I have a witch device (lamp) with two timers.
When I click on the first timer, e.g. to change it, the lamp immedeately switches on. One minute later, another "on" event is generated.
Strangely, when I click on the second timer, no "off" events are generated.
Is this normal behaviour?
Edit switch activates device?
sammyke007
- Domoticz version: 2022.1
Re: Edit switch activates device?
I can confirm this. When editing timers with an ON command, the light turns on after clicking the rule.
sciurius
- Domoticz version: 2021.1
Do you also get the second 'ON' after 64 seconds?
sciurius
Worse: The 'off' function of the timer doesn't seem to work at all. The lamp switches on as instructed but the off timer never goes off.
I can switch the lamp off (and on) from the widget on the 'Switches' panel without problems.
The lamp is connected via the Tuya plugin.
sciurius
The last couple of days the 'off' timer has worked properly so there may be something else going on. Small disruptions in connectivity, maybe.
- user4563
- Domoticz version: 2026.4
Just to add, I am on the same v 2021.1 but on Windows not RPi and couldn't recreate this.
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
- Domoticz version: 2026.3
Could be feedback of MQTT or python plugin.
