.countertoday in dzvents
Andyyyy
Post by Andyyyy »
Hi !
I want to use "x.counterToday" in dzvents to display the actual daily runtime of a device in an external system.
		timer = {
			'every minute',
		logging = {
        level = domoticz.LOG_INFO,
        marker = "TMR"
	execute = function(domoticz, timer)
		domoticz.log('CL dosierung (TMR): '..domoticz.devices('$Pool CL dosierung (TMR)').counterToday, domoticz.LOG_INFO)
In the Webinterface and the Json output display the Value "0" but dzvents diplays the last value from yesterday until a new value is set.
Does someone know where the bug is ?
Domoticz version: 2026.3
Re: .countertoday in dzvents
I can confirm that behavior. I have two counters (solarpanel generation) that I summarize in a total counter. And I see that one of these solarpanel counters is reset only when a new value is written to the counter, normally the next morning after sunrise. The other counter is reset at midnight. probably by the plugin that is controlling it.
Andyyyy
Post by Andyyyy »
Now i have a solution that work for me. Simply set the counter with the actual value once at the beginning of the day,
		timer = {
				'at 00:01',
	domoticz.devices('$Pool CL dosierung (TMR)').updateCounter(domoticz.devices('$Pool CL dosierung (TMR)').counter)
