Moderators: leecollings , htilburgs , robgeerts
Doudy
Posts: 246 Joined: Tuesday 09 August 2016 9:09
Post
by Doudy » Thursday 27 May 2021 9:12
I have install the last version V3.8.2 beta
Now it is ok
Another question : Why are the days in English?
My config :
config['owm_api'] = '5xxxxx2';
config['owm_city'] = 'Rxxxxxx';
config['owm_name'] = 'Météo Rxxxxxx';
config['owm_country'] = 'be';
config['owm_lang'] = 'fr';
config['owm_cnt'] = '4';
config['owm_days'] = true;
HansieNL
Posts: 969 Joined: Monday 28 September 2015 15:13
Post
by HansieNL » Thursday 27 May 2021 17:43
@Doudy
Days are in English (default) if you don't have set any language.
There are two language settings to set the Dashticz language:
config['language'] = 'nl_NL';
config['calendarlanguage'] = 'nl_NL';
Complete settings overview you can find in the manual:
https://dashticz.readthedocs.io/en/beta/
Blah blah blah
Dickey
Posts: 25 Joined: Friday 19 April 2019 22:29
Domoticz version: 2022.1
Post
by Dickey » Thursday 27 May 2021 19:55
@Doudy
It's very important to read the manual ( as HansieNL suggested).
My way of getting a nice dashboard and complete the config, is try and error.
Dz-beta | Dashticz 3.8.10 BETA | Tradfri | RF-Link | Z-Wave | Harmony | Unify | P1 |
Doudy
Post
by Doudy » Friday 28 May 2021 7:42
@ HansieNL
@ Dickey
TroisSix
Posts: 93 Joined: Monday 11 January 2016 9:29
Domoticz version: 2025.2
Post
by TroisSix » Saturday 29 May 2021 11:51
I just updated to the last version, but the weatherwidget.io is not working anymore, I understand there is a new way to configure the weather widget, but why disable the weatherwidget.io within a html frame?
This one is not working anymore:
https://dashticz.readthedocs.io/en/beta ... stom-block
Need help to keep it cause the colors are really nice
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
HansieNL
Post
by HansieNL » Saturday 29 May 2021 12:45
TroisSix wrote: Saturday 29 May 2021 11:51
Are you sure? It's still working here with latest beta.
Blah blah blah
TroisSix
Post
by TroisSix » Saturday 29 May 2021 13:40
Hi HansieNL,
You're right, sorry, that's working on my iPad & IE, but not on firefox anymore (I cleared my cache)
Anyway, I configured the weather with the new method and I'll keep it now
Improvments: could it be possible to have an abbreviation of the days (like mon. instead of monday) ?
Great work team!
riko
Posts: 90 Joined: Saturday 22 August 2020 13:36
Post
by riko » Thursday 10 June 2021 11:17
Thanks for the update, it sounds great to have more configuration parameters. Only problem is that I cannot get it working (nothing is showed at all on the screen/column where I insert the widget. I use the following code (as in the example)
config['owm_api'] = 'xxxx';
config['owm_city'] = 'Utrecht';
config['owm_name'] = '';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '5';
config['owm_min'] = true;
config['static_weathericons'] = false;
config['use_beaufort'] = true;
blocks['weather1'] = {
type: 'weather',
layout: 1,
count: 7,
interval: 3,
columns[1] = {}
columns[1]['blocks'] = ['weather1', 'cameras', 'spotify']
columns[1]['width'] = 5;
screens[1] = {}
screens[1]['background'] = 'bg_rik_1.jpg';
I've also tried variants like
type: 'weather',
apikey: 'xxx',
city: 'Amsterdam',
I've also cleared the browser cache to be sure. What do I do wrongly?
whoami
Posts: 73 Joined: Tuesday 31 March 2020 22:31
Post
by whoami » Thursday 10 June 2021 15:30
I tried all the CSS custom padding adjustments, but I can't get the yellow space smaller.
What is the code to remove this or make it smaller?
Or even better, set a fixed height to the block with all icons and text automatically adjusted to the right size...
TroisSix
Post
by TroisSix » Thursday 10 June 2021 20:09
@whoami
You could try this:
[data-id='weather'] .max {padding-top:0px !important;}
[data-id='weather'] .description {padding-bottom:0px !important;}
HansieNL
Post
by HansieNL » Saturday 12 June 2021 16:34
riko wrote: Thursday 10 June 2021 11:17
Spoiler: show Code: Select all
type: 'weather',
layout: 1,
count: 7,
interval: 3,
columns[1] = {}
screens[1] = {}
type: 'weather',
apikey: 'xxx',
city: 'Amsterdam',
Tried your config and shows without problems. Can you try to load a config with just the OWM block and see if that works.
Blah blah blah
riko
Post
by riko » Saturday 12 June 2021 20:01
HansieNL wrote: Saturday 12 June 2021 16:34
Just tried to bring down the code. This is all I have left:
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['background_image'] = 'img/bg9.jpg';
config['domoticz_ip'] = 'http://192.168.1.100:8080';
config['app_title'] = 'xxxx';
//Definition of blocks
var blocks = {}
type: 'weather',
layout: 1,
count: 7,
interval: 3,
//Buttons
//Definition of columns - 12 in totaal
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['weather1']
//Definition of screens
var screens = {}
screens[1] = {}
screens[1]['columns'] = [1]
Still a blank screen as result:
Dickey
Post
by Dickey » Saturday 12 June 2021 20:46
What is you're Dasticz version?
Go with terminal into the Dasticz folder and enter the git pull command. You will automatic get the latest version.
You need V3.8.3 beta
Think that's you're problem.
riko
Post
by riko » Sunday 13 June 2021 12:01
I did, that was the reason why the other OWMs components were not working.
Just did a retry:
pi@raspberrypi:~/dashticz $ git pull
Already up to date.
Dickey
Post
by Dickey » Sunday 13 June 2021 19:40
Did try you're config with my credentials. Looks good to me.
HansieNL
Post
by HansieNL » Sunday 13 June 2021 20:49
riko wrote: Sunday 13 June 2021 12:01
Does that mean it is working now?
Blah blah blah
riko
Post
by riko » Sunday 13 June 2021 22:21
Sorry i was not clear in my previous post. The weather blocks are still not working and i have no clue of the problem. Any ideas?
Dickey
Post
by Dickey » Monday 14 June 2021 12:02
riko wrote: Sunday 13 June 2021 22:21
Please look at you're menubar at info to see the version you use. Make a screen print.
riko
Post
by riko » Monday 14 June 2021 15:59
Please see my version:
I was also able to see that the configuration was prefilled like this
madpatrick
Posts: 760 Joined: Monday 26 December 2016 12:17
Post
by madpatrick » Monday 14 June 2021 16:28
riko wrote: Monday 14 June 2021 15:59
As mentioned by Dicky, you probably need to upgrade to 3.8.3 BETA
You are on 3.8.0 master.
