Background color of block must be color of light
Enz0jacco
just wondering, is anyone able to change the background color of a block to the color of the light?
so if the light are on and red the background should be red and if the lights are off the standard background color.
I posted the following question in another post but maybe I get a reaction in this post:
the garbage app is working great, I put a line break between the type of container and the date/day which makes the colon obsolete. Is there any way to remove the colon?
thanx in advance,
Jacco
- Dashticz jacco.jpg (178.56 KiB) Viewed 1567 times
Lokonli
Re: Background color of block must be color of light
You could set the background color via a getStatus function in custom.js. An example for device 20:
function getStatus_20(block){
var color = JSON.parse(block.device.Color);
if (block.device.Data=='On') {
var colorStr = `rgb(${color.r},${color.g},${color.b})`;
$(block.mountPoint + ' > div').css('background-color', colorStr)
$(block.mountPoint + ' > div').css('background-color', '')
Enz0jacco
I'll try this out 2night!
Enz0jacco
however the background is only changing when used in domoticz.
so for instance: if I use domoticz or google home to turn on the light the background is not changing.
is there anything to do about that?
thanx again!
Lokonli
if (block.device.Data!='Off') {
Enz0jacco
im getting the hang of it now so if u are up for another one
is the same possible with only WW light bulbs?
Lokonli
I guess ...Enz0jacco wrote: Sunday 22 November 2020 22:15 working like a charm! thank you so much.
I only have RGBWW device. Such a device contains the following Color value:
"Color" : "{\"b\":0,\"cw\":60,\"g\":0,\"m\":2,\"r\":0,\"t\":195,\"ww\":195}",
Normally the t value is the same as the ww value.
and cw + ww = 255
Yellow means no blue, so if you would like to change from light-blue to light- yellow you could use something like in the code below. Probably you have to scale the colors a bit:
var yellow=255;
var blue=255;
if (color.ww>128) //very warm, so reduce blue
blue = 255 - color.ww/2+64;
if (color.cw>128) //very cold, so reduce yellow
yellow = 255 - color.cw/2+64;
var colorStr = `rgb(${yellow},${yellow},${blue})`;
Maikel76
- Domoticz version: 2022.1
Hi Lokonli,Lokonli wrote: Sunday 22 November 2020 22:46I guess ...Enz0jacco wrote: Sunday 22 November 2020 22:15 working like a charm! thank you so much.
I only have RGBWW device. Such a device contains the following Color value:So instead of the r,g and b values, you can use the t -value (color temperature), cw value (cold white) or ww value (warm white).Code: Select all
and cw + ww = 255
First check whether your ww device also contains a color value with cw and ww values.Code: Select all
function getStatus_20(block){ var color = JSON.parse(block.device.Color); if (block.device.Data!='Off') { var yellow=255; var blue=255; if (color.ww>128) //very warm, so reduce blue blue = 255 - color.ww/2+64; if (color.cw>128) //very cold, so reduce yellow yellow = 255 - color.cw/2+64; var colorStr = `rgb(${yellow},${yellow},${blue})`; $(block.mountPoint + ' > div').css('background-color', colorStr) } else $(block.mountPoint + ' > div').css('background-color', '') }
I'm using a Philips hue light and am sure I have ww and cw values but unfortunately this code doesn't work on my running Dashticz 3.8.0.2 master
It would be more than awesome if I could make this work, I have a slider like a virtual dimmer device as block 44, could i use something like this then:
$('.block_44' + ' > div').css('background-color', colorStr)Thanks for your answer
Dashticz v3.10.7 Beta --Raspbian Buster
Maikel76
//add custom javascript in here //original
function afterGetDevices(){ //original
//function getStatus_42(block){
var devices = Domoticz.getAllDevices();
var couch = devices[42];
var kleur = parseInt(couch.Color);
if (couch.State=='Set Color') {
var yellow=255;
var blue=255;
if (kleur.ww>128) //very warm, so reduce blue
blue = 255 - kleur.ww/2+64;
if (kleur.cw>128) //very cold, so reduce yellow
yellow = 255 - kleur.cw/2+64;
$(block.mountPoint + ' > div').css('background-color', colorStr);
//else {
// $(block.mountPoint + ' > div').css('background-color', '');
} //original
Anyone has any idea??
Please help!
Lokonli
ok, let's try to do this step by step.Maikel76 wrote: Wednesday 11 August 2021 9:00 Tried the original script and a combination of other scripts but this is also not working (also with and without else statement and else with and without {} ):
Is the ' > div' still supported (and what does it do?)Code: Select all
//add custom javascript in here //original function afterGetDevices(){ //original //function getStatus_42(block){ var devices = Domoticz.getAllDevices(); var couch = devices[42]; var kleur = parseInt(couch.Color); if (couch.State=='Set Color') { var yellow=255; var blue=255; if (kleur.ww>128) //very warm, so reduce blue blue = 255 - kleur.ww/2+64; if (kleur.cw>128) //very cold, so reduce yellow yellow = 255 - kleur.cw/2+64; var colorStr = `rgb(${yellow},${yellow},${blue})`; $(block.mountPoint + ' > div').css('background-color', colorStr); } //else { // $(block.mountPoint + ' > div').css('background-color', ''); //} //} ... } //original
Please help!
Your Hue lamp is device 42 I guess.
Can you post the output of:
http://domoticz-ip:port/json.htm?type=devices&rid=42
Maikel76
Yes, that's correct, it's idx 42Lokonli wrote: Friday 13 August 2021 15:58ok, let's try to do this step by step.Maikel76 wrote: Wednesday 11 August 2021 9:00 Tried the original script and a combination of other scripts but this is also not working (also with and without else statement and else with and without {} ):
Please help!
This is my SJON output:
"ActTime" : 1628866206,
"AstrTwilightEnd" : "19:55",
"AstrTwilightStart" : "04:50",
"CivTwilightEnd" : "19:03",
"CivTwilightStart" : "05:42",
"DayLength" : "12:37",
"NautTwilightEnd" : "19:29",
"NautTwilightStart" : "05:16",
"ServerTime" : "2021-08-13 21:50:06",
"SunAtSouth" : "12:23",
"Sunrise" : "06:04",
"Sunset" : "18:41",
"app_version" : "2021.1",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Color" : "{\"b\":0,\"cw\":34,\"g\":0,\"m\":2,\"r\":0,\"t\":221,\"ww\":221}",
"CustomImage" : 0,
"Data" : "Set Color",
"Description" : "",
"DimmerType" : "abs",
"Favorite" : 1,
"HardwareDisabled" : false,
"HardwareID" : 7,
"HardwareName" : "HueBridge",
"HardwareType" : "Philips Hue Bridge",
"HardwareTypeVal" : 38,
"HaveDimmer" : true,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "1",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2021-08-13 18:41:04",
"Level" : 89,
"LevelInt" : 89,
"MaxDimLevel" : 100,
"Name" : "HueCouch",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" :
0
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Set Level: 89 %",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "WW",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Color Switch",
"TypeImg" : "dimmer",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "42"
"status" : "OK",
"title" : "Devices"
}Dashticz v3.10.7 Beta --Raspbian Buster
Lokonli
So replace the following line:
if (couch.Data=='Set Color') {
Maikel76
Thanks for your suggestion. Unfortunately it didn't work.
I also noticed the Color in the JSON output seems like JSON too, so, i tried
var kleur = JSON.parse(couch.Color);Do you have more suggestions?
Have a great Saturday
PS: I used the code that you quoted
Lokonli
Assuming that in CONFIG.js you use device 42 in a column, or defined a block like:
blocks[42] = {
title: 'My dimmer',
function getStatus_42(block) {
if (block.device.Data != 'Off') {
var yellow = 255;
var blue = 255;
if (color.ww > 128)
blue = 255 - color.ww / 2 + 64;
if (color.cw > 128)
yellow = 255 - color.cw / 2 + 64;
} else $(block.mountPoint + ' > div').css('background-color', '');
First try to get this working. After that we can change the behavior if needed.
Note: So don't use the afterGetDevices function hook for this. (the block parameter is not known. It's more difficult to find the exact device block in the browser window)
Maikel76
Absolutely awesome! It's working wowLokonli wrote: Saturday 14 August 2021 11:01 ok, let's restart.
Then add the following to custom.js:Code: Select all
blocks[42] = { title: 'My dimmer', ... }
This code is working. It will give the dimmer block in Dashticz a background color of more blue or more yellow, depending on the warm white/cold white slider.Code: Select all
function getStatus_42(block) { var color = JSON.parse(block.device.Color); if (block.device.Data != 'Off') { var yellow = 255; var blue = 255; if (color.ww > 128) //very warm, so reduce blue blue = 255 - color.ww / 2 + 64; if (color.cw > 128) //very cold, so reduce yellow yellow = 255 - color.cw / 2 + 64; var colorStr = `rgb(${yellow},${yellow},${blue})`; $(block.mountPoint + ' > div').css('background-color', colorStr); } else $(block.mountPoint + ' > div').css('background-color', ''); }
Ok, so if i want to change the slider and slider-button can i use
.ui-slider-horizontalAlso is it possible to use idx 44 for this? This is a virtual dimmer that has a level from 1-100 where 100 is 100 Kelvin and 1 is 1 Kelvin
This is the JSON output of that virtual dimmer:
"ActTime" : 1628946726,
"DayLength" : "12:36",
"NautTwilightEnd" : "19:28",
"ServerTime" : "2021-08-14 20:12:06",
"SunAtSouth" : "12:22",
"Sunset" : "18:41",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Set Level: 99 %",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"HardwareName" : "VirtualSwitches",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveGroupCmd" : true,
"ID" : "0001407C",
"Image" : "Light",
"LastUpdate" : "2021-08-14 20:12:00",
"Level" : 99,
"LevelInt" : 99,
"Name" : "Hue",
"PlanID" : "0",
"PlanIDs" :
0
"Status" : "Set Level: 99 %",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"Timers" : "false",
"Type" : "Light/Switch",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "44"
"status" : "OK",
"title" : "Devices"
}I calculate the kelvin color in a domoticz dzVents script from cc to input as value for idx 44 as follows;
colorcalc = math.floor((maxi-delta/2)+(delta/2)*math.cos((now-offset)*2*math.pi/periode)+0.5)
couch.setKelvin(colorcalc)
hue.setLevel(colorcalc)Then i have one last question. Is it also possible to change the % in this virtual dimmer idx44 to a the letter K? I tried that with the code in CUSTOM.js but it didnt work there. I tried
blocks[44] = {title: 'Hue', width: 8, unit: 'K', icon: 'fas fa-sun'}
Sorry for all questions but very happy already wirh this result
Lokonli
In principe yes. I found a small bug (getStatus function was called before the block was updated), so update to the latest beta version first.Maikel76 wrote: Saturday 14 August 2021 15:26 Absolutely awesome! It's working wow
Ok, so if i want to change the slider and slider-button can i useand another one for the slider-button for this?Code: Select all
After update you can add the following two lines to your code in custom.js:
$(block.mountPoint + ' .ui-slider-horizontal').css('background-color', colorStr);
$(block.mountPoint + ' .ui-slider-handle').css('background-color', colorStr);
Your device 44 contains the information in the field 'Level'.Maikel76 wrote: Saturday 14 August 2021 15:26 Also is it possible to use idx 44 for this? This is a virtual dimmer that has a level from 1-100 where 100 is 100 Kelvin and 1 is 1 Kelvin
This is the JSON output of that virtual dimmer:Maybe i could read the value of idx 42 as it is working now and change the .ui-slider-horizontal (?) color for this?Code: Select all
{ "ActTime" : 1628946726, "AstrTwilightEnd" : "19:55", "AstrTwilightStart" : "04:50", "CivTwilightEnd" : "19:03", "CivTwilightStart" : "05:42", "DayLength" : "12:36", "NautTwilightEnd" : "19:28", "NautTwilightStart" : "05:16", "ServerTime" : "2021-08-14 20:12:06", "SunAtSouth" : "12:22", "Sunrise" : "06:04", "Sunset" : "18:41", "app_version" : "2021.1", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "Set Level: 99 %", "Description" : "", "DimmerType" : "abs", "Favorite" : 1, "HardwareDisabled" : false, "HardwareID" : 4, "HardwareName" : "VirtualSwitches", "HardwareType" : "Dummy (Does nothing, use for virtual switches only)", "HardwareTypeVal" : 15, "HaveDimmer" : true, "HaveGroupCmd" : true, "HaveTimeout" : false, "ID" : "0001407C", "Image" : "Light", "IsSubDevice" : false, "LastUpdate" : "2021-08-14 20:12:00", "Level" : 99, "LevelInt" : 99, "MaxDimLevel" : 100, "Name" : "Hue", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "Status" : "Set Level: 99 %", "StrParam1" : "", "StrParam2" : "", "SubType" : "Switch", "SwitchType" : "Dimmer", "SwitchTypeVal" : 7, "Timers" : "false", "Type" : "Light/Switch", "TypeImg" : "dimmer", "Unit" : 1, "Used" : 1, "UsedByCamera" : false, "XOffset" : "0", "YOffset" : "0", "idx" : "44" } ], "status" : "OK", "title" : "Devices" }
I calculate the kelvin color in a domoticz dzVents script from cc to input as value for idx 44 as follows;Where couch is idx42, the Hue lamp and hue is the virtual dimmer that shows the hue color is KelvinCode: Select all
colorcalc = math.floor((maxi-delta/2)+(delta/2)*math.cos((now-offset)*2*math.pi/periode)+0.5) couch.setKelvin(colorcalc) hue.setLevel(colorcalc)
I do not understand exactly what you try to achieve:
1) set the background color of block 44 based on the value of device 44?
2) set the background color of block 44 based on the value of device 42?
3) set the background color of block 42 based on the value of device 44?
Add the following to the getStatus function in custom.js to create a custom title based on the device level:Then i have one last question. Is it also possible to change the % in this virtual dimmer idx44 to a the letter K? I tried that with the code in CUSTOM.js but it didnt work there. I triedThe unit: code isn't workingCode: Select all
block.title=block.device.Level;
hide_data: true
Maikel76
I updated and the .ui-slider-horizontal is working now, awesome!Lokonli wrote: Monday 16 August 2021 18:01
$(block.mountPoint + ' .ui-slider-horizontal').css('background-color', colorStr); $(block.mountPoint + ' .ui-slider-handle').css('background-color', colorStr);
The .ui-slider-handle i suppose it the small pinnbutton and it didnt change color, but i like how it looks this way so i don't need it
Then i tried to change the lightbulb with .fas.fa-lightbulb (and .fa-lightbulb) but it didn't work, i can change the background but this code doesn't work;
$(block.mountPoint + ' .fas.fa-lightbulb').css('color', colorStr);Nr 2 so the background colorcode calculated from idx 42 should be set as the backgroundcolor for idx 44Your device 44 contains the information in the field 'Level'.
I changed it to this and now it shows e.g. 7 KAdd the following to the getStatus function in custom.js to create a custom title based on the device level:and hide the default device info by adding the following to the block definition in CONFIG.js:Code: Select all
hide_data: true
block.title=block.device.Level+' K';So the endresult is that i have a slider background that changes color, but instead of it showing on idx 42 i would like that color on idx 44
Then if possible i would like to change the color of the lightbulb too.
I now have this setup (and disabled for this test);
.fas.fa-lightbulb {
color:#FFF8C6;
.far.fa-lightbulb {
color:#FFF8C6;
Edit: One more question: I see that the color disapears and a later re-apears, is that because the getStatus_42(block) function is not inside the afterGetDevices() function? Can it be changed to keep the color except when it's not 'Off' ?
This looks very promising and it is already looking awesome, thanks for all your help
Hope you can help me with my last questions
Maikel76
To answer my own question for anyone wants to try this:Edit: One more question: I see that the color disapears and a later re-apears, is that because the getStatus_42(block) function is not inside the afterGetDevices() function? Can it be changed to keep the color except when it's not 'Off' ?
rgb values divided gives unworkable values, so rounding them fixed the issue;
blue = blue.toFixed(0);
Working like a charm now, thanks again @lokonli
another (for me) neat feature I added is;
} else $(block.mountPoint + ' .ui-slider-horizontal').css('background-color', 'rgba(0,0,0,0.0)');Happy new year everyone
