3 position switch with a bathroom fan
jochem25
Domoticz version: 2021.1
Post by jochem25 »
I want to switch my bathroom fan remotely (and intelligent) with domoticz. So i thought about buying a kaku ACM-3500-2 switch and an aeotec multisensor. The fan had also 3 wires / positions, but I am reading in the manual that I can put only at 1 port at a time 230v.
I am a bit afraid that when an off signal from rfxcom433 is not recieved by the kaku switch that there is power on two wires, what will damage the fan.
does anybody know a good solution for this?
Ron
Domoticz version: 2.2284
Re: 3 position switch with a bathroom fan
Post by Ron »
Maybe you can use a blinds switch (rolluik schakelaar).
This kind of switche only connect contact one or two, never two at the same time.
jochem25
Post by jochem25 »
good idea, thanks!
Treve
Domoticz version: v4.11474
Post by Treve »
jochem25 wrote:Hi,
Do you have a Itho fan? If yes, is hi-low not enough?
In my case it’s sufficient.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
jochem25
Post by jochem25 »
I have a Ruck tube fan for my bathroom.
hi-low is enough, I don`t need three positions
Treve
Post by Treve »
Now you have to know how the fan electrical works before you can manage a solution.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
jochem25
Post by jochem25 »
the electrical scheme is quit simpel:
it doesn`t need a pwm.
With the blinds switch it will work. I need only 1 and 3
Treve
Post by Treve »
I think the simplest solution is to use a cheap Zigbee or more expensive Z-Wave switch that drives a normal 220 volt relay with changeover contact.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
