Tuya TS0601 no value from Temperature
lostodos
Post by lostodos »
Hi everyone,
I have a Tuya TS0601 thermostat valve - my pizigate (v1) does pick it up and provides me with three widgets in Domoticz. One of them is temperature (of the sensor in the valve) but stays at 0 degrees. I can see that the status is updated on a regular basis but the value in Domoticz doesn't change and stays at zero.
Does anyone have an idea on what might be wrong or what to try next? I have deleted the devices in Domoticz and paired the device again a few times already but without success.
More information at the end of this message.
All help is appreciated!
- Plugin version: 5.1.013
- ZiGate firmware and model: Pizigate v1 (Firmware 0320)
- export.json => see attachment
export.json.txt
Plugin raw devices json file
(36.96 KiB) Downloaded 92 times
pipiche
Re: Tuya TS0601 no value from Temperature
Post by pipiche »
could you please try thes latest plugin version
lostodos
Post by lostodos »
Hi Pipiche,
I have updated the plugin to version 5.1.014 but with the same result unfortunately. I think the Tuya device is sending updates (not sure what data it is sending though) but they are not showing in Domoticz (other then the timestamp that is updated):
I have added the export json again as well in case you might need it, see attachment
Regards,
Mark
export.json.txt
(35.05 KiB) Downloaded 100 times
pipiche
Post by pipiche »
Can you try to remove All related widgets, and redo the pairing of the device
lostodos
Post by lostodos »
That did the trick! I can read the temperature now as well as the setpoint! Nice one:)
The timers that are provisioned by Domoticz for both setpoint and mode don't seem to work however....if i set a timer for setting a new setpoint it doesn't seem to change it on the TRV but when i change it manually on the widget then it does....
Any idea what could cause this?
pipiche
Post by pipiche »
If you set a Setpoint in Domoticz, is that updated on the TRV ?
lostodos
Post by lostodos »
Yes it is updated on the TRV if i set the new setpoint manually (meaning with the up/down arrows of the widget). If i use the timer function it will not update the temperature (not in the widget and not on the TRV).
pipiche
Post by pipiche »
The timer function is a pure Domoticz stuff. No clue how does it works.
lostodos
Post by lostodos »
No worries:) Thanks a lot for your help!
lostodos
Post by lostodos »
Just as a follow up - been reading through other articles and setting timers requires a few minutes to initiate. If i set timers at least 5 minutes ahead then they have time to initialize and they work.
mitkodotcom
Post by mitkodotcom »
I have absolutely the same problem with Tuya TS0601 fan coil thermostat (this one: https://www.aliexpress.com/item/1005003 ... 18025QFLdO)
I'm using the latest plugin and firmware form Zigate+. The plugin adds three widgets:
Zigate - TS0601_Temp-8cf681fffef8ceb0-01
Zigate - TS0601_ThermoSetpoint-8cf681fffef8ceb0-01
Zigate - TS0601_ThermoMode_2-8cf681fffef8ceb0-01
but there's no further communication in any direction.
I have tried to remove and add the device several times, but to no avail.
2022-05-27 13:38:44.858 Status: Zigate: onDeviceRemoved - removing End Device
2022-05-27 13:38:44.859 Status: Zigate: onDeviceRemoved - removing End Device
2022-05-27 13:38:44.861 Status: Zigate: onDeviceRemoved - removing End Device
2022-05-27 13:38:44.898 Status: Zigate: Device Zigate - TS0601_ThermoMode_2-8cf681fffef8ceb0-01 with IEEE: 8cf681fffef8ceb0 fully removed from the system.
2022-05-27 13:38:44.900 Status: Zigate: onDeviceRemoved - removing Device Zigate - TS0601_ThermoMode_2-8cf681fffef8ceb0-01 -> 8cf681fffef8ceb0 in Zigate
2022-05-27 13:38:44.970 Status: Zigate: Decode8047 - Leave response, LQI: 97 Status: 00 - [00] Success
2022-05-27 13:38:45.072 Status: Zigate: (dd4b/8cf681fffef8ceb0) send a Leave indication and will be outside of the network. LQI: 0
2022-05-27 13:38:54.492 Status: Zigate: Request Accepting new Hardware for 240 seconds
2022-05-27 13:38:54.674 Status: Zigate: Accepting new Hardware: Enable (On)
2022-05-27 13:39:20.181 Status: Zigate: [None] NEW OBJECT: 14ec None
2022-05-27 13:39:20.340 Status: Zigate: [-] NEW OBJECT: 14ec Active Endpoint Response Ep: 01 LQI: 95
2022-05-27 13:39:20.343 Status: Zigate: [-] NEW OBJECT: 14ec Request Simple Descriptor for Ep: 01
2022-05-27 13:39:20.608 Status: Zigate: [-] NEW OBJECT: 14ec Simple Descriptor Response EP: 0x01 LQI: 95
2022-05-27 13:39:20.609 Status: Zigate: [-] NEW OBJECT: 14ec ProfileID 0104
2022-05-27 13:39:20.610 Status: Zigate: [-] NEW OBJECT: 14ec ZDeviceID 0051
2022-05-27 13:39:20.610 Status: Zigate: [-] NEW OBJECT: 14ec Application Version 0001
2022-05-27 13:39:20.611 Status: Zigate: [-] NEW OBJECT: 14ec Cluster IN Count: 04
2022-05-27 13:39:20.612 Status: Zigate: [-] NEW OBJECT: 14ec Cluster In 1: 0000 (Basic)
2022-05-27 13:39:20.613 Status: Zigate: [-] NEW OBJECT: 14ec Cluster In 2: 0004 (Groups)
2022-05-27 13:39:20.613 Status: Zigate: [-] NEW OBJECT: 14ec Cluster In 3: 0005 (Scenes)
2022-05-27 13:39:20.614 Status: Zigate: [-] NEW OBJECT: 14ec Cluster In 4: ef00
2022-05-27 13:39:20.615 Status: Zigate: [-] NEW OBJECT: 14ec Cluster OUT Count: 02
2022-05-27 13:39:20.616 Status: Zigate: [-] NEW OBJECT: 14ec Cluster Out 1: 0019 (Over-the-Air Upgrade)
2022-05-27 13:39:20.617 Status: Zigate: [-] NEW OBJECT: 14ec Cluster Out 2: 000a (Time)
2022-05-27 13:39:24.389 Status: Zigate: [0] NEW OBJECT: 14ec Model Name: TS0601
2022-05-27 13:39:24.390 Status: Zigate: [0] NEW OBJECT: 14ec Manufacturer Name: _TZE200_dzuqwsyg
2022-05-27 13:39:24.391 Status: Zigate: [None] NEW OBJECT: 14ec Request Node Descriptor
Is this type of thermostats supported by the plugin?
pipiche
Post by pipiche »
Don't know which version of the plugin you are, what is the Coordinator model you are using.
If you are on stable6 branch ( Version 6.1 ), please move to beta6 and redo the all pairing with the beta6.2.060
to move to beta6 from stable6
git checkout betat6
if you are not yet on stable6, please follow https://zigbeefordomoticz.github.io/wik ... ion-6.html
mitkodotcom
I'm on the stable branch (6.1.005) with Zigate+
I have just found the solution: It looks it's just another manufacturer and I just had to add
"_TZE200_dzuqwsyg",
to
TUYA_THERMOSTAT_MANUFACTURER = (
in Modules/tuya.py
pipiche
Post by pipiche »
