I have installed this PIR sensor and there were no problems. The strange thing is, as soon as it turns on, it turns on all NEXA switches here at home, even though I do not have an activated script for this. Whatever I do, it continues with this. Has anyone been to similar or have any suggestions on what I can do? Have tried to change the battery, removed it and added it several times without success.
The sensor appears as Lightning 2, AC. I use RFXtrxXL.
Telldus Mini PIR-sensor 433 Mhz - strange problems
- erem
- Domoticz version: 2021.1
Re: Telldus Mini PIR-sensor 433 Mhz - strange problems
have you already tried shutting down domoticz/RFXtrxXL to see if it is direct interaction between the pir and the nexa switches?
anything visible in the domoticz log?
Regards,
Rob
Rob
Andee78
Thanks... Just tried stop domoticz service (and also disable RFXtrxXL) and yes, the PIR-sensor switches all my switches to ON...erem wrote: Tuesday 09 November 2021 16:18 have you already tried shutting down domoticz/RFXtrxXL to see if it is direct interaction between the pir and the nexa switches?
How is this possible?
Andee78
I have tried to "relearn" my nexa switches with different codes and then it works. Pretty strange in my opinion....
- erem
glad to hear you solved it.
i also do not have an explanation for this.
Regards,
Rob
Rob
