Dashticz dial
droepie
Dashticz dial
I have to be honest and say that I wasn't really actively using Domoticz for the last 2 years. I had switched to Home Assistant. Nevertheless, I decided to download the latest release of Domoticz. Then when Aurora didn't work I started to investigate and in the process I also stumbled upon Dashticz. And I find that fantasticz although I have made a very nice dashboard in Home Assistant with a map of my house on which also the lights come on in the right color and open doors are visible.
However, now I run into two problems with Dashticz at the moment:
The first is the language. In my dials the texts for the wind and Evohome are still in English while in the config I specified 'NL-nl'. I saw that more people had encountered this but I can't find the solution in the large amount of answers. Have I forgotten to do something or is there a bug here?
The second one also concerns the nice dial buttons.I also use them for Hue color lights, but I have not seen the possibility to adjust the color via a popup in the dial. I have created a separate traditional button for that and it is not as nice. Is there another way to do this and through the dial? Or should I wait and submit a request for a next relay?
And I'm sorry if I opened a new topic if this was already discussed but I could not find it.
download/file.php?mode=view&id=28079
- Example of wrong text
- 2022-03-17 17_34_52-Dashticz.png (48.1 KiB) Viewed 1971 times
Lokonli
Re: Dashticz dial
Currently the Evohome dials are in English only: no translations have been made.
Dashticz already contains translation mechanisms, so it will not be too much work to add it.
I'll add it to the request list.
Could you send me the Dutch translations?
For the RGB dial:
The center part currently works as a toggle to switch on/off the light.
I can add a block parameter to open the the color selection window instead.
I'll add that to the list as well.
For the RGB dial:
Lokonli
Re: Dashticz dial
Added in latest beta version.droepie wrote: Thursday 17 March 2022 17:39 I have to be honest and say that I wasn't really actively using Domoticz for the last 2 years. I had switched to Home Assistant. Nevertheless, I decided to download the latest release of Domoticz. Then when Aurora didn't work I started to investigate and in the process I also stumbled upon Dashticz. And I find that fantasticz although I have made a very nice dashboard in Home Assistant with a map of my house on which also the lights come on in the right color and open doors are visible.
See:
https://dashticz.readthedocs.io/en/beta ... notes.html
(wind translations still open)
droepie
Re: Dashticz dial
Sorry, I did not see the questions were answered. I'm used to Home Assistant where you get an e-mail when someone responded. Thank you for the quick response
According to the Honeywell display the translation in Dutch should be:
Auto = Auto
Economy = Eco
Away = Afwezig
Custom = Vakantie (although that doesn't mean exactly the same) Aangepast (is better but does'nt show on my display)
Day Off = Vrije dag
Off = Uit (or on the display 'Verwarming uit' but that is maybe to long)
The translations for the wind are already in the translation table I found in Dashticz. For both SSE (= ZZO) and SouthEast (= ZuidOost)
Auto = Auto
Economy = Eco
Away = Afwezig
Day Off = Vrije dag
droepie
Re: Dashticz dial
Thanks for the rapid change. Only one thing that could be better. In the Netherlands we use 'Eco' rather then 'Economie' in case of something being in a mode that is less spilling with resources. (In this case the dial for EVOHOME).
- madpatrick
- Domoticz version: 2026.1
Re: Dashticz dial
Hi Lokonli
I noticed that the hidden Off level is show on the dial
You have the option with a selecto to hide the Off level (first option). This is then hidden in Domoticz, but not in my Dial selector
martinvandenhurk
Re: Dashticz dial
I was always afraid of discovering new possibilities with Domoticz, but I have come to love Dashticz.
Also because a great community platform helps others:
I can't get numbers in the right DIAL, how can this be added?
- Schermafbeelding 2022-09-25 om 11.33.44.png (369.61 KiB) Viewed 1704 times
Lokonli
Re: Dashticz dial
It's displayed as an OnOff dial. Is that intentional?martinvandenhurk wrote: Sunday 25 September 2022 11:40 I was always afraid of discovering new possibilities with Domoticz, but I have come to love Dashticz.
Can you show your block definition for the right dial?
martinvandenhurk
Re: Dashticz dial
it's not meant to be a on/off switch, if you click the button, the corresponding graph pops-up
i prefer the same layout as the other two
definition is:
definition is:
- Spoiler: show
- HansieNL
Re: Dashticz dial
Can you post the outcome of:
This will give an overview of the SolarEdge device.
Don't forget to change to your own Domoticz ip address and port number.
http://192.168.1.11:8080/json.htm?type=devices&rid=163
Blah blah blah
martinvandenhurk
Re: Dashticz dial
here you go!!
- Spoiler: show
Lokonli
Re: Dashticz dial
Maybe you have set config['use_favorites'] to true (or 1) in CONFIG.js
Because then at startup Dashticz only receives information of devices that are marked as Favorite in Domoticz.
Your SolarEdge device is not marked as Favorite.
Dials without device information will be created as on/off dials by default.
So, mark your SolarEdge device as Favorite, or change the config setting to:
config['use_favorites'] = 0
martinvandenhurk
Re: Dashticz dial
I added SolarEdge as a favorite and the value is there!
thank you Lokonli!
thank you Lokonli!
