Zigate with Tuya 4 in 1 Sensor : PIR - Temperature - Humidity- Light
dondipietro
Domoticz version: 2021.1
Post by dondipietro »
Hello dears Domo-Zigater, Dear Pipiche,
I have a sensor with PIR + temperature humidity light and I managed to pair it with the Zigate :
Zigate reports it as "TS0202"
The 4 in 1 sensor exist under different name :
Tuya ZigBee – multi-capteur 4-in-1 PIR motion temperature : https://fr.aliexpress.com/item/1005001878974427.html
But also a CE version :
IMMAX NEO SMART MOTION SENSOR 4IN1 ZIGBEE 3.0
https://www.immax.cz/media/186/07502l-p ... QwNUZfMTg2
With the zigate is seems only 2 clusters are found : Motion and Tamper, I don't see Temperature, Humidity, and Lux
TS0202
ZG2 - TS0202_Motion-14b457fffe0e47fa-01
ZG2 - TS0202_Tamper-14b457fffe0e47fa-01
My zigate hardware version is ZiGate+ (v2)
Domoticz Zigate Plugin: 5.1.009
Firmware: 0320
The device in Zigate JSON :
20 :
Battery : 100
ConsistencyCheck : ""
Health : "Live"
IEEE : "14b457fffe0e4c35"
LQI : 50
MacCapa : Array[2] ["RFD","Battery"]
Model : "TS0202"
Param : "{}"
Status : "inDB"
WidgetList : Array[2] ["ZG2 - TS0202_Motion-coude1","ZG2 - TS0202_Tamper-14b457fffe0e4c35-01"]
ZDeviceName : ""
_NwkId : "b33e"
Version : "3"
ZDeviceName : ""
Status : "inDB"
SQN : "08"
Heartbeat : "1178"
RIA : "0"
LQI : 52
Battery : 100
Model : "TS0202"
ForceAckCommands : Array[0] []
MacCapa : "80"
Type : "Motion/Tamper"
ProfileID : "0104"
ZDeviceID : "0106"
App Version : ""
Attributes List : Object {}
DeviceType : "RFD"
HW Version : ""
Last Cmds : Array[10] [[125346,"02","d6f6","0100","0101000000000000010004"],[125347,"02","d6f6","0100","0101000000000000010005"],["None","02","d6f6","0100","0101000000000000010004"],["None","02","d6f6","0100","0101000000000000010005"],["None","02","d6f6","0100","0101000000000000010004"],["None","02","d6f6","0100","0101000000000000010005"],[125409,"02","d6f6","0100","0101000000000000010004"],[125410,"02","d6f6","0100","0101000000000000010005"],[125435,"02","99cb","0100","0101000000000000010004"],[125436,"02","99cb","0100","0101000000000000010005"]]
LogicalType : "End Device"
Manufacturer : ""
Manufacturer Name : "_TZ3210_jijr1sss"
NbEp : "3"
PowerSource : "Battery"
ReadAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":"25/11/2021 13:08:38","iSQN":{"0004":125435,"0005":125436},"Attributes":{"0004":"00","0005":"00"},"ZigateRequest":{}},"0001":{"TimeStamp":"25/11/2021 13:03:34","iSQN":{"0020":125344,"0021":125345},"Attributes":{"0020":"00","0021":"00"},"ZigateRequest":{}},"0500":{"TimeStamp":"25/11/2021 13:08:40","iSQN":{},"Attributes":{"0000":"00","0010":"00"},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":"25/11/2021 13:03:21","iSQN":{"0004":125330,"0005":125333},"Attributes":{"0004":"86","0005":"86"},"ZigateRequest":{}}},"03":{"0000":{"TimeStamp":"25/11/2021 13:03:23","iSQN":{"0004":125331,"0005":125334},"Attributes":{"0004":"86","0005":"86"},"ZigateRequest":{}},"0400":{"TimeStamp":"25/11/2021 14:45:28","iSQN":{},"Attributes":{"0000":"00"},"ZigateRequest":{}}}}}
ReceiveOnIdle : ""
Stack Version : ""
Stamp : Object {"time":1637847968.6929162,"Time":"2021-11-25 14:46:08","MsgType":"8011","LastSeen":"25/11/2021 14:46:08"}
ZCL Version : ""
Health : "Live"
Capability : Array[3] ["Reduced-Function Device","Standard security","NwkAddr should be allocated"]
RollingLQI : Array[11] [52,52,52,52,52,53,53,52,52,52,52]
Epv2 : Object {"01":{"ClusterIn":{"0000":{},"0001":{},"0500":{},"ef00":{}},"ClusterOut":{"0019":{},"000a":{}},"ProfileID":"0104","ZDeviceID":"0402"},"02":{"ClusterIn":{"0001":{},"0402":{},"0405":{}},"ClusterOut":{},"ProfileID":"0104","ZDeviceID":"0302"},"03":{"ClusterIn":{"0001":{},"0400":{}},"ClusterOut":{},"ProfileID":"0104","ZDeviceID":"0106"}}
PairingInProgress : false
SQN_000a : "07"
ConfigSource : "DeviceConf"
Ep : Object {"01":{"0000":{"0004":"_TZ3210_jijr1sss","0005":"TS0202"},"0001":{"0020":30,"0021":200},"0500":{"0002":"alarm1: 0, alaram2: 0, tamper: 0, battery: 0, Support Reporting: 0, restore Reporting: 0, trouble: 0, acmain: 0, test: 0, battdef: 0","0000":"01","0010":"00158d0005007208"},"Type":"Motion/Tamper","ClusterType":{"321":"Motion","322":"Tamper"},"0006":{"0000":"Cmd: 00, 02"}},"02":{"0000":{}},"03":{"0000":{},"0400":{"0000":57}}}
IASBattery : 100
ZDeviceVersion : "0001"
BatteryUpdateTime : "25/11/2021 13:03:33"
WriteAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0500":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"03":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0400":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
IAS : Object {"01":{"EnrolledStatus":1,"ZoneType":{},"ZoneTypeName":{},"ZoneStatus":{}}}
Max Buffer Size : "52"
Max Rx : "0052"
Max Tx : "0052"
Bind : Object {"01":{"0001":{"Target":"0000","Stamp":"25/11/2021 13:08:35","Phase":"binded","Status":"00","i_sqn":125433},"0500":{"Target":"0000","Stamp":"25/11/2021 13:08:36","Phase":"binded","Status":"00","i_sqn":125434}}}
NwkID : "b33e"
I found this in the log : ZG2 is my Zigate
2021-11-25 14:31:51.054 ZG2: (ZG2) inRawAps b33e/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006b02000400000101 Payload:
19030600006b02000400000101 not processed !!!
2021-11-25 14:31:51.189 ZG2: (ZG2) UpdateDevice - (ZG2 - TS0202_Motion-coude1) 1:On
2021-11-25 14:31:51.201 ZG2: (ZG2) UpdateDevice - (ZG2 - TS0202_Tamper-14b457fffe0e4c35-01) 0:No Alert
2021-11-25 14:31:51.311 ZG2: (ZG2) inRawAps b33e/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006c0200040000004a Payload:
19040600006c0200040000004a not processed !!!
2021-11-25 14:32:24.162 ZG2: (ZG2) Last update of the devices 201 Motion was 31.098698139190674 ago
2021-11-25 14:32:32.921 ZG2: (ZG2) UpdateDevice - (ZG2 - TS0202_Motion-coude1) 0:Off
2021-11-25 14:32:33.225 ZG2: (ZG2) Decode8095 - SQN: 09, Addr: b33e, Ep: 01, Cluster: 0006, Cmd: 00, Unknown: 02
2021-11-25 14:33:00.108 ZG2: (ZG2) UpdateDevice - (ZG2 - TS0202_Motion-14b457fffe0e47fa-01) 0:Off
2021-11-25 14:33:01.508 ZG2: (ZG2) inRawAps 0785/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006e02000400000064 Payload:
19760600006e02000400000064 not processed !!!
2021-11-25 14:33:03.931 ZG2: (ZG2) inRawAps 0785/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006b020004000000d3 Payload:
19780600006b020004000000d3 not processed !!!
2021-11-25 14:33:05.130 ZG2: (ZG2) inRawAps 0785/01 Cluster ef00 Manuf: /_TZ3210_jijr1sss Command: 06 Data: 00006c02000400000033 Payload:
19790600006c02000400000033 not processed !!!
Is there something I can do to have the temperature humidty etc ... ?
Thank you very much to your help,
Last edited by dondipietro on Thursday 25 November 2021 15:58, edited 1 time in total.
dondipietro
Re: Zigate with 4 in 1 Sensor : PIR - Temperature - Humidity- Light
About the three payload, what do you think of this :
00006e02000400000064 : 0x64 is 100 => ???? LUX maybe ...
00006b020004000000d3 => 0xD3 : 211 = 21,1 °C température
00006c02000400000033 => 0x33 : 51 = 51% humidity
dondipietro
On that github, they speaks about the same sensor I think :
https://github.com/dresden-elektronik/d ... ssues/4511
pipiche
Re: Zigate with Tuya 4 in 1 Sensor : PIR - Temperature - Humidity- Light
Post by pipiche »
can you kindly do a first test
0/ could you kindly switch to the beta branche and get the latest version
1/ remove the file Conf/Certified/Tuya/ts0202.json
2/ remove all widget created ( the motion and tamper ) in Domoticz
3/ restart the plugin
4/ redo the pairing by reseting the device and putting the plugin+zigate in pairing mode
let see what is going to happen. You should get more widgets created , check what is working and not working. Probably the Temp/Humidity won't. Can you confirm that Motion works ? Is the tamper works ?
drop me as an attachement the export.json ? you just need to rename it as the .json extension is unfortunatly not accepted here)
dondipietro
To make the test I switched to another system with a Zigate V1 on it, I think it doesn't cause trouble.
I have done what you suggested and it seems A LOT BETTER :
export.json.txt
(9.85 KiB) Downloaded 105 times
dondipietro
Lux seems to work and react well when I put a light on it.
But temperature and humidity doesn't change when I take it in hands and reset it.
Temper seems to be linked to "TS0202_Voltage"
I don't see PIR / motion detector
2021-11-25 18:32:13.144 Status: ZG1: (ZG1) ZiGate Classic PDM (legacy)
2021-11-25 18:32:13.144 Status: ZG1: (ZG1) Installer Version Number: 031c
2021-11-25 18:32:13.144 Status: ZG1: (ZG1) Branch Version: ==> Production <==
2021-11-25 18:32:23.165 Status: ZG1: (ZG1) Zigate addresses ieee: 00158d0001ee8471 , short addr: 0000
2021-11-25 18:32:23.166 Status: ZG1: (ZG1) Network state UP, PANID: 22e3 extPANID: 0x9037fe1652d287d6 Channel: 11
2021-11-25 18:32:28.102 Status: ZG1: (ZG1) Request Disabling Accepting new Hardware
2021-11-25 18:32:29.701 Status: ZG1: (ZG1) Accepting new Hardware: Disable (Off)
2021-11-25 18:32:30.219 Status: ZG1: (ZG1) Number of devices recently active in Zigate = 1
2021-11-25 18:32:30.220 Status: ZG1: (ZG1) [00] DevID: 00 Network addr: 905c IEEE: 14b457fffe0bdcab LQI: 194 power: 00 Model: TS0202 ( )
2021-11-25 18:32:33.083 Status: ZG1: (ZG1) Zigate set to Certification : CE
2021-11-25 18:32:33.090 Status: ZG1: (ZG1) Plugin with Zigate, firmware 031c correctly initialized
2021-11-25 18:32:33.651 Status: ZG1: (ZG1) TxPower Attenuation: 0 dBm
2021-11-25 18:32:38.185 Status: ZG1: (ZG1) There is a newer Zigate Firmware version available
2021-11-25 18:40:54.532 Status: ZG1: (ZG1) (905c/14b457fffe0bdcab) send a Leave indication and will be outside of the network. LQI: 0
2021-11-25 18:41:43.870 Status: ZG1: (ZG1) Request Accepting new Hardware for ever
2021-11-25 18:41:44.468 Status: ZG1: (ZG1) Accepting new Hardware: Enable (On)
2021-11-25 18:41:46.788 ZG1: (ZG1) WARNING - send_zigatecmd : [71] 0100 02cf94010204050000000001fffd cf94 ZigateQueue: 58
2021-11-25 18:41:46.790 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010000 cf94 ZigateQueue: 58
2021-11-25 18:41:46.792 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010001 cf94 ZigateQueue: 58
2021-11-25 18:41:46.794 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010002 cf94 ZigateQueue: 58
2021-11-25 18:41:46.796 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010003 cf94 ZigateQueue: 58
2021-11-25 18:41:46.797 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010004 cf94 ZigateQueue: 58
2021-11-25 18:41:46.799 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010005 cf94 ZigateQueue: 58
2021-11-25 18:41:46.800 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010006 cf94 ZigateQueue: 58
2021-11-25 18:41:46.802 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010007 cf94 ZigateQueue: 58
2021-11-25 18:41:46.803 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010100000000000001ffde cf94 ZigateQueue: 58
2021-11-25 18:41:46.804 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010100000000000001fffd cf94 ZigateQueue: 58
2021-11-25 18:41:46.806 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010100000000000001fffe cf94 ZigateQueue: 58
2021-11-25 18:41:46.813 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010200000000000001ffde cf94 ZigateQueue: 58
2021-11-25 18:41:46.815 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010200000000000001fffd cf94 ZigateQueue: 58
2021-11-25 18:41:46.816 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010200000000000001fffe cf94 ZigateQueue: 58
2021-11-25 18:41:46.828 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010300000000000001ffde cf94 ZigateQueue: 58
2021-11-25 18:41:46.829 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010300000000000001fffd cf94 ZigateQueue: 58
2021-11-25 18:41:46.831 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010300000000000001fffe cf94 ZigateQueue: 58
2021-11-25 18:41:46.846 ZG1: (ZG1) WARNING - send_zigatecmd : [72] 0100 02cf940103040000000000010000 cf94 ZigateQueue: 59
2021-11-25 18:41:46.848 ZG1: (ZG1) WARNING - send_zigatecmd : [73] 0100 02cf940103040000000000010001 cf94 ZigateQueue: 60
2021-11-25 18:41:46.850 ZG1: (ZG1) WARNING - send_zigatecmd : [74] 0100 02cf940103040000000000010002 cf94 ZigateQueue: 61
2021-11-25 18:41:46.851 ZG1: (ZG1) WARNING - send_zigatecmd : [75] 0100 02cf94010304000000000001fffd cf94 ZigateQueue: 62
2021-11-25 18:41:46.854 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000100000000010020 cf94 ZigateQueue: 62
2021-11-25 18:41:46.855 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000100000000010021 cf94 ZigateQueue: 62
2021-11-25 18:41:46.857 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000100000000010040 cf94 ZigateQueue: 62
2021-11-25 18:41:46.858 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000100000000010041 cf94 ZigateQueue: 62
2021-11-25 18:41:46.859 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010100010000000001fffd cf94 ZigateQueue: 62
2021-11-25 18:41:46.862 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940102000100000000010020 cf94 ZigateQueue: 62
2021-11-25 18:41:46.864 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940102000100000000010021 cf94 ZigateQueue: 62
2021-11-25 18:41:46.866 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940102000100000000010040 cf94 ZigateQueue: 62
2021-11-25 18:41:46.867 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940102000100000000010041 cf94 ZigateQueue: 62
2021-11-25 18:41:46.869 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010200010000000001fffd cf94 ZigateQueue: 62
2021-11-25 18:41:46.871 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940103000100000000010020 cf94 ZigateQueue: 62
2021-11-25 18:41:46.873 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940103000100000000010021 cf94 ZigateQueue: 62
2021-11-25 18:41:46.874 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940103000100000000010040 cf94 ZigateQueue: 62
2021-11-25 18:41:46.876 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940103000100000000010041 cf94 ZigateQueue: 62
2021-11-25 18:41:46.877 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010300010000000001fffd cf94 ZigateQueue: 62
2021-11-25 18:41:46.880 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010000 cf94 ZigateQueue: 62
2021-11-25 18:41:46.882 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010001 cf94 ZigateQueue: 62
2021-11-25 18:41:46.883 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010002 cf94 ZigateQueue: 62
2021-11-25 18:41:46.884 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010003 cf94 ZigateQueue: 62
2021-11-25 18:41:46.886 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010004 cf94 ZigateQueue: 62
2021-11-25 18:41:46.887 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010005 cf94 ZigateQueue: 62
2021-11-25 18:41:46.889 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010006 cf94 ZigateQueue: 62
2021-11-25 18:41:46.890 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf940101000000000000010007 cf94 ZigateQueue: 62
2021-11-25 18:41:46.892 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010100000000000001ffde cf94 ZigateQueue: 62
2021-11-25 18:41:46.893 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010100000000000001fffd cf94 ZigateQueue: 62
2021-11-25 18:41:46.894 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010100000000000001fffe cf94 ZigateQueue: 62
2021-11-25 18:41:46.901 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010200000000000001ffde cf94 ZigateQueue: 62
2021-11-25 18:41:46.903 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010200000000000001fffd cf94 ZigateQueue: 62
2021-11-25 18:41:46.904 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010200000000000001fffe cf94 ZigateQueue: 62
2021-11-25 18:41:46.917 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010300000000000001ffde cf94 ZigateQueue: 62
2021-11-25 18:41:46.919 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010300000000000001fffd cf94 ZigateQueue: 62
2021-11-25 18:41:46.920 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0100 02cf94010300000000000001fffe cf94 ZigateQueue: 62
2021-11-25 18:41:46.935 ZG1: (ZG1) WARNING - send_zigatecmd : [77] 0140 02cf940101000000000000000001 cf94 ZigateQueue: 64
2021-11-25 18:41:46.936 ZG1: (ZG1) WARNING - send_zigatecmd : [78] 0140 02cf940101000100000000000001 cf94 ZigateQueue: 65
2021-11-25 18:41:46.938 ZG1: (ZG1) WARNING - send_zigatecmd : [79] 0140 02cf940101050000000000000001 cf94 ZigateQueue: 66
2021-11-25 18:41:46.939 ZG1: (ZG1) WARNING - send_zigatecmd : [80] 0140 02cf940101ef0000000000000001 cf94 ZigateQueue: 67
2021-11-25 18:41:46.940 ZG1: (ZG1) WARNING - send_zigatecmd : [81] 0140 02cf940101001900000000000001 cf94 ZigateQueue: 68
2021-11-25 18:41:46.941 ZG1: (ZG1) WARNING - send_zigatecmd : [82] 0140 02cf940101000a00000000000001 cf94 ZigateQueue: 69
2021-11-25 18:41:46.942 ZG1: (ZG1) WARNING - send_zigatecmd : [83] 0140 02cf940101000600000000000001 cf94 ZigateQueue: 70
2021-11-25 18:41:46.944 ZG1: (ZG1) WARNING - send_zigatecmd : [84] 0140 02cf940102000100000000000001 cf94 ZigateQueue: 71
2021-11-25 18:41:46.945 ZG1: (ZG1) WARNING - send_zigatecmd : [85] 0140 02cf940102040200000000000001 cf94 ZigateQueue: 72
2021-11-25 18:41:46.946 ZG1: (ZG1) WARNING - send_zigatecmd : [86] 0140 02cf940102040500000000000001 cf94 ZigateQueue: 73
2021-11-25 18:41:46.948 ZG1: (ZG1) WARNING - send_zigatecmd : [87] 0140 02cf940102000000000000000001 cf94 ZigateQueue: 74
2021-11-25 18:41:46.949 ZG1: (ZG1) WARNING - send_zigatecmd : [88] 0140 02cf940103000100000000000001 cf94 ZigateQueue: 75
2021-11-25 18:41:46.950 ZG1: (ZG1) WARNING - send_zigatecmd : [89] 0140 02cf940103040000000000000001 cf94 ZigateQueue: 76
2021-11-25 18:41:46.952 ZG1: (ZG1) WARNING - send_zigatecmd : [90] 0140 02cf940103000000000000000001 cf94 ZigateQueue: 77
2021-11-25 18:41:46.955 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0120 02cf9401010500000000000300300000003C0384000000310001003C0384000000190002003C038400000001 cf94 ZigateQueue: 77
2021-11-25 18:41:46.956 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0120 02cf94010100010000000002002900200E100E1000000001002100210E100E10000001 cf94 ZigateQueue: 77
2021-11-25 18:41:46.957 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0120 02cf94010100060000000001001000000001012C000001 cf94 ZigateQueue: 77
2021-11-25 18:41:46.958 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0120 02cf9401020402000000000100290000000A012C00000001 cf94 ZigateQueue: 77
2021-11-25 18:41:46.958 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0120 02cf94010200010000000002002900200E100E1000000001002100210E100E10000001 cf94 ZigateQueue: 77
2021-11-25 18:41:46.959 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0120 02cf9401020405000000000100210000003C038400000001 cf94 ZigateQueue: 77
2021-11-25 18:41:46.960 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0120 02cf94010304000000000001002100000005012C0000000F cf94 ZigateQueue: 77
2021-11-25 18:41:46.961 ZG1: (ZG1) WARNING - send_zigatecmd : [None] 0120 02cf94010300010000000002002900200E100E1000000001002100210E100E10000001 cf94 ZigateQueue: 77
2021-11-25 18:41:46.459 Status: ZG1: (ZG1) self.ListOfDevices[905c] removed! substitued by self.ListOfDevices[cf94]
2021-11-25 18:41:46.473 Status: ZG1: (ZG1) NetworkID: cf94 is replacing 905c for object: 14b457fffe0bdcab
2021-11-25 18:41:46.933 Status: ZG1: (ZG1) [0] NEW OBJECT: cf94 0xinDB - IAS Zone controler setting
2021-11-25 18:41:51.235 ZG1: (ZG1) Decode8095 - Model: TS0202 SQN: 18, Addr: cf94, Ep: 01, Cluster: 0006, Cmd: 01, Unknown: 02
2021-11-25 18:41:55.456 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Voltage-14b457fffe0bdcab-01) 0:0.0;0.0
2021-11-25 18:41:57.703 Error: ZG1: (ZG1) No transport, write directive to '192.168.1.74:63256' ignored.
2021-11-25 18:41:57.703 Error: ZG1: (ZG1) No transport, write directive to '192.168.1.74:63283' ignored.
2021-11-25 18:42:00.405 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Voltage-14b457fffe0bdcab-02) 0:0.0;0.0
2021-11-25 18:42:05.442 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Voltage-14b457fffe0bdcab-03) 0:0.0;0.0
2021-11-25 18:42:19.976 ZG1: (ZG1) readCluster - 0000 - cf94/01 unknown attribute: ffde 20 0001 0f
2021-11-25 18:42:28.071 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Temp+Hum-14b457fffe0bdcab-02) 0:0.0;54.3;1
2021-11-25 18:42:28.107 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Temp-14b457fffe0bdcab-02) 0.0:0.0
2021-11-25 18:42:32.076 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Temp+Hum-14b457fffe0bdcab-02) 0:0.0;0.0;2
2021-11-25 18:42:32.107 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Humi-14b457fffe0bdcab-02) 0.0:2
2021-11-25 18:42:33.050 ZG1: (ZG1) readCluster - 0405 - cf94/02 unknown attribute: 0001 21 0002 0000
2021-11-25 18:42:34.051 ZG1: (ZG1) readCluster - 0405 - cf94/02 unknown attribute: 0002 21 0002 0000
2021-11-25 18:42:35.047 ZG1: (ZG1) readCluster - 0405 - cf94/02 unknown attribute: fffd 21 0002 0002
2021-11-25 18:42:36.112 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 0:0
2021-11-25 18:42:37.101 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 0:0
2021-11-25 18:42:38.100 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 1000:1000
2021-11-25 18:42:39.087 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 1:1
2021-11-25 18:43:55.861 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Voltage-14b457fffe0bdcab-01) 0:28.0;28.0
2021-11-25 18:43:58.211 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 34:34
2021-11-25 18:45:18.292 ZG1: (ZG1) Decode8095 - Model: TS0202 SQN: 01, Addr: cf94, Ep: 01, Cluster: 0006, Cmd: 01, Unknown: 02
2021-11-25 18:45:18.326 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 32:32
2021-11-25 18:45:22.313 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Voltage-14b457fffe0bdcab-01) 0:30.0;30.0
2021-11-25 18:45:22.426 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Voltage-14b457fffe0bdcab-01) 0:28.0;28.0
2021-11-25 18:49:20.804 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 232:232
2021-11-25 18:50:19.086 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 25:25
2021-11-25 18:50:30.452 ZG1: (ZG1) Decode8095 - Model: TS0202 SQN: 21, Addr: cf94, Ep: 01, Cluster: 0006, Cmd: 00, Unknown: 02
2021-11-25 18:51:15.410 ZG1: (ZG1) Decode8095 - Model: TS0202 SQN: 23, Addr: cf94, Ep: 01, Cluster: 0006, Cmd: 01, Unknown: 02
2021-11-25 18:52:06.485 ZG1: (ZG1) Decode8095 - Model: TS0202 SQN: 27, Addr: cf94, Ep: 01, Cluster: 0006, Cmd: 00, Unknown: 02
2021-11-25 18:55:19.950 ZG1: (ZG1) UpdateDevice - (ZG1 - TS0202_Lux-14b457fffe0bdcab-03) 2:2
After reset of the sensor and re-pairing :
Humidity and temperature ar set to 0 and doesn't change.
pipiche
Post by pipiche »
can you kindly retrieve latest beta ( 5.2.298) restart the plugin and see if Temp, Humi are coming ?
If so, could you please remove all widgets and redo the pairing again
dondipietro
First, big thank you for your support !
With this update, Motion and tamper seems ok.
I loose LUX
and temperature humidity is not working.
Here is some error given by Zigate plugin when pairing and export object export.
Here is log output when unplug - plug the sensor :
2021-11-25 20:43:35.318 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 20:43:35.335 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 1:Tamper
2021-11-25 20:43:35.831 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 20:43:42.265 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 20:43:44.004 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 20:43:52.835 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 20:43:52.853 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 0:No Alert
2021-11-25 20:44:25.121 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 20:45:18.945 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 20:45:34.439 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 20:45:34.461 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 1:Tamper
2021-11-25 20:45:47.422 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 20:45:47.436 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 0:No Alert
2021-11-25 20:46:22.496 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 20:48:41.482 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 20:53:29.267 Status: Incoming connection from: 192.168.1.74
2021-11-25 20:53:42.334 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 20:58:43.195 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 21:03:44.116 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 21:08:45.013 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 21:13:45.921 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 21:18:36.158 Status: Incoming connection from: 192.168.1.74
2021-11-25 21:18:46.811 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 21:20:50.096 ZGbeta2: (ZGbeta2) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2021-11-25 21:20:50.096 ZGbeta2: (ZGbeta2) is_domoticz_db_available: True
2021-11-25 21:23:47.696 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 21:28:48.590 ZGbeta2: (ZGbeta2) UpdateDevice - (ZGbeta2 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 21:30:28.986 Status: Incoming connection from: 192.168.1.74
errors.txt
(47.47 KiB) Downloaded 97 times
export.txt
(8.09 KiB) Downloaded 89 times
pipiche
Post by pipiche »
Can you update the firmware of the ZiGate to the latest 320 ? This I think is preventing the Temp/Humi to work.
The error you have reported in the errors.txt are really weird. At what time did you get them ? During the pairing phase ?
pipiche
Post by pipiche »
So I have fixed the error issue, sorry for that it was a mistake on my end.
please update with a git pull to get 5.2.299
remove all widgets and then restart the plugin and finally redo the pairing
make sure to have firmware 320 on the ZiGate
dondipietro
Hello Again,
A lot of progress !
I use zigate v1 with firmware ZiGate_v3.20-OPDM.bin
Here is the result with the last test :
MOTION Sensor : OK
TAMPER : OK
TEMPERATURE : OK
HUMIDITY : OK
BATTERY Level : show 200% (I power it with usb not battery)
LUX sensor is missing, but it was OK with your first Beta version I tested, is it possible for you to make it work again ?
Output log : from pairing then with a restart of the sensor.
2021-11-25 23:29:08.923 Status: ZG_beta4: (ZG_beta4) Request Accepting new Hardware for ever
2021-11-25 23:29:09.103 Status: ZG_beta4: (ZG_beta4) Accepting new Hardware: Enable (On)
2021-11-25 23:29:24.408 ZG_beta4: (ZG_beta4) --> Adding device 336b in self.DevicesInPairingMode
2021-11-25 23:29:24.409 ZG_beta4: (ZG_beta4) --> ['336b']
2021-11-25 23:29:24.410 Status: ZG_beta4: (ZG_beta4) [None] NEW OBJECT: 336b None
2021-11-25 23:29:24.986 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Active Endpoint Response Ep: 01 LQI: 246
2021-11-25 23:29:24.986 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Active Endpoint Response Ep: 02 LQI: 246
2021-11-25 23:29:24.986 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Active Endpoint Response Ep: 03 LQI: 246
2021-11-25 23:29:24.987 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Request Simple Descriptor for Ep: 01
2021-11-25 23:29:24.987 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Request Simple Descriptor for Ep: 02
2021-11-25 23:29:24.988 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Request Simple Descriptor for Ep: 03
2021-11-25 23:29:25.306 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Simple Descriptor Response EP: 0x01 LQI: 243
2021-11-25 23:29:25.306 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b ProfileID 0104
2021-11-25 23:29:25.306 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b ZDeviceID 0402
2021-11-25 23:29:25.307 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Application Version 0001
2021-11-25 23:29:25.307 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster IN Count: 04
2021-11-25 23:29:25.307 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 1: 0000 (Basic)
2021-11-25 23:29:25.308 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 2: 0001 (Power Configuration)
2021-11-25 23:29:25.308 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 3: 0500 (IAS Zone)
2021-11-25 23:29:25.308 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 4: ef00
2021-11-25 23:29:25.308 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster OUT Count: 02
2021-11-25 23:29:25.309 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-11-25 23:29:25.309 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster Out 2: 000a (Time)
2021-11-25 23:29:25.410 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Simple Descriptor Response EP: 0x02 LQI: 246
2021-11-25 23:29:25.410 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b ProfileID 0104
2021-11-25 23:29:25.410 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b ZDeviceID 0302
2021-11-25 23:29:25.411 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Application Version 0001
2021-11-25 23:29:25.411 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster IN Count: 03
2021-11-25 23:29:25.411 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 1: 0001 (Power Configuration)
2021-11-25 23:29:25.411 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 2: 0402 (Temperature Measurement)
2021-11-25 23:29:25.412 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 3: 0405 (Relative Humidity Measurement)
2021-11-25 23:29:25.412 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster OUT Count: 00
2021-11-25 23:29:26.068 ZG_beta4: (ZG_beta4) Request Basic Manufacturer via Read Attribute request: 0004
2021-11-25 23:29:26.083 ZG_beta4: (ZG_beta4) EP: {'01': {'0000': {}, '0001': {}, '0500': {}, 'ef00': {}, '0019': {}, '000a': {}}, '02': {'0001': {}, '0402': {}, '0405': {}}, '03': {}}
2021-11-25 23:29:26.085 Status: ZG_beta4: (ZG_beta4) [None] NEW OBJECT: 336b Request Node Descriptor
2021-11-25 23:29:26.546 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Simple Descriptor Response EP: 0x03 LQI: 246
2021-11-25 23:29:26.546 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b ProfileID 0104
2021-11-25 23:29:26.547 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b ZDeviceID 0106
2021-11-25 23:29:26.547 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Application Version 0001
2021-11-25 23:29:26.547 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster IN Count: 02
2021-11-25 23:29:26.547 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 1: 0001 (Power Configuration)
2021-11-25 23:29:26.548 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster In 2: 0400 (Illuminance Measurement)
2021-11-25 23:29:26.548 Status: ZG_beta4: (ZG_beta4) [-] NEW OBJECT: 336b Cluster OUT Count: 00
2021-11-25 23:29:31.103 ZG_beta4: (ZG_beta4) binding_needed_clusters_with_zigate 336b based on Device Configuration
2021-11-25 23:29:31.104 ZG_beta4: (ZG_beta4) 336b Binding cluster based on Conf: []
2021-11-25 23:29:31.185 ZG_beta4: (ZG_beta4) is_domoticz_db_available: Fashion: True , Major: 2021, Minor: 1
2021-11-25 23:29:31.185 ZG_beta4: (ZG_beta4) is_domoticz_db_available: True
2021-11-25 23:29:31.690 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:29:31.700 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 0:No Alert
2021-11-25 23:29:31.064 Status: ZG_beta4: (ZG_beta4) [1] NEW OBJECT: 336b Model Name: TS0202-_TZ3210_jijr1sss
2021-11-25 23:29:31.160 Status: ZG_beta4: (ZG_beta4) [1] NEW OBJECT: 336b 0xCreateDB - IAS Zone controler setting
2021-11-25 23:29:36.041 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:0.0;50;1
2021-11-25 23:29:36.081 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Temp-14b457fffe0bdcab-02) 0.0:0.0
2021-11-25 23:29:37.064 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:0.0;0.0;2
2021-11-25 23:29:37.080 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Humi-14b457fffe0bdcab-02) 0.0:2
2021-11-25 23:29:41.127 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:29:41.142 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 1:Tamper
2021-11-25 23:30:07.029 Error: ZG_beta4: (ZG_beta4) No transport, write directive to '192.168.1.74:56345' ignored.
2021-11-25 23:30:07.029 Error: ZG_beta4: (ZG_beta4) No transport, write directive to '192.168.1.74:56344' ignored.
2021-11-25 23:30:09.283 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 23:30:09.305 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 0:No Alert
2021-11-25 23:30:50.934 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:30:55.122 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:30:55.143 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 1:Tamper
2021-11-25 23:31:05.179 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:31:05.201 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 0:No Alert
2021-11-25 23:31:13.864 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:31:15.179 ZG_beta4: (ZG_beta4) tuya_response - Model: TS0202-_TZ3210_jijr1sss UNMANAGED Nwkid: 336b/01 dp: 6e data type: 2 data: 00000064
2021-11-25 23:31:17.599 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.8;0.0;2
2021-11-25 23:31:17.615 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Temp-14b457fffe0bdcab-02) 23.8:23.8
2021-11-25 23:31:17.620 ZG_beta4: (ZG_beta4) tuya_response - Model: TS0202-_TZ3210_jijr1sss UNMANAGED Nwkid: 336b/01 dp: 6b data type: 2 data: 000000ee
2021-11-25 23:31:18.825 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.8;51;1
2021-11-25 23:31:18.842 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Humi-14b457fffe0bdcab-02) 51:1
2021-11-25 23:31:18.845 ZG_beta4: (ZG_beta4) tuya_response - Model: TS0202-_TZ3210_jijr1sss UNMANAGED Nwkid: 336b/01 dp: 6c data type: 2 data: 00000033
2021-11-25 23:31:57.785 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 23:31:57.807 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 0:No Alert
2021-11-25 23:33:12.820 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 23:33:12.842 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 1:Tamper
2021-11-25 23:33:13.029 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:33:22.882 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:33:22.905 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 0:No Alert
2021-11-25 23:33:54.432 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:33:55.748 ZG_beta4: (ZG_beta4) tuya_response - Model: TS0202-_TZ3210_jijr1sss UNMANAGED Nwkid: 336b/01 dp: 6e data type: 2 data: 00000064
2021-11-25 23:33:56.235 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 23:33:57.564 ZG_beta4: (ZG_beta4) tuya_response - Model: TS0202-_TZ3210_jijr1sss UNMANAGED Nwkid: 336b/01 dp: 6b data type: 2 data: 000000ee
2021-11-25 23:33:58.748 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.8;46;1
2021-11-25 23:33:58.764 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Humi-14b457fffe0bdcab-02) 46:1
2021-11-25 23:33:58.767 ZG_beta4: (ZG_beta4) tuya_response - Model: TS0202-_TZ3210_jijr1sss UNMANAGED Nwkid: 336b/01 dp: 6c data type: 2 data: 0000002e
2021-11-25 23:35:09.423 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 0:Off
2021-11-25 23:35:09.446 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 1:Tamper
2021-11-25 23:35:09.531 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:35:43.275 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:35:43.298 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 0:No Alert
2021-11-25 23:36:17.124 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-25 23:36:17.147 ZG_beta4: (ZG_beta4) UpdateDevice - (ZG_beta4 - TS0202-_TZ3210_jijr1sss_Tamper-14b457fffe0bdcab-01) 1:Tamper
pipiche
Post by pipiche »
Can you do me a favor:
retrieve the latest beta, remove the widget , restart the plugin, redo the pairing ( but before enable the following debug parameters (from the WebUI > Tools )
debugCluster
debugTuya
then drop me the all debug logs ...
Yo should get the Lux back and the battery should be better. I need to understand something better as regards to Temp and Humi
dondipietro
I think everything look OK with this version.
Here is the log file :
2021-11-26 12:07:52.235 Status: ZGbeta5: (ZGbeta5) Entering work loop.
2021-11-26 12:07:52.235 Status: ZGbeta5: (ZGbeta5) Started.
2021-11-26 12:07:53.027 Status: ZGbeta5: (ZGbeta5) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) channel set to 11
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) filename set to /home/tdp/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-08.json
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) pluginHome set to /home/tdp/domoticz/plugins/Domoticz-Zigate/
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) homedirectory set to /home/tdp/domoticz/plugins/Domoticz-Zigate/
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) pluginData set to /home/tdp/domoticz/plugins/Domoticz-Zigate/Data/
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) pluginConfig set to /home/tdp/domoticz/plugins/Domoticz-Zigate/Conf/
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) pluginOTAFirmware set to /home/tdp/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) pluginReports set to /home/tdp/domoticz/plugins/Domoticz-Zigate/Reports/
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) pluginWWW set to /home/tdp/domoticz/plugins/Domoticz-Zigate/www/
2021-11-26 12:07:53.032 Status: ZGbeta5: (ZGbeta5) pluginLogs set to /home/tdp/domoticz/plugins/Domoticz-Zigate/Logs/
2021-11-26 12:07:53.038 Status: ZGbeta5: (ZGbeta5) Zigate plugin beta-5.2.302 started
2021-11-26 12:07:53.066 Status: ZGbeta5: (ZGbeta5) DeviceConf loaded - 24 confs loaded
2021-11-26 12:07:53.238 Status: ZGbeta5: (ZGbeta5) DeviceConf loaded - 306 confs loaded
2021-11-26 12:07:53.238 Status: ZGbeta5: (ZGbeta5) load ListOfDevice
2021-11-26 12:07:53.277 Status: ZGbeta5: (ZGbeta5) 2 Entries loaded from /home/tdp/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-8.txt
2021-11-26 12:07:53.278 Status: ZGbeta5: (ZGbeta5) Transport mode: USB
2021-11-26 12:07:53.781 Status: ZGbeta5: (ZGbeta5) ZigateTransport: Serial Connection open: Serial<id=0x6b9d1d50, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-11-26 12:07:53.784 Status: ZGbeta5: (ZGbeta5) ZigateTransport: writer_thread Thread start.
2021-11-26 12:07:53.786 Status: ZGbeta5: (ZGbeta5) ZigateTransport: thread_processing_and_sending Thread start.
2021-11-26 12:07:53.787 Status: ZGbeta5: (ZGbeta5) Start Web Server connection
2021-11-26 12:07:53.802 Status: ZGbeta5: (ZGbeta5) Web backend for Web User Interface started on port: 9440
2021-11-26 12:07:57.157 Status: ZGbeta5: (ZGbeta5) ==> Transport Mode switch to full mode
2021-11-26 12:07:57.160 Status: ZGbeta5: (ZGbeta5) ZiGate Classic PDM (OptiPDM)
2021-11-26 12:07:57.161 Status: ZGbeta5: (ZGbeta5) Installer Version Number: 0320
2021-11-26 12:07:57.161 Status: ZGbeta5: (ZGbeta5) Branch Version: ==> Production <==
2021-11-26 12:08:02.091 Status: ZGbeta5: (ZGbeta5) Erase Zigate PDM
2021-11-26 12:08:02.472 Status: ZGbeta5: (ZGbeta5) ZiGate PDM loaded
2021-11-26 12:08:02.475 Status: ZGbeta5: (ZGbeta5) 'Factory new' Restart status: STARTUP
2021-11-26 12:08:07.174 Status: ZGbeta5: (ZGbeta5) ZiGate Classic PDM (OptiPDM)
2021-11-26 12:08:07.175 Status: ZGbeta5: (ZGbeta5) Installer Version Number: 0320
2021-11-26 12:08:07.176 Status: ZGbeta5: (ZGbeta5) Branch Version: ==> Production <==
2021-11-26 12:08:17.079 Status: ZGbeta5: (ZGbeta5) ZigateConf - Setting extPANID : 0x0000000000000000
2021-11-26 12:08:17.080 Status: ZGbeta5: (ZGbeta5) ZigateConf setting Channel(s) to: 11
2021-11-26 12:08:17.080 Status: ZGbeta5: (ZGbeta5) setChannel - Channel set to : 00000800
2021-11-26 12:08:17.081 Status: ZGbeta5: (ZGbeta5) Force ZiGate to Normal mode
2021-11-26 12:08:17.081 Status: ZGbeta5: (ZGbeta5) Start network
2021-11-26 12:08:17.082 Status: ZGbeta5: (ZGbeta5) Set Zigate as a TimeServer
2021-11-26 12:08:17.839 Status: ZGbeta5: (ZGbeta5) Start Network - Formed new network
2021-11-26 12:08:17.840 Status: ZGbeta5: (ZGbeta5) Zigate details IEEE: 00158d0001ee8471, NetworkID: 0000, Channel: 11, Status: 01: Success
2021-11-26 12:08:17.842 Status: ZGbeta5: (ZGbeta5) Accepting new Hardware: Disable (Off)
2021-11-26 12:08:17.960 Status: ZGbeta5: (ZGbeta5) Zigate addresses ieee: 00158d0001ee8471 , short addr: 0000
2021-11-26 12:08:17.961 Status: ZGbeta5: (ZGbeta5) Network state UP, PANID: beb2 extPANID: 0x3519f26fc984b81b Channel: 11
2021-11-26 12:08:18.812 Error: ZGbeta5: (ZGbeta5) No transport, write directive to '192.168.1.74:63287' ignored.
2021-11-26 12:08:18.812 Error: ZGbeta5: (ZGbeta5) No transport, write directive to '192.168.1.74:63288' ignored.
2021-11-26 12:08:22.087 Status: ZGbeta5: (ZGbeta5) Request Disabling Accepting new Hardware
2021-11-26 12:08:22.487 Status: ZGbeta5: (ZGbeta5) Accepting new Hardware: Disable (Off)
2021-11-26 12:08:27.057 Status: ZGbeta5: (ZGbeta5) Zigate set to Certification : CE
2021-11-26 12:08:27.064 Status: ZGbeta5: (ZGbeta5) Plugin with Zigate (OptiPDM), firmware 0320 correctly initialized
2021-11-26 12:08:27.250 Status: ZGbeta5: (ZGbeta5) TxPower Attenuation: 0 dBm
2021-11-26 12:09:35.072 Status: ZGbeta5: (ZGbeta5) Erase Log History
2021-11-26 12:09:38.035 Status: ZGbeta5: (ZGbeta5) Erase Log History
2021-11-26 12:09:51.581 Status: ZGbeta5: (ZGbeta5) Request Accepting new Hardware for ever
2021-11-26 12:09:51.775 Status: ZGbeta5: (ZGbeta5) Accepting new Hardware: Enable (On)
2021-11-26 12:10:00.864 Status: ZGbeta5: (ZGbeta5) [None] NEW OBJECT: 6a5c None
2021-11-26 12:10:01.844 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Active Endpoint Response Ep: 01 LQI: 201
2021-11-26 12:10:01.845 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Active Endpoint Response Ep: 02 LQI: 201
2021-11-26 12:10:01.845 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Active Endpoint Response Ep: 03 LQI: 201
2021-11-26 12:10:01.845 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Request Simple Descriptor for Ep: 01
2021-11-26 12:10:01.846 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Request Simple Descriptor for Ep: 02
2021-11-26 12:10:01.846 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Request Simple Descriptor for Ep: 03
2021-11-26 12:10:02.874 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Simple Descriptor Response EP: 0x01 LQI: 201
2021-11-26 12:10:02.875 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c ProfileID 0104
2021-11-26 12:10:02.875 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c ZDeviceID 0402
2021-11-26 12:10:02.875 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Application Version 0001
2021-11-26 12:10:02.876 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster IN Count: 04
2021-11-26 12:10:02.876 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 1: 0000 (Basic)
2021-11-26 12:10:02.876 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 2: 0001 (Power Configuration)
2021-11-26 12:10:02.876 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 3: 0500 (IAS Zone)
2021-11-26 12:10:02.877 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 4: ef00
2021-11-26 12:10:02.877 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster OUT Count: 02
2021-11-26 12:10:02.877 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-11-26 12:10:02.878 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster Out 2: 000a (Time)
2021-11-26 12:10:03.904 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Simple Descriptor Response EP: 0x02 LQI: 204
2021-11-26 12:10:03.905 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c ProfileID 0104
2021-11-26 12:10:03.905 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c ZDeviceID 0302
2021-11-26 12:10:03.905 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Application Version 0001
2021-11-26 12:10:03.906 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster IN Count: 03
2021-11-26 12:10:03.906 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 1: 0001 (Power Configuration)
2021-11-26 12:10:03.906 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 2: 0402 (Temperature Measurement)
2021-11-26 12:10:03.907 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 3: 0405 (Relative Humidity Measurement)
2021-11-26 12:10:03.907 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster OUT Count: 00
2021-11-26 12:10:04.878 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Simple Descriptor Response EP: 0x03 LQI: 201
2021-11-26 12:10:04.878 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c ProfileID 0104
2021-11-26 12:10:04.878 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c ZDeviceID 0106
2021-11-26 12:10:04.879 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Application Version 0001
2021-11-26 12:10:04.879 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster IN Count: 02
2021-11-26 12:10:04.879 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 1: 0001 (Power Configuration)
2021-11-26 12:10:04.880 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster In 2: 0400 (Illuminance Measurement)
2021-11-26 12:10:04.880 Status: ZGbeta5: (ZGbeta5) [-] NEW OBJECT: 6a5c Cluster OUT Count: 00
2021-11-26 12:10:07.129 Status: ZGbeta5: (ZGbeta5) [None] NEW OBJECT: 6a5c Request Node Descriptor
2021-11-26 12:10:12.090 Status: ZGbeta5: (ZGbeta5) [2] NEW OBJECT: 6a5c Model Name: TS0202-_TZ3210_jijr1sss
2021-11-26 12:10:12.091 Status: ZGbeta5: (ZGbeta5) [None] NEW OBJECT: 6a5c Request Node Descriptor
2021-11-26 12:10:12.188 Status: ZGbeta5: (ZGbeta5) [2] NEW OBJECT: 6a5c 0xCreateDB - IAS Zone controler setting
2021-11-26 12:12:08.852 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6e dt: 02 data: 00000064
2021-11-26 12:12:08.853 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Model: TS0202-_TZ3210_jijr1sss Unknow Nwkid: 6a5c/01 dp: 6e data type: 2 data: 00000064
2021-11-26 12:12:10.034 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 6259
2021-11-26 12:12:10.035 ZGbeta5: (ZGbeta5) readCluster - 0400 - 6a5c/03 Attr: 0000 Type: 21 Size: 0002 6259
2021-11-26 12:12:10.035 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 - LUX Sensor: 25177/329
2021-11-26 12:12:10.052 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Lux-14b457fffe0bdcab-03) 329:329
2021-11-26 12:12:11.255 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6b dt: 02 data: 000000e7
2021-11-26 12:12:11.256 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Temperature 231
2021-11-26 12:12:11.272 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.1;0.0;2
2021-11-26 12:12:11.288 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp-14b457fffe0bdcab-02) 23.1:23.1
2021-11-26 12:12:12.439 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6c dt: 02 data: 0000002f
2021-11-26 12:12:12.439 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Humidity 47
2021-11-26 12:12:12.454 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.1;47;1
2021-11-26 12:12:12.471 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Humi-14b457fffe0bdcab-02) 47:1
2021-11-26 12:14:18.620 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-26 12:14:18.763 ZGbeta5: (ZGbeta5) ReadCluster - 0001 - 6a5c/01 AttrId: 0021 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: c8
2021-11-26 12:14:18.763 ZGbeta5: (ZGbeta5) readCluster 0001 - 6a5c Battery Percentage: 200
2021-11-26 12:14:18.763 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss mainVolt:None , battVolt:None, battRemainingVolt: 28.0, battRemainPer:200.0
2021-11-26 12:14:18.764 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss Updating battery 100 to 100
2021-11-26 12:14:18.775 ZGbeta5: (ZGbeta5) ReadCluster - 0001 - 6a5c/01 AttrId: 0020 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 1c
2021-11-26 12:14:18.775 ZGbeta5: (ZGbeta5) readCluster 0001 - 6a5c Battery: 28 V
2021-11-26 12:14:18.781 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss mainVolt:None , battVolt:None, battRemainingVolt: 28.0, battRemainPer:200.0
2021-11-26 12:14:18.781 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss Updating battery 100 to 100
2021-11-26 12:14:19.932 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6e dt: 02 data: 00000064
2021-11-26 12:14:19.932 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Model: TS0202-_TZ3210_jijr1sss Unknow Nwkid: 6a5c/01 dp: 6e data type: 2 data: 00000064
2021-11-26 12:14:21.166 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 3b77
2021-11-26 12:14:21.166 ZGbeta5: (ZGbeta5) readCluster - 0400 - 6a5c/03 Attr: 0000 Type: 21 Size: 0002 3b77
2021-11-26 12:14:21.167 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 - LUX Sensor: 15223/33
2021-11-26 12:14:21.183 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Lux-14b457fffe0bdcab-03) 33:33
2021-11-26 12:14:22.335 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6b dt: 02 data: 000000e8
2021-11-26 12:14:22.335 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Temperature 232
2021-11-26 12:14:22.350 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.2;47;1
2021-11-26 12:14:22.366 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp-14b457fffe0bdcab-02) 23.2:23.2
2021-11-26 12:14:23.561 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6c dt: 02 data: 0000002e
2021-11-26 12:14:23.561 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Humidity 46
2021-11-26 12:14:23.577 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.2;46;1
2021-11-26 12:14:23.593 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Humi-14b457fffe0bdcab-02) 46:1
2021-11-26 12:19:19.491 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-26 12:19:19.643 ZGbeta5: (ZGbeta5) ReadCluster - 0001 - 6a5c/01 AttrId: 0021 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: c8
2021-11-26 12:19:19.644 ZGbeta5: (ZGbeta5) readCluster 0001 - 6a5c Battery Percentage: 200
2021-11-26 12:19:19.644 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss mainVolt:None , battVolt:None, battRemainingVolt: 28.0, battRemainPer:200.0
2021-11-26 12:19:19.644 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss Updating battery 100 to 100
2021-11-26 12:19:19.655 ZGbeta5: (ZGbeta5) ReadCluster - 0001 - 6a5c/01 AttrId: 0020 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 1c
2021-11-26 12:19:19.656 ZGbeta5: (ZGbeta5) readCluster 0001 - 6a5c Battery: 28 V
2021-11-26 12:19:19.661 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss mainVolt:None , battVolt:None, battRemainingVolt: 28.0, battRemainPer:200.0
2021-11-26 12:19:19.662 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss Updating battery 100 to 100
2021-11-26 12:19:20.807 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6e dt: 02 data: 00000064
2021-11-26 12:19:20.807 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Model: TS0202-_TZ3210_jijr1sss Unknow Nwkid: 6a5c/01 dp: 6e data type: 2 data: 00000064
2021-11-26 12:19:22.040 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 3a47
2021-11-26 12:19:22.040 ZGbeta5: (ZGbeta5) readCluster - 0400 - 6a5c/03 Attr: 0000 Type: 21 Size: 0002 3a47
2021-11-26 12:19:22.041 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 - LUX Sensor: 14919/31
2021-11-26 12:19:22.057 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Lux-14b457fffe0bdcab-03) 31:31
2021-11-26 12:19:23.204 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6b dt: 02 data: 000000e7
2021-11-26 12:19:23.204 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Temperature 231
2021-11-26 12:19:23.219 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.1;46;1
2021-11-26 12:19:23.235 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp-14b457fffe0bdcab-02) 23.1:23.1
2021-11-26 12:19:24.433 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6c dt: 02 data: 0000002e
2021-11-26 12:19:24.433 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Humidity 46
2021-11-26 12:24:20.381 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-26 12:24:20.530 ZGbeta5: (ZGbeta5) ReadCluster - 0001 - 6a5c/01 AttrId: 0021 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: c8
2021-11-26 12:24:20.530 ZGbeta5: (ZGbeta5) readCluster 0001 - 6a5c Battery Percentage: 200
2021-11-26 12:24:20.530 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss mainVolt:None , battVolt:None, battRemainingVolt: 28.0, battRemainPer:200.0
2021-11-26 12:24:20.531 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss Updating battery 100 to 100
2021-11-26 12:24:20.541 ZGbeta5: (ZGbeta5) ReadCluster - 0001 - 6a5c/01 AttrId: 0020 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 1c
2021-11-26 12:24:20.542 ZGbeta5: (ZGbeta5) readCluster 0001 - 6a5c Battery: 28 V
2021-11-26 12:24:20.547 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss mainVolt:None , battVolt:None, battRemainingVolt: 28.0, battRemainPer:200.0
2021-11-26 12:24:20.548 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss Updating battery 100 to 100
2021-11-26 12:24:21.697 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6e dt: 02 data: 00000064
2021-11-26 12:24:21.698 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Model: TS0202-_TZ3210_jijr1sss Unknow Nwkid: 6a5c/01 dp: 6e data type: 2 data: 00000064
2021-11-26 12:24:22.933 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 3daa
2021-11-26 12:24:22.934 ZGbeta5: (ZGbeta5) readCluster - 0400 - 6a5c/03 Attr: 0000 Type: 21 Size: 0002 3daa
2021-11-26 12:24:22.934 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 - LUX Sensor: 15786/37
2021-11-26 12:24:22.951 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Lux-14b457fffe0bdcab-03) 37:37
2021-11-26 12:24:24.107 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6b dt: 02 data: 000000e6
2021-11-26 12:24:24.107 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Temperature 230
2021-11-26 12:24:24.123 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:23.0;46;1
2021-11-26 12:24:24.139 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp-14b457fffe0bdcab-02) 23.0:23.0
2021-11-26 12:24:25.341 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6c dt: 02 data: 0000002e
2021-11-26 12:24:25.342 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Humidity 46
2021-11-26 12:29:21.254 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Motion-14b457fffe0bdcab-01) 1:On
2021-11-26 12:29:21.404 ZGbeta5: (ZGbeta5) ReadCluster - 0001 - 6a5c/01 AttrId: 0021 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: c8
2021-11-26 12:29:21.404 ZGbeta5: (ZGbeta5) readCluster 0001 - 6a5c Battery Percentage: 200
2021-11-26 12:29:21.405 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss mainVolt:None , battVolt:None, battRemainingVolt: 28.0, battRemainPer:200.0
2021-11-26 12:29:21.405 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss Updating battery 100 to 100
2021-11-26 12:29:21.416 ZGbeta5: (ZGbeta5) ReadCluster - 0001 - 6a5c/01 AttrId: 0020 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 1c
2021-11-26 12:29:21.416 ZGbeta5: (ZGbeta5) readCluster 0001 - 6a5c Battery: 28 V
2021-11-26 12:29:21.422 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss mainVolt:None , battVolt:None, battRemainingVolt: 28.0, battRemainPer:200.0
2021-11-26 12:29:21.422 ZGbeta5: (ZGbeta5) readCluster 0001 - Device: 6a5c Model: TS0202-_TZ3210_jijr1sss Updating battery 100 to 100
2021-11-26 12:29:22.569 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6e dt: 02 data: 00000064
2021-11-26 12:29:22.569 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Model: TS0202-_TZ3210_jijr1sss Unknow Nwkid: 6a5c/01 dp: 6e data type: 2 data: 00000064
2021-11-26 12:29:23.803 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 3f47
2021-11-26 12:29:23.803 ZGbeta5: (ZGbeta5) readCluster - 0400 - 6a5c/03 Attr: 0000 Type: 21 Size: 0002 3f47
2021-11-26 12:29:23.804 ZGbeta5: (ZGbeta5) ReadCluster - 0400 - 6a5c/03 - LUX Sensor: 16199/41
2021-11-26 12:29:23.820 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Lux-14b457fffe0bdcab-03) 41:41
2021-11-26 12:29:24.976 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6b dt: 02 data: 000000e5
2021-11-26 12:29:24.977 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Temperature 229
2021-11-26 12:29:24.992 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp+Hum-14b457fffe0bdcab-02) 0:22.9;46;1
2021-11-26 12:29:25.008 ZGbeta5: (ZGbeta5) UpdateDevice - (ZGbeta5 - TS0202-_TZ3210_jijr1sss_Temp-14b457fffe0bdcab-02) 22.9:22.9
2021-11-26 12:29:26.211 ZGbeta5: (ZGbeta5) tuya_response - Model: TS0202-_TZ3210_jijr1sss Nwkid: 6a5c/01 dp: 6c dt: 02 data: 0000002e
2021-11-26 12:29:26.212 ZGbeta5: (ZGbeta5) tuya_smart_motion_all_in_one - Humidity 46
2021-11-26 12:29:53.096 Status: Incoming connection from: 192.168.1.74
pipiche
Post by pipiche »
well done !
thanks for your support
dondipietro
Domoticz version: 2021.1
Post by dondipietro »
Congratulation to You Pipiche, Good job.
Thank you very much for this excellent support and reactivity.
Do you think about pushing this beta test in the next stable version ?
Is there a risk to loose previous zigbee paired device with Zigate using this beta ?
