NodeMcu with tasmota and two sensor DHT22
Pietrogramma
Post by Pietrogramma »
Hello guys, I recently discovered Domoticz and I am therefore a beginner. Some time ago I used a Nodemcu, with tasmota firmware, to which I connected two DHT22 sensors (one on GPIO14 and one on GPIO2), one for the internal temperature of the house and one for the external one.
Yesterday, I tried to connect it to Domoticz, via MQtt, but I can read the data of only one sensor, is there the possibility of reading both of them? if you could explain to me, in the simplest way possible (as if you were talking to a child 🙂) how to do it?
Hello and thank you very much
Dave21w
Domoticz version: Stable
Re: NodeMcu with tasmota and two sensor DHT22
Post by Dave21w »
First Question, Have you added 2 new sensors to Domoticz and then made a note of there IDX value and entered this in the correct field in Tasmota yet ?
Pietrogramma
Hi Dave, exacltly... I created two sensor temperature+Umidity (one with IDX 1 and other with ODX2) and I inserted in tasmota "Domoticz" the value 1 in the Sensor Temp-Umidity and 2 in sensor temp-umidity-baro, but I read the temperature only in sensor with IDX1
Domoticz version: 2025.1
Check with MQTT explorer what Tasmota is sending, see https://www.domoticz.com/wiki/MQTT#Debugging_MQTT
And check that values that Tasmota is sending are according the rules from Domoticz MQTT https://www.domoticz.com/wiki/MQTT#Upda ... t_Setpoint
Pietrogramma
I installed in my PC the MQTT explorer and I checked that the two sensors work ( I read their values in MQTT).
Always in the MQTT Explorere, under the IN string of the Domoticz, I read only in = {"idx":2,"nvalue":0,"svalue":"24.8;88.8;3","Battery":100,"RSSI":5}, I don't found any rifeiment about DX1.
In the attach pic, where I must insert the value of the DX1?
I attach a photo whit the valuues in tasmta web of the two sensor.
Thanks and ciao
besix
Post by besix »
I do not have AM 2301 because it is not suitable for the outdoors.
You must use the rules in tasmota. Run console and insert
Rule
  ON tele-AM2301-14#temperature DO var1 %value% ENDON
  ON tele-AM2301-14#humidity DO publish domoticz/in {"idx":2,"svalue":"%var1%;%value%;1"} ENDON
Then turn on the rule
Rule1 1
You can also use the Tasmoticz plug then it should detect two sensors by itself
Pietrogramma
I tried to install the plugin Tasmoticz ( I followed this github https://github.com/joba-1/Tasmoticz), but the system was in crash (if I goto to the ip of raspberry I see only a black screen and in the url I read http://192.168.178.30:8080/#/Offline).
Actually i've noticed that often when I install a plugin i have this problem, how can i solve it? is there any operation to do before installing a plugin.
Thanks and ciao
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
Hopefully you are not on bullseye because many plugins don't work
Rfxcom
Raspi 4
