Factory reset for tkb home TZ68E socket?
SilverShaded
I cant find a way to do factory reset, so after doing a hardware reset on a Razberry most of my sockets seem to useless Junk. Anyone got any suggestions please?
- deejc
- Domoticz version: 3.5641
Re: Factory reset for tkb home TZ68E socket?
Google for the manual I found it on the first link
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
SilverShaded
Yeah thanks, but the manual doesn't say how to do a factory reset, unless you picked up the TZ88E manual buy mistake.
- deejc
I looked at the vesternet site and they have a manual for the one you mention, it states in that manual how it resets if it's excluded from the network, I also know that nearly all zwave devices need a triple push in the button to include/exclude them, in this case the manual states "hitting the button one time" starts inc/exclusion
SilverShaded
It's allready included on another netwrk which is now dead, i therefore need to be able to do factory reset from the device itself...
- deejc
Press button 3 times in 2 seconds, within 1 second, press button again and hold for 5 seconds until led goes off, then reinclude into the new network
- deejc
I'm sure mine is the same type of plug and I'm sure this is what i did
SilverShaded
Ok, i think i got it working. Had to exclude it from the new network, (even though it didnt belong to that network) before including it... After doing that it worked pretty smoothly. At the back of my mind i was thinking it either had to be factory reset at the switch, or excluded from the old controller first. Apparently that wasnt neccessary.
- deejc
Good news, so the one button push is the right option even with another zwave network! Strange but good to know
DrSamJames
Just wanted to say thanks. I had the same problem a TZ68E TKBHOME plug that was registered to a dead network. Tired the reset so many times, but running my new zwave controller in exclusion mode press the button three time, then going into inclusion mode and 3 presses worked!
Sam
Sam
LordLiverpool
Same here. I was ready to throw away my three TKB sockets. The official reset procedure may have worked with one of them - I'm not sure at this point. This post saved me.
