Electricity Current/Ampere 3 Phase IPX800V3 + X400CT
laco
Domoticz version: 2021.1
Post by laco »
I would need to convert this LUA script to DzVents.
Can anyone help me?
-- Odber 3 fázy
--time=os.date("*t")
IDX=44 --virtual CM113, Electrisave
IDX_D=40 --darling
json = (loadfile "/volume1/docker/domoticz/config/scripts/lua/JSON.lua")()  -- For Synology Linux
local config=assert(io.popen('/usr/bin/curl "http://login:[email protected]/api/xdevices.json?cmd=30"'))
local blocjson = config:read('*all')
 config:close()
 -- print (blocjson)
 local jsonValeur = json:decode(blocjson)
-- if time.min%2==0 then --[2min  test]--
faza1=(tonumber(jsonValeur.AN6)/310) --faza1 on IPX800V3
faza2=(tonumber(jsonValeur.AN7)/310) --faza2 on IPX800V3
faza3=(tonumber(jsonValeur.AN8)/310) --faza3 on IPX800V3
darling=(tonumber(jsonValeur.AN5)/310) --darling
print ('faza1 : ' .. faza1) --prints a value.
print ('faza2 : ' .. faza2) --prints a value.
print ('faza3 : ' .. faza3) --prints a value.
print ('darling : ' .. darling) --prints a value.
commandArray[1]={['UpdateDevice'] = IDX .."|0|"..faza1..";"..faza2..";"..faza3..";"}
commandArray[2]={['UpdateDevice'] = IDX_D .."|0|"..darling..";"}
--end
Domoticz version: 2025.1
Re: Electricity Current/Ampere 3 Phase
Could be based on something like this
https://domoticz.com/forum/viewtopic.ph ... 44#p237144
You can reuse your own json parsing logic.
laco
Post by laco »
Use this command to read data from my IPX800 V3, X400-CT:
http://192.168.1.120/api/xdevices.json?cmd=30
{"product":"IPX800_V3","AN1":766,"AN2":62,"AN3":190,"AN4":65,"AN5":0,"AN6":823,"AN7":1269,"AN8":1548,"AN9":0,"AN10":0,"AN11":0,"AN12":0,"AN13":0,"AN14":0,"AN15":0,"AN16":0}
I have an analog phase sampling sensor in Amperes there.
AN6 = PHASE1
AN7 = PHASE2
AN8 = PHASE3
I need to write data to the virtual sensor IDX:44 CM113, Electrisave
Thanks for help
dzVents is based on Lua so some things be the same.
Take the script I referred to and copy the json parsing logic into it.
You need .updateCurrent(current1, current2, current3) to update your 3Phase Current device (idx 44)
What kind of device is the darling? Check the update code for that in https://www.domoticz.com/wiki/DzVents:_ ... _scripting
laco
Post by laco »
I can't do it. :-(
What do you have now on code and what is the error?
laco
Post by laco »
The LUA script above gives me an error:
2021-09-02 17:35:00.770 Error: EventSystem: in Script #11 Odber 3 fázy: [string "-- Odber 3 fázy ..."]:8: attempt to call a nil value
I have Domoticz running in DOCKER https://hub.docker.com/r/domoticz/domoticz
It could be something like this.
Not tested!!!
local scriptVar = '3PhaseCurrent'
return
    on =
        timer =
            'every 5 minutes',
        httpResponses =
            scriptVar
    logging =
        level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
        marker = scriptVar,
    execute = function(dz, item)
        if item.isTimer then
            dz.openURL({
                url = 'http://192.168.1.120/api/xdevices.json?cmd=30',
                callback = scriptVar,
            return
        if (item.isHTTPResponse) then
          if item.ok then
 		--- do the parsing logic here
 		local jsonValeur  = item.json
		domoticz.log('3 Phase values = ' .. faza1 .. ' , ' .. faza2 .. ' , ' .. faza3, domoticz.LOG_INFO)
 		-- update devices here
 		domoticz.devices(44).updateCurrent(faza1, faza2, faza3) -- update IDX:44 CM113, Electrisave
 		-- domoticz.devices(40).update????(darling)  -- update command depends on device type. See dzVents Wiki
           dz.log('There was a problem handling the request', dz.LOG_ERROR)
           dz.log(item, dz.LOG_ERROR)
laco
Post by laco »
Prints an error:
2021-09-05 18:26:00.688 Error: dzVents: Error: (3.1.8) 3PhaseCurrent: An error occurred when calling event handler Odber 3 fazy
2021-09-05 18:26:00.689 Error: dzVents: Error: (3.1.8) 3PhaseCurrent: ...rdata/scripts/dzVents/generated_scripts/Odber 3 fazy.lua:41: attempt to index a nil value (global 'domoticz')
laco
Post by laco »
I enter in a web browser:
Print this text:
{"product":"IPX800_V3","AN1":805,"AN2":65,"AN3":202,"AN4":65,"AN5":0,"AN6":0,"AN7":14,"AN8":254,"AN9":0,"AN10":0,"AN11":0,"AN12":0,"AN13":0,"AN14":0,"AN15":0,"AN16":0}
As said the script was not tested. There were some inconsistencies in the dz/domoticz calls. I tried to fix them in the code below.
return
    on =
        timer =
            'every 5 minutes',
        httpResponses =
            scriptVar
    logging =
        marker = scriptVar,
            domoticz.openURL({
            return
          if item.ok then
			domoticz.log('There was a problem handling the request', dz.LOG_ERROR)
			domoticz.log(item, dz.LOG_ERROR)
laco
Post by laco »
It's working properly now.
Well thank you.
Is it possible to set it to write more often than 1 minute?
rrozema
Post by rrozema »
You still have some dz. in that code that needs to be replaced by domoticz.
return
    on =
        timer =
            'every 5 minutes',
        httpResponses =
            scriptVar
    logging =
        marker = scriptVar,
            domoticz.openURL({
            return
          if item.ok then
			domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
			domoticz.log(item, domoticz.LOG_ERROR)
And no, dzvents timers can't be set faster than once per minute. I think you may be able to do it though using command option .afterSec()), but i haven't tested it so I really don't know if below code actually works. But if it does work, it will query your device and update your device values in domoticz every 15 seconds. I also added .checkFirst() to the update statement, to prevent the values to be updated every 15 seconds even if no new value was read. Again, this is untested: see for yourself if it works. And please do let us know the results :-)
return
    on =
        timer =
            'every 1 minute',
        httpResponses =
            scriptVar
    logging =
        marker = scriptVar,
            domoticz.openURL({
            domoticz.openURL({
            }).afterSec(15)
            domoticz.openURL({
            }).afterSec(30)
            domoticz.openURL({
            }).afterSec(45)
            return
        elseif (item.isHTTPResponse) then
          if item.ok then
			domoticz.devices(44).updateCurrent(faza1, faza2, faza3).checkFirst() -- update IDX:44 CM113, Electrisave
However, dzvents may still not be the best solution for this, because this is actually an implementation of a hardware device. I think it should be possible to implement this using the http/https poller hardware. Using that method it is possible to trigger the refresh more often than once per minute, for example every 10 seconds is quite normal. An example of how this is done for another device can be found here (site is in Dutch, sorry) : https://www.connectix.nl/watermeter-uit ... -domoticz/
laco
Post by laco »
It works properly, writes every 15 seconds.
But it still displays an error in the log.
2021-09-09 17:23:00.835 Status: dzVents: Debug: - HTTPResponse: 3PhaseCurrent
2021-09-09 17:23:00.860 Status: dzVents: Info: Handling httpResponse-events for: "3PhaseCurrent"
2021-09-09 17:23:00.861 Status: dzVents: Info: 3PhaseCurrent: ------ Start internal script: Odber_phase_15s: HTTPResponse: "3PhaseCurrent"
2021-09-09 17:23:00.862 Status: dzVents: Info: 3PhaseCurrent: 3 Phase values = 0.0 , 0.045161290322581 , 0.75806451612903
2021-09-09 17:23:00.871 Status: dzVents: Debug: 3PhaseCurrent: Processing device-adapter for Fázy: 3-phase Ampere device adapter
2021-09-09 17:23:00.872 Status: dzVents: Info: 3PhaseCurrent: ------ Finished Odber_phase_15s
2021-09-09 17:23:00.872 Status: dzVents: !Info: 3PhaseCurrent: Debug: Writing module summary to /opt/domoticz/userdata/scripts/dzVents/module.log
2021-09-09 17:23:00.872 Error: dzVents: Error: (3.1.8) 3PhaseCurrent: An error occurred when calling event handler Odber_phase_15s
2021-09-09 17:23:00.872 Error: dzVents: Error: (3.1.8) 3PhaseCurrent: ...ta/scripts/dzVents/generated_scripts/Odber_phase_15s.lua:54: attempt to call a nil value (field 'checkFirst')
rrozema
Post by rrozema »
That's the 2nd addition I did: checking if the value has actually changed. Please remove the .checkFirst() from that code and see if works better then.
It should have worked, but apparently something's wrong, so better leave it off for now.
laco
Re: Electricity Current/Ampere 3 Phase IPX800V3 + X400CT
Post by laco »
Thank you very much.
Now it works perfectly.
I set every 5 seconds to write the value.
Here is my function code:
return
    on =
        timer =
            'every 1 minutes',
        httpResponses =
            scriptVar
    logging =
        marker = scriptVar,
            domoticz.openURL({
                url = 'http://login:[email protected]/api/xdevices.json?cmd=30',
            domoticz.openURL({
            }).afterSec(5)
             domoticz.openURL({
            }).afterSec(10)
             domoticz.openURL({
            }).afterSec(15)
             domoticz.openURL({
            }).afterSec(20)
             domoticz.openURL({
            }).afterSec(25)
            domoticz.openURL({
            }).afterSec(30)
             domoticz.openURL({
            }).afterSec(35)
             domoticz.openURL({
            }).afterSec(40)
            domoticz.openURL({
            }).afterSec(45)
             domoticz.openURL({
            }).afterSec(50)
             domoticz.openURL({
            }).afterSec(55)
            return
          if item.ok then
			phase1=(tonumber(jsonValeur.AN6)/310) --phase1 on IPX800V3
			phase2=(tonumber(jsonValeur.AN7)/310) --phase2 on IPX800V3
			phase3=(tonumber(jsonValeur.AN8)/310) --phase3 on IPX800V3
			domoticz.log('3 Phase values = ' .. phase1 .. ' , ' .. phase2 .. ' , ' .. phase3, domoticz.LOG_INFO)
			domoticz.devices(44).updateCurrent(phase1, phase2, phase3) -- update IDX:44 CM113, Electrisave
			domoticz.devices(40).updateCurrent(darling)  -- update command depends on device type. See dzVents Wiki
rrozema
Post by rrozema »
As I said, retrieving the values using dzVents is not the best idea. It works, but it may overload your system. Symptoms of an overloaded system can be: slow response of the domoticz UI site, long delays between clicking a button in Domoticz and the actual response of the device and vice versa, long delays between activating an actuator (f.e. a light switch) and the corresponding device in Domoticz showing the result, high cpu usage, high RAM usage, overheating, etc. And if you really go to far, you could even crash/freeze Domoticz. So I would suggest not to update as often as every 5 seconds. Plus, besides the potential performance issues, adding new values every 5 seconds makes your database grow very fast too.
You're better off implementing your interface using one of the "hardware" methods Domoticz provides. This can for example be the HTTP/HTTPS poller combined with a lua script, or a python hardware implementation. Those can achieve similar results, but they are meant to be run every so-many seconds, so they're probably better optimized for it. I can't give you much pointers how to exactly use those "hardware" methods, as I've myself not done this before either. I just want you to be aware that the way you're doing it now can potentially cause you other/future problems in your system.
I agree, especially for URL requests they can be high demanding on your system. dzVents luckily now supports asynchronous requests but setting it to 5 seconds is a little bit fast. Why do you need this? Looking at your graph there is no spike of 5 seconds. so 30 sec or 1 minute should be enough in monitoring your 3Phase usage. In the end, in the weekly/monthly/yearly overviews all the values of 1 day are recalculated and summarized to 1 daily value (containing min,max and average). So these 5 sec intervalls are only stored for max 7 days (depends on your Log settings in menu Setup-Settings)
laco
Post by laco »
My domoticz runs in DOCKER on SYNOLOGY NAS.
I'm testing it so far, but the CPU load and RAM consumption are very low.
The response is fast, there is no sign of slowing down.
It is important for me to know the immediate consumption in Wats.
2021-09-10 (1).png (32.32 KiB) Viewed 2547 times
laco
Post by laco »
I have one more question.
Can I modify the script to write only positive data?
For example, if 0 is darling so that it does not write it to the database.
Is it possible to create a separate script for DARLING?
