Telldus Mini PIR-sensor 433 Mhz - strange problems
Andee78
Post by Andee78 »
I have installed this PIR sensor and there were no problems. The strange thing is, as soon as it turns on, it turns on all NEXA switches here at home, even though I do not have an activated script for this. Whatever I do, it continues with this. Has anyone been to similar or have any suggestions on what I can do? Have tried to change the battery, removed it and added it several times without success.
The sensor appears as Lightning 2, AC. I use RFXtrxXL.
erem
Domoticz version: 2021.1
Re: Telldus Mini PIR-sensor 433 Mhz - strange problems
Post by erem »
have you already tried shutting down domoticz/RFXtrxXL to see if it is direct interaction between the pir and the nexa switches?
anything visible in the domoticz log?
Regards,
Rob
Andee78
Post by Andee78 »
erem wrote: Tuesday 09 November 2021 16:18 have you already tried shutting down domoticz/RFXtrxXL to see if it is direct interaction between the pir and the nexa switches?
Thanks... Just tried stop domoticz service (and also disable RFXtrxXL) and yes, the PIR-sensor switches all my switches to ON... :geek:
How is this possible?
Andee78
Post by Andee78 »
I have tried to "relearn" my nexa switches with different codes and then it works. Pretty strange in my opinion....
erem
Post by erem »
glad to hear you solved it.
i also do not have an explanation for this.
Regards,
Rob
