Alexa text to speech Topic is solved
Alexa, Google Home and Siri
sammyke007
Domoticz version: 2022.1
Re: Alexa text to speech
Post by sammyke007 »
poweredge wrote: Monday 08 March 2021 9:07
philchillbill wrote: Sunday 07 March 2021 18:58
poweredge wrote: Sunday 07 March 2021 14:41 how did you do that ? im from NL as well - and have an international amazon account but i keep gettting failed MFA logins (mfa activated oathtool works etc)
In the script towards the beginning:
SET_AMAZON='amazon.co.uk'
SET_ALEXA='alexa.amazon.co.uk'
thanks - tried it but no luck... did you login on the DM machine prior with browser so it recognizes your instance? i still get the captcha and MFA etc.
Are you doing the MFA in the correct way? You need to enter the correct digits. Most people do the MFA part wrong.
I also use .co.uk with MFA as a Belgian user and never had any problems with Alexa text2speech since the last year.
See page 6 of this topic for my conversation with salopette. He was doing the same thing wrong. The usage of the correct quotes (double or single) is important!
poweredge
Post by poweredge »
sammyke007 wrote: Monday 08 March 2021 10:05
i think i do - just sent you a PM as well - im using the correct 'string' - i think ...the long secret / combi of letters/numbers in groups of 4.
EDIT: registration on the amazon website also went fine - so that would be the issue ... ran the oathtool with options and " MFA KEY AMAZON "
DM2021.1 (pri+sec) VM/RPI4. Dashticz @touchscreen. IT: Dell ESXi cluster, UPS, fiber+4g WAN. Smart: Aeotec/Neo/Qubino/Eurotronic zwave, Philips Hue, P1, rfxom433, OTGW, ITHO WiFi, Shelly shutter/water sens, NEST v3, 9x Alexa
witchdocta
Post by witchdocta »
Hi guys,
I'm struggling getting the MFA thingy to work.
As far as I understood, the MFA key has to be generated on the machine which is usingt the script, right? I've tried to work around thiws by using the google authenticator app on an iphone, scan the QR on the amazon webpage, click "can't read the QR" and put in the shown (long) key as MFA secret in the script. But creating the answer on another device is obviously not correct.
:?: As I'm on a synology running domoticz in a docker container maybe someone could give me a hand on how to install the oauthtool there. Is it even possible? Or is there a workaround to create the key for the synology/domoticz/container-combination?
Help is very much appreciated.
wxop
Post by wxop »
Here is a full integration in Domoticz, as a Dzvent script, (using a bash wrapper to this excellent alexa_remote_control.sh script).
viewtopic.php?f=59&t=37038&p=279913
Enjoy playing sound, or speaking text, when any Domoticz's switch changes its state.
Developer of phpMyDomo, a Web Interface for Domoticz
gizmocuz
Post by gizmocuz »
In beta 14040 I added the possibility to add a custom http/script action for each notification.
Using the script from:
https://blog.loetzimmer.de/2021/09/alex ... cript.html
With this you can set a custom message in your own language that is being send to (for example) PushOver and let your english speaking alexa speak something complete different
Hope it can benefit someone here
Hesmink
Post by Hesmink »
gizmocuz wrote: Tuesday 11 January 2022 14:32 In beta 14040 I added the possibility to add a custom http/script action for each notification.
Nice! Thanks for implementing this.
sammyke007
Nice one indeed, tnx!
acaonweb
Post by acaonweb »
I'm using node red to make Alexa speech 😄
There is a nice palette to install that provide everything you need, and more flexible and powerful than the script ( I mean, script is only for speech, node red do all the rest 😄 )
grecof973
Post by grecof973 »
acaonweb wrote: Saturday 04 June 2022 7:25 I'm using node red to make Alexa speech 😄
Any more info or some links? it's possible
acaonweb
Post by acaonweb »
yes sure,
obviously you need to run node red in a server somewhere, easy to do (click https://nodered.org/docs/getting-started/raspberrypi)
The you need to install a new palette inside node red, click hamburger on the top right side, cli manage Palette, click on Install tab, find node-red-contrib-alexa-remote2-v2, install it
See https://tech.scargill.net/node-red-cont ... cakebaked/ to configure it
nigels0
Domoticz version: 3.8153
Post by nigels0 »
To get pass the cookie issue, I ran the app once and Amazon sent me a OTP via text. I added that to the end of my password and tried again - and it worked.
On rebooting though, the cookies placed in /tmp disappeared, so I moved the tmp directory constant in the script to something that would persist between re-boots, and that was fine.
TroisSix
Domoticz version: 2025.2
Post by TroisSix »
Have you any issue with the cookies today? on my side, even with the method oathtool/mfa, the cookies are not downloading :(
Edit: it works using the cookie-cli, and just forget the email/pwd/mfa ;-)
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
I'm not a master of pi, but with a proper tutorial I could replicate this function for myself. I have a zigbee socket with consumption monitoring, and theoretically I would like Alexa to notify me when the washing machine has finished the washing program. is there a whole tutorial somewhere so I can replicate this function?
thx
