From accumulated to daily heat consumption
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
There is a custom sensor that shows the accumulated heat consumption. I would like to add a sensor that shows the heat consumption of the previous day.
heat consumption.png (22.89 KiB) Viewed 681 times
I get stuck making the necessary script.
return
    on =
        timer =
            'at 20:00',
    logging =
        level = domoticz.LOG_ERROR, -- change to domoticz.LOG_DEBUG when somesthing is wrong
        marker = 'heat consumption previous day',
        data =
        previousData = { initial = {} }
    execute = function(dz, timer)
        local totaal = dz.devices('Warmteverbruik totaal')                      -- custom sensor accumulated heat consumption (GJ)
        local gisteren = dz.devices('Warmteverbruik gisteren')                  -- custom sensor heat comsumption previous day (GJ)
        local verschil = totaal.sensorValue - dz.data.previousData
            gisteren.updateCustomSensor(verschil)
            table.insert(dz.data.previousData, totaal.sensorValue)
Log shows:
 2022-01-04 20:00:00.376 Error: dzVents: Error: (3.1.8) heat consumption previous day: An error occurred when calling event handler Warmteverbruik per dag
2022-01-04 20:00:00.376 Error: dzVents: Error: (3.1.8) heat consumption previous day: ...pts/dzVents/generated_scripts/Warmteverbruik per dag.lua:27: attempt to perform arithmetic on a table value (field 'previousData')
Thanks in advance
vtwp
Re: From accumulated to daily heat consumption
Post by vtwp »
Hi Jan,
I don't know the solution, but the error message says that it fails performing a numeric calculation because the format of the numbers is not the same ("attempt to perform arithmetic on a table value (field 'previousData')"). That means the error is in the script line:
Assuming that 'previousData' is a table, maybe you can check how you can call the value from a table. Hope that helps!
Jan Jansen
Re: From accumulated to daily heat consumption [Solved]
@vtwp
Thanks for your reply. By using a uservariable I was able to solve the problem.
