Oficial Docker Container Topic is solved
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
knireis
Re: Oficial Docker Container
Post by knireis »
Chris12 wrote: Friday 07 May 2021 10:44 Some questions about the domoticz docker:
How can I create my own docker after installing some extra packages like:
- apt update
- apt install curl
- apt install python
- apt install python-requests
- apt-get install sudo
- apt-get install openssh-server
All needed for getting my scripts working.
How can I check for updates of domoticz?
I now run version 2021.1 (build 13243), will there be a pop-up notifiying me when a new version is available? Or is that a complete new docker image?
You mean you want to install those packages in the docker container? I did it with a switch in domoticz which is toggled automatically (with a dzvents script) after domoticz startsup. Then the switch triggers another script which installs the necessary packages.
Chris12
Domoticz version: 2021.1
Post by Chris12 »
Yes, I installed those packages in the docker container. and I'm looking for an easy way to do these steps whenever a new domoticz docker is available.
Can you share both scripts?
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
knireis
Post by knireis »
return
    on =
        system =
            'start',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'start',
    execute = function(dz)
        dz.devices('Linphone-S').switchOn().afterSec(20)
#!/bin/bash
apt update && apt -y dist-upgrade
apt install -y <here your packages>
exit
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
i think you can do it 2 ways
docker ps -a
docker commit [CONTAINER_ID] [new_image_name]
eg
docker commit a94eb9694608 domoticzname:13188
this will give you the new image name with all the apt-get changes you made
you can also save the current image to an external directory
eg
• docker save domoticz/domoticz:latest | gzip >/volume1/docker/images/domoticz13149-curl-nmap.tar.gz
i would never ever run an update from within the container
if the update fails or screws up things you do not have a working container anymore
always create a new version of the container by copying the settings and use the new image
this way you have a new container with a new version but still have the old container with the old version
parkerc
Post by parkerc »
Quick question ; how do you do a restart Domoticz when you’re running it via Docker.?
I can get to the command line via the following ..
 docker exec -it domoticz-bridge /bin/bash
But the standard approach below does not work, as sudo is not found ..
 sudo systemctl restart domoticz.service
pvklink
Domoticz version: latest b
Post by pvklink »
which image/docker did you use...
Jablotron connection, Ikea
knireis
Post by knireis »
parkerc wrote: Sunday 09 May 2021 12:41 Hi
maybe not a direct answer to your question, but why not restart the docker? does not take that much time
rezzalex
Post by rezzalex »
Hello everyone,
sorry if the question has already been raised previously.
Would that be possible to keep the "old" Build of DZ Beta to be able to roll back to a previous docker beta version in case of bugs?
I know I can keep my own dz docker image... but I would feel safer if I can retreive any version.
DAVIZINHO
Post by DAVIZINHO »
rezzalex wrote: Tuesday 25 May 2021 12:32 Hello everyone,
There is a issue with this suggestion, create more docker images, with stable. and maybe with all the betas or one before the last.
coment in the issue will be interesting
https://github.com/domoticz/domoticz/issues/4810
antonlamers
Post by antonlamers »
I want to instal a python plugin i have nu userdata directory were must i do it?
As you can see all my data is in another volume this is for resetting the raspberry pi i don't lose the data from the containers
i have this in my yml file:
# Domoticz
domoticz:
container_name: domoticz
image: domoticz/domoticz
ports:
- "8081:8080"
- "6144:6144"
- "1443:1443"
volumes:
- ./volumes/domoticz/data:/config
restart: unless-stopped
environment:
- PUID=1000
- PGID=1000
- TZ= Europe/Amsterdam
devices:
- /dev/ttyAMA0
- /dev/ttyS0
- /dev/ttyACM0
- /dev/ttyACM1
- /dev/ttyUSB0
Greating,
Anton
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
Volumes should be defined as:
volumes:
- <path to domoticz volume>:/opt/domoticz/userdata
eg
- ./volumes/domoticz/data:/opt/domoticz/userdata
antonlamers
Thanks, yes i ssee now te plugin directory
can i remove this line?:
That line was an example from IOTstack. https://github.com/SensorsIot/IOTstack
Greating,
Anton
Version: 2023.2
antonlamers
another question,
i want to add plugin manager or this 2 plugins: wled and deconz plugin's
how must i do this in the conrtainer?
Greating,
Anton
Version: 2023.2
antonlamers wrote: Monday 05 July 2021 14:12 Hi,
Yes, delete that line as that refers to another (non official) domoticz docker image.
I am not sure plugin manager is docker compatible.
You have to enter the docker image and do the installations from the command line within the Domoticz docker installation if extra Python modules are needed. If not you can also install them outside the docker in the <path to domoticz volume>/plugins. After a restart of Domoticz it should see the plugins.
DAVIZINHO
Post by DAVIZINHO »
Hello.
the docker container have this variable: EXRA_CMD_ARG
someone know what is this? what do?
DAVIZINHO wrote: Sunday 18 July 2021 17:30 Hello.
Here you can put extra Domoticz command line arguments https://www.domoticz.com/wiki/Command_line_parameters
DAVIZINHO
Post by DAVIZINHO »
waltervl wrote: Sunday 18 July 2021 18:46
Thanks for the info.
I want to lauch a script first time the container runs, lile he init file in the Linuxserver dockers, i thinks this will be similar but not :-(
anton
Post by anton »
Now must I set up the network in the compose file?
I have a domoticz container with MQTT port 1883 enabled and a mosquito container
Domoticz say error: MQTT: Connecting to 192.178.1.5:1883
2021-08-04 19:16:18.466 Error: MQTT Gateway: MQTT: Failed to start, return code: 14 (Check IP/Port)
I think that mosquito and domoticz each have another ip adres. The raspberry where the docker is running has 192.178.1.5
JackD
Post by JackD »
To check your Mosquito you can use the mqtt-explorer (http://mqtt-explorer.com/).
Great Windows tool to check your how your Mosquitto server is running.
If Mosquitto and Domoticz are on the same IP then sometimes entering "127.0.0.1"(local) in Domoticz as the IP of the Mosquitto MQTT server will do the trick.
And there are also a few option in the Mosquitto settings file(mosquitto.conf) you have to make, depending on how you set up your system.
Users browsing this forum: Henielma and 1 guest
