Recently i bought a EcoDim ED-10017 wireless zwave switch dimmer it is not recognized when i add it to the z-wave network it is listed ad Unknown.
It looks like this switch is the same as the Sunricher sr-zv9001k2-dim but is has a different product id. The sunricher is listed as :
<Product config="sunricher/srzv9001k2dim.xml" id="a30f" name="Wall Controller - SR-ZV9001K2-DIM" type="0300"/>
the manufacturer id of this switch is 0x0330 (the same as sunricher)
The Product type ID is 0x0003
The product ID is 0xa307
I tried to edit this manual in the manufacterer_specific.xml and added the sunricher/srzv9001k2dim.xml file but the switch is not working.
Is there anybody out there who can help solve this issue ?
Thx
Z-Wave support for EcoDim ED-10017 Wall switch Dimmer
- Target OS: -
- Domoticz version: 4.11590
Re: Z-Wave support for EcoDim ED-10017 Wall switch Dimmer
Did you get this controller to work?
Using Zwave, Philips Hue, Raspberry Pi, Machinon Theme
I used your approach and created an xml file and entry for the wall switch. I rebooted the system and it is now "recognized"... But it does not change a thing really.
What I noticed is that the "Last Seen" updates for the correct device when I click a button, but no data change, nor any data logged.
Is there a way to implement better support for this device myself??
I could also build something that assumes a button pressed when Last Seen is changed for a device. Not pretty, but will work.
Ok, found a way to work around this:
I named the buttons $RemoteOn and $RemoteOff (The $ hides the buttons from the switches screen). I can tell which is which, by the Last Updated field that updates when I press each button (in the Settings -> Devices list). Based on that I created two simple DzVents scripts:
devices = { '$RemoteOn' }
logging = {
level = domoticz.LOG_INFO,
marker = 'ED-10018 Wall Switch',
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
domoticz.groups('Verlichting Paarden').switchOn()
and its counterpart:
devices = { '$RemoteOff' }
logging = {
domoticz.groups('Verlichting Paarden').switchOff()
logging = {
logging = {
One last thing: I updated the manufacturer xml, but I also copied the srzv9001k2dim.xml file and changed the product id in there, to match this device.
