Simple batch script with text editing Topic is solved
All kinds of 'OS' scripts
Droll
Domoticz version: 2024.7
Post by Droll »
I got an output file from a testing machine that I need to clean up a bit before importing into some spreadsheet..
"VarName"   "TimeString"    "VarValue"  "Validity"  "Time_ms"
"VALUES_A"  "2021-10-25 09:57:32"   10500   1   44494414962.465279
"VALUES_B"  "2021-10-25 09:57:32"   59.282589   1   44494414962.488426
"VALUES_C"  "2021-10-25 09:57:32"   7.522789    1   44494414962.488426
"VALUES_D"  "2021-10-25 09:57:32"   7.880400    1   44494414962.500000
"VALUES_E"  "2021-10-25 09:57:32"   8.337399    1   44494414962.500000
"VALUES_F"  "2021-10-25 09:57:32"   9.523390    1   44494414962.534721
"VALUES_G"  "2021-10-25 09:57:32"   16.065742   1   44494414962.534721
"VALUES_H"  "2021-10-25 09:57:32"   18.799999   1   44494414962.546295
"VALUES_I"  "2021-10-25 09:57:32"   "2013-03-14 21:30:32"   1   44494414962.546295
"VALUES_A"  "2021-10-25 09:57:52"   10501   1   44494414962.465279
"VALUES_B"  "2021-10-25 09:57:52"   60.282589   1   44494414962.488426
"VALUES_C"  "2021-10-25 09:57:52"   7.622789    1   44494414962.488426
"VALUES_D"  "2021-10-25 09:57:52"   7.890400    1   44494414962.500000
"VALUES_E"  "2021-10-25 09:57:52"   7.337399    1   44494414962.500000
"VALUES_F"  "2021-10-25 09:57:52"   10.523390   1   44494414962.534721
"VALUES_G"  "2021-10-25 09:57:52"   17.065742   1   44494414962.534721
"VALUES_H"  "2021-10-25 09:57:52"   19.799999   1   44494414962.546295
"VALUES_I"  "2021-10-25 09:57:52"   "2013-03-14 21:30:32"   1   44494414962.546295
And I want it to be something like this
2021-10-25 09:57:32, 10500, 59.282589, 7.522789, 7.880400, 8.337399, 9.523390, 16.065742, 18.799999
2021-10-25 09:57:32, 10501, 60.282589, 7.622789, 7.890400, 7.337399, 10.523390, 17.065742, 19.799999
Found sommething simmulair searching the net, here should be possible to edit the parameters to fit my text ? ..
@echo off
setlocal enableDelayedExpansion
for %%F in (*.txt) do (
  set "out="
  set "i=x"
  > "%%~nF.csv" (
    for /f usebackq^ tokens1^= delims^="*"^ "*"^  %%A in ("%%F") do (
      if %%A neq !i! (
        if defined out echo !out!"
        set /a "i=%%A, j=0"
        set "out=!i!
      ) else (
        set /a j+=1
        if !j! leq 3 (set "out=!out!.%%B j") else set "out=!out!.%%C"
And of coarse I can't make it work, carpenter not a programmer :-)
AND I know ther's pleny of script people here :)
Arne Kjetil
user4563
Domoticz version: 2026.4
Re: Simple batch script with text editing
Post by user4563 »
You would be better off doing this with a script in PowerShell
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
Droll
Post by Droll »
user4563 wrote: Sunday 19 December 2021 16:39 You would be better off doing this with a script in PowerShell
Maybe, got any exampels ?.
I has to be run on a regulary basis to convert files..
Arne Kjetil
user4563
Post by user4563 »
What formats can you get that data in?
Droll
Post by Droll »
user4563 wrote: Sunday 19 December 2021 18:09 What formats can you get that data in?
It comes in a simple TXT file, see example at the top..
This is ONE reading, it will continue with the same pattern ( Values_A > I, then back to A > .... )
Output can be txt,csv, ??
Arne Kjetil
user4563
Post by user4563 »
Since you can only get the raw data in txt and it's not a uniform delimiter (quotes as well as tab here), you are going to have to parse through it. I found a script online so will this work?
Screenshot 2021-12-19 131500.jpg (234.1 KiB) Viewed 11277 times
Droll
Post by Droll »
siklosi wrote: Sunday 19 December 2021 19:20 Here is python3 script that should do the job.
save as script.py, put data in indata.txt and run with python3 script.py... you will get outdata.txt with formatted text
Not familiare with phyton, but gave it a try :-)
Droll
Post by Droll »
user4563 wrote: Sunday 19 December 2021 19:22 Since you can only get the raw data in txt and it's not a uniform delimiter (quotes as well as tab here), you are going to have to parse through it. I found a script online so will this work?
Maybe, maybe it can be changed to be even more precise ?, what kind of script ?
Arne Kjetil
user4563
Post by user4563 »
I tried the python script @siklosi posted above and it gives you your comma delimited output you are looking for. In the script with python on windows with the path you have to use forward slashes ie
C:/Path/Path/sample.txt
Droll
Post by Droll »
user4563 wrote: Sunday 19 December 2021 22:14 I tried the python script @siklosi posted above and it gives you your comma delimited output you are looking for. In the script with python on windows with the path you have to use forward slashes ie
Well it doesn't work here, forward or backward \/ :-)
user4563
Post by user4563 »
Can you post the error you are now getting?
Droll
Post by Droll »
siklosi wrote: Monday 20 December 2021 7:46 why don't you try putting script in same folder C:/test and using it without path... open('indata.txt') as f:
backslash is escape character so when you need real backslash you have to use double like c:\\test\\indata.txt
Everything are in the same folder...
And for some reason it works, and in the next moment it doesn't work...
Got this error "SyntaxError: unexpected character after line continuation character"
Tested on 2 different machines, one Win7 and one Win10 ..
user4563
Post by user4563 »
Run the script in CMD or PowerShell like this:
python.exe "C:\test\script.py"
If you want to run in the Python shell window:
exec(open('C:/test/script.py').read())
Droll
Post by Droll »
user4563 wrote: Tuesday 21 December 2021 1:45 Run the script in CMD or PowerShell like this:
Still the same, somtimes it works, somtime it doesn't ...
But when it works, it's almost good :-), just missing the most important parameter .. the first ...
2021-10-25 09:57:32, 59.282589, 7.522789, 7.880400, 8.337399, 9.523390, 16.065742, 18.799999
2021-10-25 09:57:52, 60.282589, 7.622789, 7.890400, 7.337399, 10.523390, 17.065742, 19.799999
Should have been
2021-10-25 09:57:52, 10501, 60.282589, 7.622789, 7.890400, 7.337399, 10.523390, 17.065742, 19.799999
Below is an actual example of my start file, at the moment 3300 lines and growing...
Only difference are the first line, was simplyfied in my first example..
"FLASHVALUES_S/N"	"2021-10-25 09:57:32"	10500	1	44494414962.465279
"FLASHVALUES_PMPP"	"2021-10-25 09:57:32"	59.282589	1	44494414962.488426
"FLASHVALUES_VMPP"	"2021-10-25 09:57:32"	7.522789	1	44494414962.488426
"FLASHVALUES_IMPP"	"2021-10-25 09:57:32"	7.880400	1	44494414962.500000
"FLASHVALUES_ISC"	"2021-10-25 09:57:32"	8.337399	1	44494414962.500000
"FLASHVALUES_VOC"	"2021-10-25 09:57:32"	9.523390	1	44494414962.534721
"FLASHVALUES_EFF"	"2021-10-25 09:57:32"	16.065742	1	44494414962.534721
"FLASHVALUES_TC"	"2021-10-25 09:57:32"	18.799999	1	44494414962.546295
"FLASHVALUES_DATE"	"2021-10-25 09:57:32"	"2013-03-14 21:30:32"	1	44494414962.546295
"FLASHVALUES_S/N"	"2021-10-25 10:00:05"	10050	1	44494416727.615738
"FLASHVALUES_PMPP"	"2021-10-25 10:00:05"	57.828953	1	44494416727.638893
"FLASHVALUES_VMPP"	"2021-10-25 10:00:05"	7.338327	1	44494416727.638893
"FLASHVALUES_IMPP"	"2021-10-25 10:00:05"	7.880400	1	44494416727.685188
"FLASHVALUES_ISC"	"2021-10-25 10:00:05"	8.337399	1	44494416727.696754
"FLASHVALUES_VOC"	"2021-10-25 10:00:05"	9.338927	1	44494416727.696754
"FLASHVALUES_EFF"	"2021-10-25 10:00:05"	15.671803	1	44494416727.696754
"FLASHVALUES_TC"	"2021-10-25 10:00:05"	18.799999	1	44494416727.708336
"FLASHVALUES_DATE"	"2021-10-25 10:00:05"	"2013-03-14 21:33:05"	1	44494416727.708336
Droll
Post by Droll »
"FLASHVALUES_S/N" TAB "2021-10-25 09:57:32" TAB 10500 TAB 1 TAB 44494414962.465279
10500 missing ...
The original file uses tabs, not space... could this have something to do with the code ?
with open('data.txt','r') as f:
    lines = f.readlines()
data=''
newline=''
for line in lines:
    line=line.replace("\"","").split()
    if line[0]=='FLASHVALUES_S/N':
        newline=line[1]+" "+line[2]
    elif line[0].startswith('FLASHVALUES') and line[0] !='FLASHVALUES_DATE':
        newline=newline+", "+line[3]
    if line[0]=='FLASHVALUES_DATE':
        data=data+newline+"\n"
print (data)
with open('Flash.txt', 'w') as f:
    f.write(data)
On a test file with spaces this one works fine.... 40000 lines :D , BUT there's one field missing, and it doesn't work on the real file :(
Recap:
  • Missing the value from the first line "FLASHVALUE_S/N".
    Doesn't work on the real file, as it uses TAB instead of space.
Arne Kjetil
Droll
Post by Droll »
Still no go, so have attached a sample of the file itself..
As for the missing part I figured out that part :D
newline=line[3]+", "+line[1]+" "+line[2]
data2.txt
(5.23 KiB) Downloaded 295 times
Arne Kjetil
Droll
Post by Droll »
siklosi wrote: Tuesday 21 December 2021 18:39 this is utf-16 text file and that is why it was not possible to parse it.
with open('data2.txt','r', encoding="utf-16") as f:
data=''
newline=''
for line in lines:
    if line:
            newline=line[1]+" "+line[2]+", "+line[3]
print (data)
    f.write(data)
Now it works :D , thank you for the good help :D
Just as a sidenote... is it possible to get the script to change the dots (.) to comas (,) ??
From 3.14 to 3,14 ?
Easier to to use in Ecxel beacuse we uses , here..
Arne Kjetil
Droll
Post by Droll »
siklosi wrote: Tuesday 21 December 2021 20:46 yes, just add for example line[0].replace("." , ",")
May I ask where :lol:, not very good with scrips
Arne Ketill
Droll
Post by Droll »
with open('Flahlist0.txt','r', encoding="utf-16") as f:
data=''
newline=''
for line in lines:
    line=line.replace("." , ",")
    if line:
            newline=line[3]+"; "+line[1]+" "+line[2]
            newline=newline+"; "+line[3]
print (data)
with open('Flash.csv', 'w') as f:
    f.write(data)
Figured it out, but it cased some other problems for Excel, so I had to make another change too :D
Change the "," to ";" in the output file.... so now it works as intended, at least for now 8-)
Arne Kjetil
