work in any other way!
/home/pi/domoticz/scripts/dzVents/scripts/upload_gas_usage_to_minderGas.lua
Upper78
Domoticz version: V4.10228
Post by Upper78 »
Hi mvveelen,
I just tested with your script, and the only thing that needs to be changed is the URL from mindergas.
This has changed. Change line 40 to https://www.mindergas.nl/api/meter_readings as the url, and it works.
sincze
Domoticz version: 2024.4
Post by sincze »
As my experience with dZVents is 0,0 and the and the wiki described a version with special tools required in BASH I had to give it a small different BASH twist for 2 house holds that wanted to have this done.
Best Practices:
- No mindergas key in the main script but in separate config file.
- Needs no special tools or apt-get installs
Find the mindergas.sh here.
https://github.com/sincze/bash/blob/main/mindergas.sh
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Derik
Post by Derik »
MM Hi..
Oud topic..
maar ik gebruikt eerst een ander script wat niet meer werkt na een nieuw armbian installatie.
Welk script werkt nu goed?
En uploaden jullie alleen gas? Of ook KWH/2 als zijnde gas, voor een wp verbruik [ de oude api ]
Nieuw is wel Kwh maar ik zoek eigen de /2 versie
En natuurlijk de kwh versie altijd welkom
njlammerts
Domoticz version: 2022.2
Post by njlammerts »
I used the script from Sándor Incze because this seems to be the latest (2023) script for uploaden to Mindergas.nl. The older scripts give an arror "meterstand is geen getal"
The script from Sándor runs ok, but i get ( a simular message) "Error no value!" as result.
Does anyone has a solution?
HvdW
Domoticz version: 2023.2
Post by HvdW »
Here is a script that should work.
jq is the ingredient that you need.
#!/bin/bash
# LET OP
# METERSTAND check your domoticz port and domoticz idx (rid) for gas
# check your mindergas token
# LET OP
#Token to authenicate with mindergas.nl
TOKEN=your token
#fetch meterstand (use jq to parse JSON object correctly)
METERSTAND=`curl -s "http://127.0.0.1:8383/json.htm?type=devices&rid=16" | jq '.result[0].Counter'| tr -d '"'`
#Get OS date, and format it corectly.
NOW=$(date +"%Y-%m-%d")
#Build JSON by hand 😉
JSON='{ "date":"'$NOW'", "reading":"'$METERSTAND'" }'
#post using curl to API
curl -v -H "Content-Type:application/json" -H "AUTH-TOKEN:$TOKEN" -d "$JSON" https://www.mindergas.nl/api/meter_readings
# don't forget:
# https://ehoco.nl/stand-gasmeter-uploaden-naar-mindergas-nl/
# sudo apt install jq -y
and in crontab for a daily upload.
58 23 * * * /home/pi/scripts/mindergas-upload.sh
Bugs bug me.
njlammerts
After the update to Domoticz 2025.05 the update to mindergas does not work anymore
when running the mindergas.sh manually I get " Error no value!"
Does anyone know what could be the reason?
njlammerts
njlammerts wrote: Tuesday 13 May 2025 10:59 After the update to Domoticz 2025.05 the update to mindergas does not work anymore
Does anyone know what could be the reason? it has been running for 1.5 year without a problem
mindergas.sh:
# Config file in here
source /home/pi/domoticz/scripts/system/config
TOKEN=$MINDERGAS_API
IDX=$GAS_IDX
#fetch meterstand
METERSTAND=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://$DOMOTICZ_IP:$DOMOTICZ_PORT/json.htm?type=devices&rid=$IDX" | /bin/grep '"Co$
if [ $METERSTAND ] ; then
# echo $METERSTAND
# NOW=$(date --date="yesterday" +"%Y-%m-%d")
#Build JSON by hand ;-)
exit
echo "Error no value!"
fi
Config file:
# CONFIG FILE that will be used in BASH scripts
# Is placed in DIR_SCRIPTS directory
DEBUG="true"
DIR_TEMP="/var/tmp"
DIR_LOG="/var/log"
DIR_SCRIPTS="/home/pi/domoticz/scripts/system"
DOMOTICZ_IP="172.16.10.248"
DOMOTICZ_PORT="8080"
MINDERGAS_API="blabla12345"
GAS_IDX="694"
jvdz
Post by jvdz »
This line is wrong: type=devices&rid=$IDX" | /bin/grep '"Co$
That needs to follow the new API structure:type=command&param=getdevices&rid=$IDX" | /bin/grep '"Co$
See: https://wiki.domoticz.com/Domoticz_API/ ... fic_device
njlammerts
The line which was copied, was not complete (my mistake) . It is:
METERSTAND=`curl -s --connect-timeout 2 --max-time 5 "Accept: application/json" "http://$DOMOTICZ_IP:$DOMOTICZ_PORT/json.htm?type=command&param=getdevices&rid=$IDX" | /bin/grep '"Counter" :' | awk {'print $3'} | /usr/bin/cut -d '"' -f 2`
But the reply from jvdz was good enough for me to change the line, and it seems to work when I execute manually..
Big Thanks !!!
