Topology report in Zigate plugin
JanZorz
Post by JanZorz »
Hey,
I vaguely remember that the solution to this was posted somewhere in the past, but I can't find it anymore.
Problem at hand is Zigate Topology scan. All of a sudden it just shows me z a Zigate controller and two random sensors connected to it and not the rest of the network.
Plugin: 5.2.089
Anyone remembers how to fix this issue?
Cheers and thnx, Jan
Domoticz version: 2026.3
Re: Topology report in Zigate plugin
go to the Zigate dasboard - Settings, enable advanced setings and enabled "displaySibling" in the Web Ui settings section, this will make the graph much complete.
JanZorz
Post by JanZorz »
Hey, thnx for answer.
I went into settings and this option was already enabled, see the attached picture. I disabled it, saved config and enabled it again (and again saved config), did another Topology scan - but still the same result :(
Screenshot 2021-10-08 at 19.06.25.png (50.38 KiB) Viewed 545 times
I tried it just now with plugin 5.2.100 and I see the same, no battery nodes and 2 battery nodes floating around. So it seems to be a bug in the dashboard....
JanZorz
Post by JanZorz »
waltervl wrote: Friday 08 October 2021 20:12 I tried it just now with plugin 5.2.100 and I see the same, no battery nodes and 2 battery nodes floating around. So it seems to be a bug in the dashboard....
Thnx for confirmation... maybe pipiche might have more insight?
Cheers, Jan
