Alexa text to speech Topic is solved
Re: Alexa text to speech
Gave up two years ago: not reliable, cookies issue, lots of trail and error when installing: what account, what language... Been using Jarvis on my wall tablet as alternative.
Before I drive into Alexa speak again; What is the status nowadays?
- Domoticz version: 2022.1
Has been working 3 months without MFA, but then one day I got a captcha after expired cookies.
Setup MFA and it works very fine since then over here!
- Domoticz version: Stable
Google works perfectly for me. for months now and no cookies monster.
ok, got it running again, this time with MFA. Good to have voice on Alexa again.
Questions
1) how does the volume parameter work?
2) in Dzvents the following line is used:
However, when adding another line, only the last line is executed; the kitchen device is silent:
Questions
os.execute ("/home/pi/domoticz/scripts/alexa_remote_control.sh -d ALL -e speak:'"..message.."'")
os.execute ("/home/pi/domoticz/scripts/alexa_remote_control.sh -d Kitchen -e speak:'"..message.."'")
os.execute ("/home/pi/domoticz/scripts/alexa_remote_control.sh -d Bathroom -e speak:'"..message.."'")
It seems that Alexa is missing messages because of some sort of sleep mode. It starts with the second attempt, when calling the script after an hour or so.
SOLVED Re: Alexa text to speech
If I start the script ./alexa_remote_control.sh -ALL speak:'MESSAGE' an error occurs:
bash: ./alexa_remote_control.sh: /bin/sh^M: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden
jq and oathtools are installed. The scripts looks fine.
Any hints?
UTF-8 was the solution...
Any hints?
all of a sudden Alexa is silent. MFA was working since May, but now this error:
Try logging in to https://alexa.amazon.de with your browser. In your browser
make sure to have all Amazon related cookies deleted and Javascript disabled!
(For more information have a look at /tmp/.alexa.login)
To avoid issues with captcha, try using Multi-Factor Authentication.
To do so, first set up Two-Step Verification on your Amazon account, then
configure this script (or the environment) with your MFA secret.
Support for Multi-Factor Authentication requires 'oathtool' to be installed.
- philchillbill
Me too. Refreshing the cookie does not help
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
Tested, still working fine here using MFA.
- philchillbill
I fixed mine by changing my store from .de to .co.uk. No idea why it even worked with .de because my account is indeed .co.uk. And .de worked for a few months with MFA. Anyway, solved.
That might be a possible solution as my Alexa account is indeed an .co.uk account
I can't get Alexa to speak on my Sonos Beam from my Raspberry Pi. alexa_remote_control.sh -a gives me the correct devices back, and when I do a
she also says the correct things as if you would say 'goodmorning' to it.
My account is an Amazon.com account and my settings:
When I try to use the speak command (so no error):
Any suggestions to get it working?
EDIT: I'm afraid this script will not work with Sonos. Some speech and things like routines are not possible on certain (or most?) third party devices. I guess I'll try to achieve the same goal another way.
sudo /home/pi/domoticz/scripts/alexa_remote_control.sh -e goodmorning -d 'Sonos Beam'
SET_MFA_SECRET='<52 character from https://www.amazon.com/a/settings/approval>'
SET_LANGUAGE='en-US'
SET_TTS_LOCALE='en-US'
SET_AMAZON='amazon.com'
SET_ALEXA='alexa.amazon.com'
pi@raspberrypi:~ $ sudo /home/pi/domoticz/scripts/alexa_remote_control.sh -e speak:'Why am I not talking' -d 'Sonos Beam'
sending cmd:speak:Why am I not talking to dev:Sonos Beam type:A3NPD82ABCPIDP serial:<myserial> customerid:<mycustomeridhere>
Is amazon messing with devices currently?
Has been working for months with MFA. I'm In the Netherlands and got my devices on Amazon.de, language = EN
My settings in alexa_remote_control.sh:
Error after: /home/pi/domoticz/scripts/alexa_remote_control.sh -e speak:'MESSAGE'
1) Is anybody else having the same issues?
2) if i remember correctly the cookie and login error have been always there, even when things were working correctly. That would make it harder to debug. Can somebody with working Alexa report his/her feedback here from /home/pi/domoticz/scripts/alexa_remote_control.sh -e speak:'MESSAGE'
SET_LANGUAGE='en-UK'
SET_TTS_LOCALE='de-DE'
SET_AMAZON='amazon.de'
SET_ALEXA='alexa.amazon.de'
cookie does not exist. logging in ...
ERROR: Amazon Login was unsuccessful. Possibly you get a captcha login screen.
Update: problem gone of previous post
1) doing a sudo version got me a good login with sudo /home/pi/domoticz/scripts/alexa_remote_control.sh -e goodmorning -d 'kitchen'
2) got the wrong device name set, renamed it on amazon.de and did a Rpi reboot
To answer my own question 2): there is no login error message
pi@raspberrypi:~ $ sudo /home/pi/domoticz/scripts/alexa_remote_control.sh -e speak:'MESSAGE' -d kitchen
sending cmd:speak:MESSAGE to dev:kitchen type:AB72C64C86AW2 serial:90F007187016046L customerid:A77JZ2BCLO7CQ
I love whispered effect :
Switch light ON
Switch light OFF
Switch light ON
script:///home/pi/domoticz/scripts/alexa/alexa_remote_control.sh -d "Echo Office" -e speak:'<speak><amazon:effect name="whispered">Light switch ON !</amazon:effect></speak>'
script:///home/pi/domoticz/scripts/alexa/alexa_remote_control.sh -d "Echo Office" -e speak:'<speak><amazon:effect name="whispered">Light switch OFF !</amazon:effect></speak>'
Re: Alexa text to speech/Alexa started announcing “underscore” for every space
Thank you all for your great contributions to this capability.
A very simple guide to setting TTS for Alexa can be found here https://www.machinon.com/post/autonomous-tts-with-alexa
Once setup I then ran into a problem of Alex converting spaces to underscore (for alexa.amazon.co.uk) e.g. "Hellounderscorethisunderscore..." The fix (for the moment) is to insert a hyphen between each word e.g. ./alexa_tts.sh -d Kitchen -e speak:'Hello-I-can-talk-now'. (link https://forums.homeseer.com/forum/homes ... tant/page7)
This works great.
can you combine a speak and sound effect command?
this did not work > ./Alexa_tts.sh -e sound:amzn_sfx_trumpet_bugle_04, speak:'hello', -d 'Kitchen echo'
how did you do that ? im from NL as well - and have an international amazon account but i keep gettting failed MFA logins (mfa activated oathtool works etc)philchillbill wrote: ↑Wednesday 26 August 2020 23:54 I fixed mine by changing my store from .de to .co.uk. No idea why it even worked with .de because my account is indeed .co.uk. And .de worked for a few months with MFA. Anyway, solved.
DM2021.1 (pri+sec) VM/RPI4. Dashticz @touchscreen. IT: Dell ESXi cluster, UPS, fiber+4g WAN. Smart: Aeotec/Neo/Qubino/Eurotronic zwave, Philips Hue, P1, rfxom433, OTGW, ITHO WiFi, Shelly shutter/water sens, NEST v3, 9x Alexa
- philchillbill
In the script towards the beginning:
SET_AMAZON='amazon.co.uk'
SET_ALEXA='alexa.amazon.co.uk'
thanks - tried it but no luck... did you login on the DM machine prior with browser so it recognizes your instance? i still get the captcha and MFA etc.philchillbill wrote: ↑Sunday 07 March 2021 18:58In the script towards the beginning:
