Calculate daily kWh based on a cumulative kWh device
riko
Post by riko »
I would like to have a device that is showing the daily production of my solar panels to present in Dashticz. I'm using the Omnik-Data-Logger python script to retrieve the data from the inverter. Unfortunately this one only communicates TOTAL kWh produced (since installation). This is imported in a General / Custom sensor:
Now I'm struggling with a script that calculates the daily production on the basis of the kWh value midnight. I am thinking to use a script to log persistant kWh data during 24 hours. And use the getAtTime function to retrieve value of 00:00 and substract that from the actual reading. The plan is to use dz.time do determine the number of hours and minutes which was midnight. It sounds easy but I get lost in the time formatting. Can anyone help with this? (or is there even a simpeler solution for this challenge?)
What I have so far:
return
    active = true,
      devices = {
                    23 -- IDX van Productie zonnepanelen in totale kwh
    logging =
        level = domoticz.LOG_DEBUG, -- change to LOG_ERROR when OK - was LOG_DEBUG
        marker = 'kwh_calc'
    data =
        production_store =
            history = true,
            maxHours = 25,
            maxItems = 7500,
    execute = function(dz, item)
		local round = dz.utils.round
		local Time                              = require('Time')
     		local currentTime                       = Time(dz.time.raw)
		-- begin script
        	local total_production = dz.devices(23)   -- IDX van Productie zonnepanelen in kwh
        	local daily_production = dz.devices(315)   -- IDX van Productie dummy sensor voor daily production
		local lastProductionWatt = round(tonumber(total_production.rawData[1]),1)
		dz.data.production_store.add(lastProductionWatt)
 		local todays_production, index = dz.data.production_store.getAtTime(currentTime)
I've created a General / Custom sensor to write back the results (IDX 315)
psubiaco
Re: Calculate daily kWh based on a cumulative kWh device
Post by psubiaco »
Why not letting Domoticz to compute the kWh for you?
If you just use a Domoticz General/kWh counter, configured as "Computed", you can modify your python script to pass to Domoticz the average power (watt) measured in each interval, then Domoticz will display the power graph and also the computed imported energy.
Regards.
Paolo
Paolo
riko
Post by riko »
Thanks for the suggestion. I was considering this as well, there is a actual watt measured and reported every minute I think. But I was afraid that this will lead to wrong calculations as the production can change quite fast (clouds coming over etc). The inverter is registering the total kWh which is the 'real' one and always more precise I think
That means still in need of a script. Or are there also possibilities to let a Domoticz counter device count on the basis of a total kWh counter?
Domoticz version: 2025.1
If that is the case you definitely should use the Domoticz general KWh Counter as that also can accept the total Kwh from the inverter (setting from Device). You should adopt your python script for this. See also https://www.domoticz.com/wiki/Dummy_for ... counter.29
I use the Omnik Python plugin and have no issues. It is running fine reading the data directly from the converter.
https://github.com/sincze/Domoticz-Omni ... Web-Plugin
riko
Post by riko »
Thanks, I tried different ways but didn't get it. It appears that I'm using another plugin (https://www.domoticz.com/wiki/Omnik_Solar_Inverter). What I've tried:
Create a new virtural device device: General/kWh, changed the python script so the 'idx_E_Total' value is sent to this device. I've ried various configurations (and each of the combinations) of the device
  • Type: Usage
  • Type: Return
  • Energy read: Computed
  • Energy read: From device
I see that the device received the total kWh number:
But the device value is not updated accordingly:
I think Domoticz just receives values like: 9331.2, 9131.3, 9131.4, etc etc. The device should calculate the delta and register this instead of taking the full number.
Any ideas?
The URL for this device should look something like
Http://IP:PORT/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=POWER;ENERGY
POWER = current power
ENERGY = cumulative energy in Watt-hours (Wh)
riko
Post by riko »
Thanks, I just saw that the Python script is indeed receiving the daily production from the inverter as well ('E Today': 15 kWh, nice sunny day):
But the full package of the script is a bit too complicated for me and I'm not familar with Python. It seems that this data element is not used to be sent to Domoticz (/home/pi/Omnik-Data-Logger/outputs/DomoticzOutput.py):
#!/usr/bin/python
import PluginLoader
import urllib
import urllib2
import ConfigParser
config = ConfigParser.RawConfigParser()
#change to correct folder.
config.read(['/home/pi/Omnik-Data-Logger/config-default.cfg', '/home/pi/Omnik-Data-Logger/config.cfg'])
domoticz_host    = config.get('domoticz','domoticz_host')
domoticz_port    = config.get('domoticz','domoticz_port')
domoticz_url     = config.get('domoticz','domoticz_url')
idx_Temp = config.get('domoticz','idx_Temp')
idx_PV1_U = config.get('domoticz','idx_PV1_U')
idx_PV2_U = config.get('domoticz','idx_PV2_U')
idx_PV1_A = config.get('domoticz','idx_PV1_A')
idx_PV2_A = config.get('domoticz','idx_PV2_A')
idx_AC_Output = config.get('domoticz','idx_AC_Output')
idx_E_Total = config.get('domoticz','idx_E_Total')
idx_E_Current = config.get('domoticz','idx_E_Current')
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url)
class DomoticzOutput(PluginLoader.Plugin):
    """Outputs the data from the Omnik inverter to Domoticz"""
    def process_message(self, msg):
        """Output the information from the inverter to Domoticz.
        Args:
            msg (InverterMsg.InverterMsg): Message to process
        #Total AC energy generated by inverter in kWatt
        get_data = {
                'svalue': msg.e_total,
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_E_Total
        get_data_encoded = urllib.urlencode(get_data)
        full_url = url + '?' + get_data_encoded
        urllib.urlopen(full_url)
        #Current AC power and today's total power
        get_data = {
                'svalue': str(msg.p_ac(1)) + ';' + str(msg.e_total * 1000),
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_E_Current,
                'nvalue': '0'
        #Current inverter temperature
        if msg.temperature < 300: #inverter displays temperature of +/- 6352 degrees Celcius when not generating power
                get_data = {
                        'svalue': msg.temperature,
                        'type': 'command',
                        'param': 'udevice',
                        'idx' : idx_Temp,
                        'nvalue': '0'
        #String 1 voltage
        get_data = {
                'svalue': msg.v_pv(1),
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_PV1_U,
                'nvalue': '0'
        #String 2 voltage
        get_data = {
                'svalue': msg.v_pv(2),
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_PV2_U,
                'nvalue': '0'
        #String 1 ampere
        get_data = {
                'svalue': msg.i_pv(1),
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_PV1_A,
                'nvalue': '0'
        #String 2 ampere
        get_data = {
                'svalue': msg.i_pv(2),
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_PV2_A,
                'nvalue': '0'
        #Current AC current
        get_data = {
                'svalue': msg.i_ac(1),
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_AC_Output,
                'nvalue': '0'
Does anybody have suggestion for a quick fix for this?
You should change this line
e_total is apparently today's total. You should find the absolute total from the Omnik values. What value is that in the livestats script? The H value?
riko
Post by riko »
It seems that I need to additionally export the e_today value to Domoticz. Looking at the code of the LiveStats:
import PluginLoader
class ConsoleOutput(PluginLoader.Plugin):
    """Outputs the data from the Omnik inverter to stdout"""
        """Output the information from the inverter to stdout.
        Args:
        print "ID: {0}".format(msg.id)
        print "E Today: {0:>5}   Total: {1:<5}".format(msg.e_today, msg.e_total)
        print "H Total: {0:>5}   Temp:  {1:<5}"\
            .format(msg.h_total, msg.temperature)
        print "PV1   V: {0:>5}   I: {1:>4}".format(msg.v_pv(1), msg.i_pv(1))
        print "PV2   V: {0:>5}   I: {1:>4}".format(msg.v_pv(2), msg.i_pv(2))
        print "PV3   V: {0:>5}   I: {1:>4}".format(msg.v_pv(3), msg.i_pv(3))
        print "L1    P: {0:>5}   V: {1:>5}   I: {2:>4}   F: {3:>5}"\
            .format(msg.p_ac(1), msg.v_ac(1), msg.i_ac(1), msg.f_ac(1))
        print "L2    P: {0:>5}   V: {1:>5}   I: {2:>4}   F: {3:>5}"\
            .format(msg.p_ac(2), msg.v_ac(2), msg.i_ac(2), msg.f_ac(2))
        print "L3    P: {0:>5}   V: {1:>5}   I: {2:>4}   F: {3:>5}"\
            .format(msg.p_ac(3), msg.v_ac(3), msg.i_ac(3), msg.f_ac(3))
I've tried to add the e_today to the code, without any knowledge of Python and it seems that I missed something. I've added to the config.cfg file the line: 'idx_E_Today = 315 #nieuw'
config.cfg:
### Settings ###
[general]
# General:enabled_plugins
# Choose which outputs to use
# Possible options: MysqlOutput,PVoutputOutput,ConsoleOutput,CSVOutput
enabled_plugins = DomoticzOutput
[domoticz]
domoticz_host      = 192.168.1.100
domoticz_port      = 8080
domoticz_url       = json.htm
# Provide IDX here of the specific devices was 23
idx_Temp      = 17
idx_PV1_U     = 18
idx_PV2_U     = 19
idx_PV1_A     = 20
idx_PV2_A     = 21
idx_AC_Output = 22
idx_E_Total   = 23
idx_E_Current = 24
[inverter]
# IP address of your Omnik inverter
ip = *********************
# Default for a Omnik with Wifi module
port = ***********************
# S/N of the wifi kit
wifi_sn = ************************
#use temperature of inverter for pvoutput
use_temperature = true
[mysql]
# Host where the mysql server is active
host = 127.0.0.1
user =
pass =
database =
[pvout]
# These two can be found at http://pvoutput.org/account.jsp
apikey = NOTAREALAPIKEY86e2258d4e29169fb79cf18b00
sysid  = 12345
[csv]
disable_header = false
[log]
# Log:Output
# Possible options: none,console,file (combinations are possible)
# Use none to disable logging
type = console
# Log:level
# Possible options: critical, error, warning, info, debug
level = debug
# Log:filename
# Output file for file logger
filename = omnik-export.log
In the file DomoticzOutput.py I've added this section:
#NIEUW today kWh generated
get_data = {
'svalue': msg.e_today,
'type': 'command',
'param': 'udevice',
'idx' : idx_E_Today
DomoticzOutput.py:
#!/usr/bin/python
import PluginLoader
import urllib
import urllib2
import ConfigParser
idx_E_Today = config.get('domoticz','idx_E_Today') #nieuw
        Args:
        get_data = {
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_E_Today
        get_data = {
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_E_Total
        get_data = {
                'type': 'command',
                'param': 'udevice',
                'nvalue': '0'
                get_data = {
                        'type': 'command',
                        'param': 'udevice',
                        'idx' : idx_Temp,
                        'nvalue': '0'
        #String 1 voltage
        get_data = {
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_PV1_U,
                'nvalue': '0'
        #String 2 voltage
        get_data = {
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_PV2_U,
                'nvalue': '0'
        #String 1 ampere
        get_data = {
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_PV1_A,
                'nvalue': '0'
        #String 2 ampere
        get_data = {
                'type': 'command',
                'param': 'udevice',
                'idx' : idx_PV2_A,
                'nvalue': '0'
        #Current AC current
        get_data = {
                'type': 'command',
                'param': 'udevice',
                'nvalue': '0'
I have a General/custom sensor IDX 315 to which I try to export the data. This sensor is similar configured as the sensor that consumes the e_total (which part of the code I've tried to copy).
Any ideas what I missed?
I do not understand what you are trying to do.
As suggested you should use the Energy (Usage and Counter) device. It needs 2 values: POWER and Counter.
It also has history logging so you can compare the years.
But perhaps a lot easier is to use the real plugin.... Just install it and it will create everything for you. https://github.com/sincze/Domoticz-Omni ... Web-Plugin
riko
Post by riko »
Just installed this plugin. Indeed very easy and with the result I was looking for. Thanks!
