Edit switch activates device?
sciurius
Domoticz version: 2021.1
Post by sciurius »
I have a witch device (lamp) with two timers.
When I click on the first timer, e.g. to change it, the lamp immedeately switches on. One minute later, another "on" event is generated.
Strangely, when I click on the second timer, no "off" events are generated.
Is this normal behaviour?
sammyke007
Domoticz version: 2022.1
Re: Edit switch activates device?
Post by sammyke007 »
I can confirm this. When editing timers with an ON command, the light turns on after clicking the rule.
sciurius
Post by sciurius »
Do you also get the second 'ON' after 64 seconds?
sciurius
Post by sciurius »
Worse: The 'off' function of the timer doesn't seem to work at all. The lamp switches on as instructed but the off timer never goes off.
I can switch the lamp off (and on) from the widget on the 'Switches' panel without problems.
The lamp is connected via the Tuya plugin.
sciurius
Post by sciurius »
The last couple of days the 'off' timer has worked properly so there may be something else going on. Small disruptions in connectivity, maybe.
user4563
Domoticz version: 2025.2
Post by user4563 »
Just to add, I am on the same v 2021.1 but on Windows not RPi and couldn't recreate this.
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
Domoticz version: 2025.1
Could be feedback of MQTT or python plugin.
