Smart Meter P1 actual usage Fase1, Fase2, Fase3 to Daily total KW
Domoticz version: 2025.1
Re: Smart Meter P1 actual usage Fase1, Fase2, Fase3 to Daily total KW
Did you give multiple devices the same name eg L1C ? DzVents cannot handle that so you have rename those to unique names.
fortissimo
Post by fortissimo »
Every device is unique in its name.
Then it looks like you have a type error somewhere. For example I do not see "upvalue 'L1C'" mentioned.
Perhaps you have missed a comma or bracket.
DuDo
Post by DuDo »
i get
2022-07-27 10:10:46.772 Error: dzVents: Error: (3.1.8) kWh estimated values: An error occurred when calling event handler CalculateKWHusedL1L2L3
2022-07-27 10:10:46.772 Error: dzVents: Error: (3.1.8) kWh estimated values: ...pts/dzVents/generated_scripts/CalculateKWHusedL1L2L3.lua:90: attempt to concatenate a nil value (field 'counter')
but where is the original script?
