Mitsubishi/Panasonic airco
Dave47
Domoticz version: 2023.1
Post by Dave47 »
Is it possible to add a Mitsubishi or Panasonic air conditioner to hardware.
We do see the possibility for a Daikin
Or is there another method to build this in Domoticz?
FireWizard
Re: Mitsubishi/Panasonic airco
Post by FireWizard »
Someone has to write a plug-in and that is not a quick job. So that will take at least some time.
I don't know, whether the Panasonic AC and the Mitsubishi AC have the same API or Cloud service.
A few month ago, I have been working to integrate a Panasonic AC Cloud service into Domoticz.
See: https://www.domoticz.com/forum/viewtopi ... =Panasonic
Unfortunately this project has never been finished as the user stopped responding. Do not know why.
If this is something you want to try, I will be happy to support you and to continue this project.
joto
Domoticz version: 3.5478
Post by joto »
I have integrated my Panasonic in Domoticz using the thread FireWizard referring to as inspiration.
FlyingDomotic
Post by FlyingDomotic »
For Mitsubishi, you may use Wemos D1 with https://github.com/SwiCago/HeatPump on you heat pumps and https://github.com/Masurov/Domoticz-Mit ... QTT-Plugin on Domoticz size. List of confirmed working hardware can be found at https://github.com/SwiCago/HeatPump/issues/13
sdamasoc
Post by sdamasoc »
If someone is interested I made a plugin using the panasonic cloud comfort api to control my 3 AC units:
https://github.com/sdamasoc/domoticz_pa ... _CZ-TACG1/
Derik
Post by Derik »
Edit:
Sorry did not read airco :oops: :oops:
Headpump..
For Panasonic use:
https://github.com/Egyras/HeishaMon
Much better then pana cloud.
More options and open source, without very expensive pana cloud box [ i have 1 for sale ]
Help topic:
https://gathering.tweakers.net/forum/li ... /2039112/0 [ dutch ]
Nodered and plugin to use all the functions
Thuis
Post by Thuis »
FlyingDomotic wrote: Tuesday 01 September 2020 23:19 For Mitsubishi, you may use Wemos D1 with https://github.com/SwiCago/HeatPump on you heat pumps and https://github.com/Masurov/Domoticz-Mit ... QTT-Plugin on Domoticz size. List of confirmed working hardware can be found at https://github.com/SwiCago/HeatPump/issues/13
Hello i have a silly question.
Is this only for heatpumps? Or is it also for an AC? Like an mhi SRK xx ZSX-S ?
Thanks in advance.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
FlyingDomotic
You may use it for lot os Mitsubishi AC and heat pumps. Personally, I use them for 4 different AC models.
Full list is at https://github.com/SwiCago/HeatPump/issues/13
Thuis
Post by Thuis »
FlyingDomotic wrote: Wednesday 29 June 2022 20:23 You may use it for lot os Mitsubishi AC and heat pumps. Personally, I use them for 4 different AC models.
What are the AC models you use? Ive seen the lists, but theyre all heatpump numbers
AimoPaukku
Domoticz version: Stable
Post by AimoPaukku »
nevermind...
Last edited by AimoPaukku on Saturday 01 October 2022 15:52, edited 1 time in total.
efarmer1
Post by efarmer1 »
is this not a HTTP command thing, istead of mqtt.
