Looking for dewpoint
jkimmel
- Domoticz version: 2021.1
I'm not sure whether my temperature sensor provides a dewpoint.
How could I check this?
Rfxcom
Raspi 4
Raspi 4
- Domoticz version: 2025.1
Re: Looking for dewpoint
A dew point is only available when also humidity is known. So if you have a combined Temp/humidity sensor a dew point can be calculated and displayed.
Why is your question in dzVents subforum and not in temperature and weather?
jkimmel
Sorry, you are right. But I was looking for using the dewpoint in a dzVents Script, that's the reason. Sorry again.
Rfxcom
Raspi 4
Raspi 4
rrozema
Both on a temphum and a temperture, humidity, barometer device the property dewPoint is available (https://www.domoticz.com/wiki/DzVents:_ ... _scripting, then search for dewpoint)
If you've got a separate temperature and relative humidity value, you can theoretically calculate the dewpoint.http://www.wettermail.de/wetter/feuchte.html (site in German) has some formulas. I went through them a long time ago to calculate the absolute humidity, but I totally forgot how I did it and I don't have the time to put this one into code too. You can try for yourself...
- FireWizard
Hello @jkimmel,
As @rrozema already said, if you intend to use a combined temperature/humidity and/or barometer device, Domoticz will calculate the dew point itself.
However, if you have separated values and want to calculate the dew point yourself, in order to send it e.g to a "Custom sensor", called "Dew Point", you may find some useful information at: https://bmcnoldy.rsmas.miami.edu/Humidity.html
Especialy look to the "Spreadsheet-ready equations" and you will find the corrct formula.
I used it in a Node Red flow once, with the following Javascript code in a " Function" node.
Of course, you can use this formula in any script language, you prefer.
function dewpoint(T,RH) {
var TD = 243.04 * (Math.log(RH/100)+((17.625*T)/(243.04+T)))/(17.625-Math.log(RH/100)-((17.625*T)/(243.04+T)));
return TD;
msg.payload = {"command":"udevice","idx":13584,"nvalue":0,"svalue":dewpoint(msg.payload.temperature,msg.payload.humidity).toString()};
return msg;Regards
jkimmel
My sensor delivers combined temp/humidity as well as two separate values for temp and humidity.rrozema wrote: Sunday 12 September 2021 7:48 Both on a temphum and a temperture, humidity, barometer device the property dewPoint is available (https://www.domoticz.com/wiki/DzVents:_ ... _scripting, then search for dewpoint)
Domoticz is calculating the dewpoint, see here: So i defined
local dewpoint = dz.devices(TEMPERATURE_SENSOR).dewPoint
dz.log('Current dewpoint: ' .. dewpoint, dz.LOG_INFO)Code: Select all
2021-09-13 11:57:00.569 Error: dzVents: Error: (3.1.7) ...z/scripts/dzVents/generated_scripts/Klima Wohnzimmer.lua:52: attempt to concatenate a nil value (local 'dewpoint')Rfxcom
Raspi 4
Raspi 4
rrozema
Have you tried .dewPoint as per the documentation? Lua is case sensitive.
jkimmel
As you can see above the local variable dewpoint is defined asrrozema wrote: Monday 13 September 2021 12:16 Have you tried .dewPoint as per the documentation? Lua is case sensitive.
local dewpoint = dz.devices(TEMPERATURE_SENSOR).dewPointRfxcom
Raspi 4
Raspi 4
rrozema
local TEMPERATURE_SENSOR = 'Woonkamer: TempHum'
timer = {
'every minute'
logging = {
level = domoticz.LOG_INFO,
marker = 'test',
local sensor_device = domoticz.devices(TEMPERATURE_SENSOR)
if nil == sensor_device then
domoticz.log('Device ' .. TEMPERATURE_SENSOR .. ' not found.', domoticz.LOG_ERROR)
local dewpoint = sensor_device.dewPoint
domoticz.log('"' .. sensor_device.name .. '" : ' .. sensor_device.deviceType .. ', dewpoint = ' .. tostring(dewpoint) .. '.', domoticz.LOG_ERROR)
sensor_device.dump()
}For me the output is:
- Spoiler: show
Works for me too:rrozema wrote: Monday 13 September 2021 20:30
Please try the above. It should not give the previous error. instead this either lists the dewpoint value or the message that your device was not found. Given of course you change the name in the top of the script to the name of your temphum sensor. Plus, it dumps all of your sensor's properties so you can check their value.
2021-09-13 21:08:00.517 Error: dzVents: Error: (3.1.7) test: "Buiten TempHumBaro" : Temp + Humidity + Baro, dewpoint = 11.939999580383.
