Upload gas usage to mindergas.nl  [Solved]
roblom
Post by roblom »
So this is my first dzvents script ever, what do you think of it? Please give some feedback.
It collects the gas usage from the smartmeter and uploads it to the mindergas.nl database.
 /home/pi/domoticz/scripts/dzVents/scripts/upload_gas_usage_to_minderGas.lua
 Author 		: Roblom
 Description 	: This script collects the gas values from Domoticz (for example from the smart meter) and uploads the values to a MinderGas account.
			For more information about MinderGas, see the API instructions on their website on https://mindergas.nl/member/api
local AUTH_TOKEN = 'xxxxxxxxxxxxxx'	 -- Fill in here your Mindergas authentication token
	active = true,
		--timer 			= {'at 00:05'},
		timer 			= {'every minute'},
		httpResponses 	= {'UploadToMindergas'}
	logging =	{
		level	=	domoticz.LOG_DEBUG,
		marker	=	'Mindergas'
        if item.isTimer then
			local GasUsageCounter 	= domoticz.devices('Gas (P1)').counter
			local TodaysDate 		= tostring(domoticz.time.rawDate)
			domoticz.log('The gas usage is ' .. GasUsageCounter, domoticz.LOG_INFO)
			domoticz.log('The date is ' .. TodaysDate, domoticz.LOG_INFO )
			domoticz.openURL({
				url = 'https://www.mindergas.nl/api/gas_meter_readings',
				method = 'POST',
				headers = {
					['Content-Type']	= 'application/json',
					['AUTH-TOKEN']		= AUTH_TOKEN
				callback = 'UploadToMindergas',
				postData = {
					['date']			= TodaysDate,
					['reading']			= GasUsageCounter
        elseif (item.isHTTPResponse) then
			if (item.statusCode == 201) then
				domoticz.log('Gas usage data is sucessfully upoaded to Mindergas.nl.', domoticz.LOG_INFO)
				if (item.statusCode == 401) then
					domoticz.log('There was an authorisation problem with the Mindergas.nl database.', domoticz.LOG_ERROR)
				if (item.statusCode == 422) then
					domoticz.log('There was an unprocessable enrty while trying to upload the gas usage data to Mindergas.nl', domoticz.LOG_ERROR)
				domoticz.notify('Domoticz error', 'An error occured while trying to upload the gas usage data to Mindergas.nl', PRIORITY_NORMAL)
Re: Upload gas usage to mindergas.nl
roblom wrote: Sunday 19 May 2019 20:02 So this is my first dzvents script ever, what do you think of it? Please give some feedback.
@robblom, my compliments; looking good.
some small not important remarks:
You included your Mindergas authentication token as plain text in your script. What you could do is to put the token in a domoticz uservariable and read that during the execution of the script. In that way the token is not direct readable n the script. You could even make it really fancy if you store the key encoded en decode it during execution. Many examples to encode / decode in Lua can be found on the internet.
is excellent. Could be replaced by
if item.ok then -- self.statusCode >= 200 and self.statusCode <= 299
to test for a more generic statsusCode to reflect success.
You use the string "trigger" to trigger the script on the openURL callback. If you develop more scripts you might want to use a more distinctive name.
roblom
Post by roblom »
Thanks for the compliments, it's not that complicated script but was a good example to learn dzVents. As I'm no programmer at all I'm learning through trial and error but have good autodidact skills and dzVents is quite easy to learn.
About the authentication token, I removed it from the above example, thanks for pointing out.
but putting it in a user variable is of course an option, but would this be a real advantage in security purpose? Because a user variable is also readable in domoticz GUI itself.
The statusCode that are described in the mindergas API are only 201, 401 and 422 so therefore I only put in those. If the status is not 201, 401 or 422 there will be send a notification for extra attention.
The 'trigger' name is indeed not that distinctive, changed that to 'UploadToMindergas'.
Again, thanks for the feedback, quite useful!
roblom wrote: Sunday 19 May 2019 22:41 but putting it in a user variable is of course an option, but would this be a real advantage in security purpose? Because a user variable is also readable in domoticz GUI itself.
True if you edit and save your scripts via the internal event editor. I am used to an external editor and do not store my scripts in the database. So if you encrypt / decrypt the value in the uservariable, users with access to the gui and without access to the OS file system would not be able to see the decrypted api-key; but I doubt if there is a really secure way to handle a situation where the api-key need to be part of the url.
roblom
Post by roblom »
I also use a external editor (Notepad++). As I don't find it a big security issue, I leave it as it is for now. Thanks for your feedaback.
EdwinK
Post by EdwinK »
Looks great, but
2019-05-21 08:36:01.238 Status: dzVents: Info: Handling httpResponse-events for: "UploadToMindergas
2019-05-21 08:36:01.238 Status: dzVents: Info: Mindergas: ------ Start internal script: Minder Gas: HTTPResponse: "UploadToMindergas"
2019-05-21 08:36:01.238 Status: dzVents: Error (2.4.21): Mindergas: HTTP/1.1 response: 422 ==>> Unprocessable Entity
2019-05-21 08:36:01.238 Status: dzVents: Error (2.4.21): Mindergas: There was an unprocessable enrty while trying to upload the gas usage data to Mindergas.nl
2019-05-21 08:36:01.238 Status: dzVents: Info: Mindergas: ------ Finished Minder Gas
2019-05-21 08:37:00.582 Status: dzVents: Info: Mindergas: ------ Start internal script: Minder Gas:, trigger: every minute
2019-05-21 08:37:00.582 Status: dzVents: Info: Mindergas: The gas usage is 1184.658
2019-05-21 08:37:00.582 Status: dzVents: Info: Mindergas: The date is 2019-05-21
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: url = https://www.mindergas.nl/api/gas_meter_readings
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: method = POST
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: post data = {"date":"2019-05-21","reading":1184.658}
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: headers = {["Content-Type"]="application/json", ["AUTH-TOKEN"]="WdC_oA8VqqLjB6ijYmzC"}
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: callback = UploadToMindergas
2019-05-21 08:37:00.587 Status: dzVents: Info: Mindergas: ------ Finished Minder Gas
EdwinK
Post by EdwinK »
It seems the meter is updated at mindergas.nl, just throwing an error in the logs.
EdwinK wrote: Tuesday 21 May 2019 8:46 It seems the meter is updated at mindergas.nl, just throwing an error in the logs.
Could it be that this entry is already at mindergas ? That would also generate this returnCode
roblom
Post by roblom »
waaren wrote: Tuesday 21 May 2019 10:56
That is correct, the 422 error is
422 Unprocessable Entity
Er is een validatiefout opgetreden. Dit kan komen door:
Er is al een meterstand voor de opgegeven datum.
De meterstand is geen getal.
De meterstand is kleiner dan de vorige meterstand.
De meterstand is groter dan de volgende meterstand.
De datum ligt in de toekomst.
De datum ligt voor 31 december 2005.
So if you say the data is uploaded in the mindergas database then the 422 error is because you try to put in the same values that are already in. So when you change the script to that it is only running once a day, you have no errors anymore.
EdwinK
Post by EdwinK »
Okay. Will change the script to run less often. Thanks
HvdW
Domoticz version: 2023.2
Post by HvdW »
And can you upload the finished script too?
It's very interesting.
To get results that can be compared over the years (I'm on mindergas since 2013) I will upload it once a moth and as from now it'll be automagic upload!
Bugs bug me.
maxtrash
Post by maxtrash »
Thanks, works like a charm.
BOverdevest
Domoticz version: 4.11307
Post by BOverdevest »
maxtrash wrote: Thursday 24 October 2019 0:39 Thanks, works like a charm.
indeed and thanks for pushing this topic to the top again, or I would have missed this one...
HUE, Tradfri, Zwave, RFXCOM, rooted TOON, PS4
jandahmen
Post by jandahmen »
pls publish the last good working script, so we can learn too. regards jan dahmen
BOverdevest
jandahmen wrote: Tuesday 29 October 2019 18:29 pls publish the last good working script, so we can learn too. regards jan dahmen
See post #1, worked for me, with some adjustment to make it work on my system.
 Author 		: Roblom
	active = true,
		--timer 			= {'every minute'},
		httpResponses 	= {'UploadToMindergas'}},
	logging =	{	level	=	domoticz.LOG_ERROR, marker	=	'Mindergas'	},
			local GasUsageCounter 	= domoticz.devices('P1GasMeterStand').counter
			domoticz.openURL({
				method = 'POST',
				headers = {
				postData = {
            local SubSystem   = domoticz.NSS_TELEGRAM
            local Priority      = domoticz.PRIORITY_NORMAL
            local Sound         = domoticz.SOUND_DEFAULT
            local Tittle        = "MinderGas - "
			local Message       = "Geen idee :" .. item.statusCode
			if (item.statusCode == 201) then Message ='Gas usage data is sucessfully upoaded.'
			    elseif (item.statusCode == 401) then Message = 'There was an authorisation problem with the Mindergas.nl database.'
			    elseif (item.statusCode == 422) then Message = 'There was an unprocessable enrty while trying to upload the gas usage data to Mindergas.nl'
			domoticz.log(Message, domoticz.LOG_INFO)
			domoticz.notify(Tittle,Message,Priority,Sound,"",SubSystem)
De volgende HTTP status codes worden geretourneerd:
201 Created
De meterstand is succesvol verwerkt en opgeslagen.
401 Unauthorized
Het authenticatietoken is ongeldig of zit niet in de request.
Akerboom
Post by Akerboom »
thanks for the script! :)
dutchronnie
Post by dutchronnie »
I do use this script some time without any problems.
But since a few days the readings are not uploaded anymore, and do i get the this error
I didn't change anything, but is is not working anymore.
Does sombody know what the problem could be?
 Author 		: Roblom
local AUTH_TOKEN = 'KKgjpoiJJeJPG'kjhgf'	 -- Fill in here your Mindergas authentication token
	active = true,
	logging =	{
			domoticz.openURL({
				method = 'POST',
				headers = {
				postData = {
dutchronnie wrote: Tuesday 17 November 2020 15:27 "An error occured while trying to upload the gas usage data to Mindergas.nl',"
If you insert below line directly after line 61 it will show some potential useful information
domoticz.log(item, domoticz.LOG_FORCE)
dutchronnie
Re: Upload gas usage to mindergas.nl  [Solved]
I added the line in the script, i hope i can see it tommorow.
I found the following rules in the log file from domoticz
2020-11-15 00:03:01.237 Error: dzVents: Error: (3.0.16) Mindergas: HTTP/1.1 response: 401 ==>> Unauthorized
2020-11-15 00:03:01.238 Error: dzVents: Error: (3.0.16) Mindergas: There was an authorisation problem with the Mindergas.nl database.
2020-11-16 00:05:01.755 Error: dzVents: Error: (3.0.16) Mindergas: HTTP/1.1 response: 401 ==>> Unauthorized
2020-11-16 00:05:01.755 Error: dzVents: Error: (3.0.16) Mindergas: There was an authorisation problem with the Mindergas.nl database.
2020-11-17 00:05:01.694 Error: dzVents: Error: (3.0.16) Mindergas: HTTP/1.1 response: 401 ==>> Unauthorized
2020-11-17 00:05:01.694 Error: dzVents: Error: (3.0.16) Mindergas: There was an authorisation problem with the Mindergas.nl database.
Authorisation problem, strange. i checked the api, but it is alright.
On mindergas i can add the values to the database by hand, so there is nothing wrong with the database.
alpafranken
Post by alpafranken »
dutchronnie wrote: Tuesday 17 November 2020 19:23 I added the line in the script, i hope i can see it tommorow.
The problem is your local AUTH_TOKEN = 'KKgjpoiJJeJPG'kjhgf' your token has an ' in it which causes the variable to malfunction.
