Python plugin: Presence detection from wireless router
Prinsje
Re: Python plugin: Presence detection from wireless router
Did delete and re-added iDetect in the Hardware section. For some strange reason, no iDetect-related devices were created (old iDetect Devices were obviously removed as part of deletion). Anybody having a quick work-around? Thanks.
EscApe
- Domoticz version: 2020+
A few things to check:Prinsje wrote: Monday 20 December 2021 11:50 Did delete and re-added iDetect in the Hardware section. For some strange reason, no iDetect-related devices were created (old iDetect Devices were obviously removed as part of deletion). Anybody having a quick work-around? Thanks.
- Is "Accept new hardware devices" enabled in the Domoticz Settings?
- Are there any typos or syntax errors in the configuration string for devices to monitor?
To dig deeper you can enable debug mode and look at (or share) the log.
Prinsje
Thanks for your prompt response EscApe.EscApe wrote: Monday 20 December 2021 12:47 A few things to check:
All new hardware devices are allowed. Log provides following syntax error:
2021-12-20 13:09:08.703 iDetect hardware started.
2021-12-20 13:09:08.703 Status: iDetect: (iDetect) Entering work loop.
2021-12-20 13:09:08.703 Status: iDetect: (iDetect) Started.
2021-12-20 13:09:08.980 Status: iDetect: (iDetect) Initialized version 2.0, author 'ESCape'
2021-12-20 13:09:10.737 Error: iDetect: (iDetect) 'onStart' failed 'SyntaxError'.
2021-12-20 13:09:10.737 Error: iDetect: (iDetect) ----> Line 427 in '/home/pi/domoticz/plugins/iDetect/plugin.py', function onStart
2021-12-20 13:09:10.737 Error: iDetect: (iDetect) ----> Line 212 in '/home/pi/domoticz/plugins/iDetect/plugin.py', function onStart
2021-12-20 13:09:10.737 Error: iDetect: (iDetect) ----> Line 14 in '/home/pi/domoticz/plugins/iDetect/trackers/__init__.py', function <module>
2021-12-20 13:09:18.053 Status: iDetect: (iDetect) Skip this hearbeat ... system is still preparing
2021-12-20 13:09:28.083 Status: iDetect: (iDetect) Skip this hearbeat ... system is still preparing -
EscApe
It looks like the plugin is not even starting. Strange that it throws a syntaxerror. You could try completely removing the plugin from the file system and reinstalling, just in case a file was modified. Does your installation meet the requirements (installed modules) and are you running a supported python version (tested with 3.7)?
Prinsje
Yep, deletion and re-installation was successfull. Thanks EscApe!EscApe wrote: Monday 20 December 2021 15:30 It looks like the plugin is not even starting. Strange that it throws a syntaxerror. You could try completely removing the plugin from the file system and reinstalling, just in case a file was modified. Does your installation meet the requirements (installed modules) and are you running a supported python version (tested with 3.7)?
Devices are now listed in the device section again. Next item to solve is how to ensure that the UDM Pro data is correctly analysed by the script - mobile devices connected via wifi remain highlighted as being present whilst disconnected for a while.
EscApe
I can only speak for the ssh and ping trackers. The unifi (http) tracker was written by stas-demydiuk and I don’t know if/how it supports the UDM pro. If a specific tracker is needed then someone owning a UDM pro can add it as a pull request on GitHub.Prinsje wrote: Monday 20 December 2021 17:09 Next item to solve is how to ensure that the UDM Pro data is correctly analysed by the script
rensbr
I'm running Domoticz in Docker and I can't get this plugin to work.
I have installed the plugin according to the guide, but i'm getting the below error:
I have installed paramiko locally, but that didn't do the trick, so I used the following command to install paramiko inside docker container:
But then i'm getting the following error:
Anybody an idea to get the plugin working?
2022-01-08 20:33:01.447 Error: Presence detection: Missing paramiko module required for ssh. Install it using: sudo pip3 install paramiko
2022-01-08 20:33:01.448 Error: Presence detection: Missing paramiko module required for ssh. Install it using: sudo pip3 install paramiko
2022-01-08 20:33:01.448 Error: Presence detection: Missing paramiko module required for ssh. Install it using: sudo pip3 install paramikoCode: Select all
docker exec -it domoticz pip3 install paramikoCode: Select all
Collecting paramiko
Downloading https://files.pythonhosted.org/packages/60/3e/84c52fb09db84548c5d366bac8863125c6db099b87495e04c8af5527e6f1/paramiko-2.9.2-py2.py3-none-any.whl (210kB)
100% |████████████████████████████████| 215kB 3.3MB/s
Collecting bcrypt>=3.1.3 (from paramiko)
Downloading https://files.pythonhosted.org/packages/52/a7/51ab6481ac355517696477889d8ab232106a0ddadda642c54e47a2ab40b9/bcrypt-3.2.0-cp36-abi3-manylinux1_x86_64.whl (63kB)
100% |████████████████████████████████| 71kB 6.5MB/s
Collecting pynacl>=1.0.1 (from paramiko)
Downloading https://files.pythonhosted.org/packages/a7/22/27582568be639dfe22ddb3902225f91f2f17ceff88ce80e4db396c8986da/PyNaCl-1.5.0.tar.gz (3.4MB)
100% |████████████████████████████████| 3.4MB 244kB/s
Installing build dependencies ... error
Complete output from command /usr/bin/python3 -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-16o0gh49 --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools>=40.8.0 wheel "cffi>=1.4.1; python_implementation != 'PyPy'":
Collecting setuptools>=40.8.0
Using cached https://files.pythonhosted.org/packages/04/e0/2fb461b22be560d2a1f630346bfafde0029205484ccfc4f1046e79f599a3/setuptools-60.3.1-py3-none-any.whl
Collecting wheel
Using cached https://files.pythonhosted.org/packages/27/d6/003e593296a85fd6ed616ed962795b2f87709c3eee2bca4f6d0fe55c6d00/wheel-0.37.1-py2.py3-none-any.whl
Collecting cffi>=1.4.1
Using cached https://files.pythonhosted.org/packages/00/9e/92de7e1217ccc3d5f352ba21e52398372525765b2e0c4530e6eb2ba9282a/cffi-1.15.0.tar.gz
Collecting pycparser (from cffi>=1.4.1)
Using cached https://files.pythonhosted.org/packages/62/d5/5f610ebe421e85889f2e55e33b7f9a6795bd982198517d912eb1c76e1a53/pycparser-2.21-py2.py3-none-any.whl
Building wheels for collected packages: cffi
Running setup.py bdist_wheel for cffi: started
Running setup.py bdist_wheel for cffi: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-6t33y93g/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-o9pws03b --python-tag cp37:
No working compiler found, or bogus compiler options passed to
the compiler from Python's standard "distutils" module. See
the error messages above. Likely, the problem is not related
to CFFI but generic to the setup.py of any Python package that
tries to compile C code. (Hints: on OS/X 10.8, for errors about
-mno-fused-madd see http://stackoverflow.com/questions/22313407/
Otherwise, see https://wiki.python.org/moin/CompLangPython or
the IRC channel #python on irc.libera.chat.)
Trying to continue anyway. If you are trying to install CFFI from
a build done in a different context, you can ignore this warning.
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cffi
Installing collected packages: setuptools, wheel, pycparser, cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-6t33y93g/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-d0ehzzqs/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-16o0gh49 --compile:
running install
/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.7
creating build/lib.linux-x86_64-3.7/cffi
copying cffi/api.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/cparser.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/verifier.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/ffiplatform.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/commontypes.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/vengine_gen.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/lock.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/error.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/recompiler.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/pkgconfig.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/model.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/__init__.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_cffi_include.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/parse_c_type.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_embedding.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-x86_64-3.7/cffi
running build_ext
creating build/temp.linux-x86_64-3.7
creating build/temp.linux-x86_64-3.7/c
x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -flto -fuse-linker-plugin -ffat-lto-objects -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.7m -c c/_cffi_backend.c -o build/temp.linux-x86_64-3.7/c/_cffi_backend.o
error: command 'x86_64-linux-gnu-gcc' failed: No such file or directory: 'x86_64-linux-gnu-gcc'
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-6t33y93g/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-d0ehzzqs/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-16o0gh49 --compile" failed with error code 1 in /tmp/pip-install-6t33y93g/cffi/
Command "/usr/bin/python3 -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-16o0gh49 --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools>=40.8.0 wheel "cffi>=1.4.1; python_implementation != 'PyPy'"" failed with error code 1 in None-
EscApe
The paramiko module (and other requirements) needs to be included in the docker container. Installing it on the host does not make it available to the container. You can create your own docker file and create the image locally to accomplish that. I don’t know if it is possible to install it afterward (like you tried)
I updated the Omada HTTPS tracker to work with 4.x.x. It does no longer support 3.x.x, but that doesn't matter because it is end-of-life.
Cheers,
Erik
Cheers,
Erik
- omada4.txt
- (3.32 KiB) Downloaded 56 times
rensbr
Thank you for the fast reply!
And which other requirements are needed for this plugin?
I'm a little docker noob, so I don't really know how to do that. Do you maybve have an idea how to do that?EscApe wrote: Saturday 08 January 2022 21:48 The paramiko module (and other requirements) needs to be included in the docker container. [...] You can create your own docker file and create the image locally to accomplish that.
For other pip3 modules this did work.I don’t know if it is possible to install it afterward (like you tried)
EscApe
I’m no docker expert either but managed to get it working. I can PM you my docker file. It needs some cleaning up, so I’m not going to publish it as it is. Took some trial and error to get paramiko install working because it has some complicated requirements on its own.
rensbr
That would be great, thanks!EscApe wrote: Saturday 08 January 2022 22:31 I’m no docker expert either but managed to get it working. I can PM you my docker file. It needs some cleaning up, so I’m not going to publish it as it is. Took some trial and error to get paramiko install working because it has some complicated requirements on its own.
EscApe
Thanks! Your changes have been merged on GitHub. Since I don't own any Omada based devices I am unable to test it. Please let me know if there are any problems.edg1972 wrote: Saturday 08 January 2022 21:54 Hi,
Cheers,
Erik
darrepac
Hello
What is the recommended to update the tracker list... I tried "modify" but it did nothing, so I pressed "add" and it created me new devices but the old ones are still behind...
thanks
thanks
EscApe
Update is fine. The “remove obsolete” setting determines what happens to devices that are no longer tracked.
darrepac
Where is "udpate"?EscApe wrote: Wednesday 19 January 2022 16:50 Update is fine. The “remove obsolete” setting determines what happens to devices that are no longer tracked.
EscApe
Assuming you where asking about changing the devices to track: Go to the hardware settings for the plug in. Edit the “tags to monitors” field and press the update button. But maybe you meant something else? There is no “modify” button on the hardware settings page in my English Domoticz setup.
darrepac
May-be I am facing poor translation problem. My setup is in french, when I go to hardware settings for the plugin, I have: which means "modify" (but could be update) and "delete". Is the one on the left the "update"?EscApe wrote: Wednesday 19 January 2022 17:43Assuming you where asking about changing the devices to track: Go to the hardware settings for the plug in. Edit the “tags to monitors” field and press the update button. But maybe you meant something else? There is no “modify” button on the hardware settings page in my English Domoticz setup.
EscApe
Looks like a different translation indeed. “Update” is “modifier”
steeringwheel
Registered especially to share my Linksys Velop tracker which also should work on other Linksys Smart Wifi routers. Needs the Python JSON module (sudo pip3 install json).
- http_linksys.py.txt
- (1.52 KiB) Downloaded 50 times
