GarbageCalendar (new version) lua scripts
Re: GarbageCalendar (new version) lua scripts
Garbagecalendar has worked flawless for more than a year. Suddenly, a few weeks ago (don’t know exactly) the data now contains back slashes and new lines where they don’t belong
The myGarbageDevice in domoticz looks like this:
plastic-\, fruit- en tuinafval
: 10 5 2022
groente-\, fruit- en tuinafval
:13 5 2022
oud papier & karton
: 14 5 2022
I am using afvalkalender.cyclusnv.nl with websitemodule = "m_opzet" I’ve checked the website with webbrowser and everything seems normal.
garbagecalendar_run_m_opzet.log says the sript can't find can't interpret the website data. I have created additonal lines in the garbagetype_cfg table reflecting the changed data, like this:
["plastic\\, metaal en drankenkartons"] ={hour=07,min=02,daysbefore=1,reminder=0,text="plastic and metalwaste"},
["groente-\\, fruit- en tuinafval"] ={hour=07,min=02,daysbefore=1,reminder=0,text="vegetable fruit and gardenwaste"},
["oud papier & karton"] ={hour=07,min=02,daysbefore=1,reminder=0,text="old paper and karton"},
Unfortunately that didn't help. Does anybody else have/had this same issue?? Is there a way to solve this??
thanks in advance!
: 10 5 2022
:13 5 2022
oud papier & karton
: 14 5 2022
thanks in advance!
Did you try to update GarbageCalendar with the latest files? There are a few files updated so maybe the problem is solved after this.dimple64 wrote: ↑Monday 02 May 2022 21:48 Garbagecalendar has worked flawless for more than a year. Suddenly, a few weeks ago (don’t know exactly) the data now contains back slashes and new lines where they don’t belong
: 10 5 2022
:13 5 2022
oud papier & karton
: 14 5 2022
thanks in advance!
- jvdz
- Domoticz version: 4.107
I would have to test with this to see what is happening. Could you PM me your garbagecalendarconfig.lua so I can use that to test?
Thanks,
Jos
Yes I did, upgraded after the issue occured. No solution:(mikeoo wrote: ↑Tuesday 03 May 2022 6:55Did you try to update GarbageCalendar with the latest files? There are a few files updated so maybe the problem is solved after this.dimple64 wrote: ↑Monday 02 May 2022 21:48 Garbagecalendar has worked flawless for more than a year. Suddenly, a few weeks ago (don’t know exactly) the data now contains back slashes and new lines where they don’t belong
: 10 5 2022
:13 5 2022
oud papier & karton
: 14 5 2022
thanks in advance!
- jvdz
Correct.. in this case the m_opzet_api module works fine, but the m_opzet module get's a backslash character in the garbagetype back from the website, which is an issue to handle.
There is now a Develeopment version available which simply removes any \ characters from the garbagetype, as those really shouldn't be in there to begin with.
Sorry it is working, i didnt read the manual in github wiki
Sorry, but I'm a Noob about this.
I was trying to use this feature, but i can't figure out what mi doing wrong.
i did go to the jvanderzande / GarbageCalendar
First i had a virtual text object with the name: 'Afval Kalender' and idx 31
i go to Setup\more Options\events
i create a new 'Lua' "all commented' script and called 'garbagecalendarconfig.lua'
i fill in the next 3 lines:
myGarbageDevice = 'Afval Kalender' -- The Text devicename in Domoticz. eg 'Container'
Zipcode = '2513BN' -- Your zipcode eg '1234AB' --
Housenr = '8' -- Your housnr. eg '99'
i create a new 'Lua' "all commented' script and called 'script_time_garbagewijzer.lua'
without any changes
i create a new 'Lua' "all commented' script and called 'm_mijnafvalwijzer.lua'
without any changes
I understand the name of the scripts are important, but I'm not sure if i also have to add '.lua' or not to the script name.
error from logs
2022-06-06 16:39:27.142 Error: EventSystem: Lua script script_time_garbagewijzer.lua did not return a commandArray
2022-06-06 16:39:27.149 Error: EventSystem: Lua script garbagecalendarconfig.lua did not return a commandArray
- Target OS: -
Hello Jos,
I've implemented the latest version of your garbageCollector scripts. I'm wondering about the fact the script runs every minute. The information the script grabbes isn't far away for updating once every minute. And running the script slow downs my PI because it's very
I think once an hour is good enough.
Do you have possibilities to run the script once an hour ?
Wich changes do applie into your scripts ?
Thanks for responding Jan
Rob
Rob
- jvdz
The script runs each minute as it's purpose id to send you the Notification at the requested time so needs to run every minute, but it will hardly take any time to process as the real heavy lifting, the collection of the WebData, is done once a day and done in the background not burdening the Domoticz single threaded event system.
.. so I am wondering what you are seeing that is worrying you?
Jos
Jos
i get this error
2022-08-13 20:43:00.725 Error: LUA: 20:43:00 MainScript: #### Error: 0 data records, updated at Sat Aug 13 20:43:00 2022 from datafile:/var/tmp/garbagecalendar_m_mijnafvalwijzer.data
can someone help me to sloved this error
- jvdz
Sure .... did you check out the steps in the Wiki? https://github.com/jvanderzande/Garbage ... ki/Testing
The Webmodule hasn't been able to retrieve the data so that's the log to check first!
Whre can i find garbage.data?jvdz wrote: ↑Sunday 14 August 2022 9:39Sure .... did you check out the steps in the Wiki? https://github.com/jvanderzande/Garbage ... ki/Testing
- jvdz
5th line in the Wiki?
So as indicated you probably need to check the last log file in that list as that should contain the nightly update information.In case you have issues with your setup you can do the following steps described below. When you still can't figure out the issue you have, you can also zip up the below defined log & data files and your garbagecalendarconfig.lua file and Email them to my GitHub Email address so I can check what is happening.
Check first your logfiles.
Check these files exist in the directory your defined in garbagecalendarconfig.lua in variable datafilepath whether they exist and/or contain errors:
garbage.data => the file containing the result of the webupdate process by the module.
garbage_run_modulename.log => log of the last time the script was ran
garbage_run_update_modulename.log => log of the last time the script ran the update process
garbage_web_modulename.log => log of the backgroung webupdate process.
- Domoticz version: 4.10xxx
Hi jvdz,
Thanks for the hard work...
Just leaving a note for other people in heiloo, uitgeest or castricum when they realise the gemeent has moved away from mijnafvalwijzer to mijnafvalzaken.nl in case they search for these terms
they can use the script m_opzet and use mijafvalzaken.nl as hostname
- jvdz
I am busy making a few changes to garbagecalendar to:
I will make the code available in the Github Development branch somewhere in the next few days.
Jos
- Allow the script to run in both LUA Time event as well as DzVents
- Added standard notification script that can do Event action in Domoticz when a notification is happening. Eg switch on a light in a particular color for a period. This again supports both commandArray[] as DzVents commands like domoticz.devices(lamp).setLevel(100)
This script can be modified to your needs for easy integration. - scriptpath variable is removed from the config an determined by the script itself.
Jos
- Rolandet
- Domoticz version: 2021.1
Little late, but I can do some testing if you like, but just for the classic setup (no dzvents)jvdz wrote: ↑Wednesday 04 January 2023 16:52 I am busy making a few changes to garbagecalendar to:Any takers that like to test a development version to ensure things are working in the different environments?
This script can be modified to your needs for easy integration.- scriptpath variable is removed from the config an determined by the script itself.
Jos
At the moment my scripts isn't working, so I'm fine with some alterations if needed.
Custodes Septentrionum
Same here, RMN chenged their app, now de API isn't accessible anymore. The data is somewhere out there, does somebody have a solution?
- jvdz
What exactly isn't working with the current GarbageCalendar (Master)?
The Development version of the new version is currently available in the Development branch on github.
There is no module for RMN as yet in my GarbageCalendar setup and a quick search tell me they moved and there is no information available yet of which API to use to get the data. When it is know it should be possible to make that module.
Jos
- Rolandet
Hi Jos.jvdz wrote: ↑Sunday 05 March 2023 14:42What exactly isn't working with the current GarbageCalendar (Master)?
Jos
For Omrin, the data just isn't coming in anymore.
garbagecalender_m_omrin.data:
-- Table: {1}
What's the best way to install the dev branche?
- jvdz
Maybe first start with updating your setup to the latest version as I did commit an update for OMRIN:
Jos
garbagecalendar - fixed omrin since their website is changed. it now uses an API like HA 2 weeks ago
- Rolandet
Ha ! I thought that may be a part of your new branchjvdz wrote: ↑Sunday 05 March 2023 15:31 Maybe first start with updating your setup to the latest version as I did commit an update for OMRIN:JosCode: Select all
it's been quite a while. Just follow the initial setup instructions ? (copy files e.a. and save my garbagecalendarconfig.lua)
