I went for a fresh install of domoticz.
- Installed last pi image (bullseye, Release date: October 30th 2021, Kernel version: 5.10)
- Installed Xiaomi mi Robot plugin.
Restart domoticz.service.
Went to hardware and added the xiaomi mi robot vacuum.
After saving, domoticz ui stops. Domoticz is still running when checking with "sudo service domoticz status"
Stopped domoticz.service and started manual.
Got this error. It looks like the error is made by the plugin, but does somebody know where to start to debug with this error?
Current thread 0xae9ff200 (most recent call first):
File "/home/pi/domoticz/plugins/xiaomi-mirobot/plugin.py", line 111 in onStart
File "/home/pi/domoticz/plugins/xiaomi-mirobot/plugin.py", line 354 in onStart
2021-11-18 12:27:22.725 Error: Domoticz(pid:9159, tid:9172('Xiaomi Mi Robot')) received fatal signal 11 (Segmentation fault)
2021-11-18 12:27:22.726 Error: siginfo address=0x23c7, address=(nil)
2021-11-18 12:27:23.023 Status: PluginSystem: 1 plugins started.
2021-11-18 12:27:24.052 Error: Did not find stack frame for thread (LWP 9172)), printing full gdb output:
2021-11-18 12:27:24.052 Error: > [New LWP 9160]
2021-11-18 12:27:24.052 Error: > [New LWP 9161]
2021-11-18 12:27:24.052 Error: > [New LWP 9162]
2021-11-18 12:27:24.052 Error: > [New LWP 9163]
2021-11-18 12:27:24.052 Error: > [New LWP 9164]
2021-11-18 12:27:24.052 Error: > [New LWP 9165]
2021-11-18 12:27:24.052 Error: > [New LWP 9166]
2021-11-18 12:27:24.052 Error: > [New LWP 9167]
2021-11-18 12:27:24.052 Error: > [New LWP 9168]
2021-11-18 12:27:24.052 Error: > [New LWP 9169]
2021-11-18 12:27:24.052 Error: > [New LWP 9170]
2021-11-18 12:27:24.052 Error: > [New LWP 9171]
2021-11-18 12:27:24.052 Error: > [New LWP 9172]
2021-11-18 12:27:24.052 Error: > [New LWP 9173]
2021-11-18 12:27:24.052 Error: > [New LWP 9174]
2021-11-18 12:27:24.052 Error: > [New LWP 9175]
2021-11-18 12:27:24.052 Error: > [New LWP 9185]
2021-11-18 12:27:24.052 Error: > [Thread debugging using libthread_db enabled]
2021-11-18 12:27:24.052 Error: > Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
2021-11-18 12:27:24.052 Error: > 0xb6940f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xbedf8300, req@entry=0xbedf82f8, rem=0xbedf8310, rem@entry=0xbedf8308) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2021-11-18 12:27:24.052 Error: > 52 ../sysdeps/unix/sysv/linux/clock_nanosleep.c: No such file or directory.
2021-11-18 12:27:24.052 Error: > Id Target Id Frame
2021-11-18 12:27:24.052 Error: > * 1 Thread 0xb6fc3240 (LWP 9159) "domoticz" 0xb6940f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xbedf8300, req@entry=0xbedf82f8, rem=0xbedf8310, rem@entry=0xbedf8308) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2021-11-18 12:27:24.052 Error: > 2 Thread 0xb593d200 (LWP 9160) "Watchdog" 0xb6940f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xb593cb70, req@entry=0xb593cb68, rem=0xb593cb80, rem@entry=0xb593cb78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2021-11-18 12:27:24.052 Error: > 3 Thread 0xb513c200 (LWP 9161) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.052 Error: > 4 Thread 0xb493b200 (LWP 9162) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.052 Error: > 5 Thread 0xb3bc0200 (LWP 9163) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.052 Error: > 6 Thread 0xb33bf200 (LWP 9164) "Webem_ssncleane" 0xb698063c in epoll_wait (epfd=14, events=0xb33be358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.052 Error: > 7 Thread 0xb2b60200 (LWP 9165) "WebServer_8080" 0xb698063c in epoll_wait (epfd=10, events=0xb2b5f328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.052 Error: > 8 Thread 0xb21ff200 (LWP 9166) "Webem_ssncleane" 0xb698063c in epoll_wait (epfd=21, events=0xb21fe358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.052 Error: > 9 Thread 0xb19fe200 (LWP 9167) "WebServer_443" 0xb698063c in epoll_wait (epfd=17, events=0xb19fd328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.052 Error: > 10 Thread 0xb0fff200 (LWP 9168) "Scheduler" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.052 Error: > 11 Thread 0xb07fe200 (LWP 9169) "TCPServer" 0xb698063c in epoll_wait (epfd=24, events=0xb07fd358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.052 Error: > 12 Thread 0xafdff200 (LWP 9170) "MainWorker" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.052 Error: > 13 Thread 0xaf5fe200 (LWP 9171) "MainWorkerRxMsg" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xaf5fdb80, clockid=<optimized out>, expected=0, futex_word=0xa7f378 <m_mainworker+3960>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-18 12:27:24.052 Error: > 14 Thread 0xae9ff200 (LWP 9172) "Xiaomi Mi Robot" 0xb69474d4 in __GI___wait4 (pid=9176, stat_loc=0xaeb25918, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2021-11-18 12:27:24.053 Error: > 15 Thread 0xae1fe200 (LWP 9173) "NotificationSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xae1fdbb0, clockid=<optimized out>, expected=0, futex_word=0xa7ee5c <m_mainworker+2652>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-18 12:27:24.053 Error: > 16 Thread 0xad7ff200 (LWP 9174) "EventSystem" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.053 Error: > 17 Thread 0xacffe200 (LWP 9175) "EventSystemQueu" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xacffdac0, clockid=<optimized out>, expected=0, futex_word=0xa7e558 <m_mainworker+344>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-18 12:27:24.053 Error: > 18 Thread 0xac7fd200 (LWP 9185) "Plugin_ASIO" futex_wait_cancelable (private=0, expected=0, futex_word=0x17c2818) at ../sysdeps/nptl/futex-internal.h:186
2021-11-18 12:27:24.053 Error: > Thread 18 (Thread 0xac7fd200 (LWP 9185) "Plugin_ASIO"):
2021-11-18 12:27:24.053 Error: > #0 futex_wait_cancelable (private=0, expected=0, futex_word=0x17c2818) at ../sysdeps/nptl/futex-internal.h:186
2021-11-18 12:27:24.053 Error: > #1 __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x0, cond=0x17c27f0) at pthread_cond_wait.c:508
2021-11-18 12:27:24.053 Error: > #2 __pthread_cond_wait (cond=0x17c27f0, mutex=0x0) at pthread_cond_wait.c:638
2021-11-18 12:27:24.053 Error: > #3 0x003d4464 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2021-11-18 12:27:24.053 Error: > #4 0x00678844 in Plugins::BoostWorkers() ()
2021-11-18 12:27:24.053 Error: > #5 0x00770c30 in thread_proxy ()
2021-11-18 12:27:24.053 Error: > #6 0xb6abc300 in start_thread (arg=0xac7fd200) at pthread_create.c:477
2021-11-18 12:27:24.053 Error: > #7 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.053 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-18 12:27:24.053 Error: > Thread 17 (Thread 0xacffe200 (LWP 9175) "EventSystemQueu"):
2021-11-18 12:27:24.053 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xacffdac0, clockid=<optimized out>, expected=0, futex_word=0xa7e558 <m_mainworker+344>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-18 12:27:24.053 Error: > #1 __pthread_cond_wait_common (abstime=0xacffdac0, clockid=<optimized out>, mutex=0xad801294, cond=0xa7e530 <m_mainworker+304>) at pthread_cond_wait.c:520
2021-11-18 12:27:24.053 Error: > #2 __pthread_cond_timedwait (cond=0xa7e530 <m_mainworker+304>, mutex=0xad801294, abstime=0xacffdac0) at pthread_cond_wait.c:656
2021-11-18 12:27:24.053 Error: > #3 0x00211b44 in CEventSystem::EventQueueThread() ()
2021-11-18 12:27:24.053 Error: > #4 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.053 Error: > #5 0xb6abc300 in start_thread (arg=0xacffe200) at pthread_create.c:477
2021-11-18 12:27:24.053 Error: > #6 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.053 Error: > Thread 16 (Thread 0xad7ff200 (LWP 9174) "EventSystem"):
2021-11-18 12:27:24.053 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.053 Error: > #1 0x008d7a64 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2021-11-18 12:27:24.053 Error: > #2 0x00208b78 in CEventSystem::Do_Work() ()
2021-11-18 12:27:24.053 Error: > #3 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.053 Error: > #4 0xb6abc300 in start_thread (arg=0xad7ff200) at pthread_create.c:477
2021-11-18 12:27:24.053 Error: > #5 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.053 Error: > Thread 15 (Thread 0xae1fe200 (LWP 9173) "NotificationSys"):
2021-11-18 12:27:24.053 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xae1fdbb0, clockid=<optimized out>, expected=0, futex_word=0xa7ee5c <m_mainworker+2652>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-18 12:27:24.053 Error: > #1 __pthread_cond_wait_common (abstime=0xae1fdbb0, clockid=<optimized out>, mutex=0x0, cond=0xa7ee30 <m_mainworker+2608>) at pthread_cond_wait.c:520
2021-11-18 12:27:24.053 Error: > #2 __pthread_cond_timedwait (cond=0xa7ee30 <m_mainworker+2608>, mutex=0x0, abstime=0xae1fdbb0) at pthread_cond_wait.c:656
2021-11-18 12:27:24.053 Error: > #3 0x00275a40 in CNotificationSystem::QueueThread() ()
2021-11-18 12:27:24.053 Error: > #5 0xb6abc300 in start_thread (arg=0xae1fe200) at pthread_create.c:477
2021-11-18 12:27:24.054 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-18 12:27:24.054 Error: > Thread 14 (Thread 0xae9ff200 (LWP 9172) "Xiaomi Mi Robot"):
2021-11-18 12:27:24.054 Error: > #0 0xb69474d4 in __GI___wait4 (pid=9176, stat_loc=0xaeb25918, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2021-11-18 12:27:24.054 Error: > #1 0x0028f944 in dumpstack_gdb(bool) ()
2021-11-18 12:27:24.054 Error: > #2 0x0028ff10 in signal_handler(int, siginfo_t*, void*) ()
2021-11-18 12:27:24.054 Error: > #3 <signal handler called>
2021-11-18 12:27:24.054 Error: > #4 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
2021-11-18 12:27:24.054 Error: > #5 <signal handler called>
2021-11-18 12:27:24.054 Error: > #6 0x0000000c in ?? ()
2021-11-18 12:27:24.054 Error: > #7 0xb59bf47c in _PyEval_EvalFrameDefault () from /lib/arm-linux-gnueabihf/libpython3.9.so
2021-11-18 12:27:24.054 Error: > #8 0xb117d88c in ?? ()
2021-11-18 12:27:24.054 Error: > Thread 13 (Thread 0xaf5fe200 (LWP 9171) "MainWorkerRxMsg"):
2021-11-18 12:27:24.054 Error: > #0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xaf5fdb80, clockid=<optimized out>, expected=0, futex_word=0xa7f378 <m_mainworker+3960>) at ../sysdeps/nptl/futex-internal.h:323
2021-11-18 12:27:24.054 Error: > #1 __pthread_cond_wait_common (abstime=0xaf5fdb80, clockid=<optimized out>, mutex=0xb6ab7a1c, cond=0xa7f350 <m_mainworker+3920>) at pthread_cond_wait.c:520
2021-11-18 12:27:24.054 Error: > #2 __pthread_cond_timedwait (cond=0xa7f350 <m_mainworker+3920>, mutex=0xb6ab7a1c, abstime=0xaf5fdb80) at pthread_cond_wait.c:656
2021-11-18 12:27:24.054 Error: > #3 0x00261f38 in MainWorker::Do_Work_On_Rx_Messages() ()
2021-11-18 12:27:24.054 Error: > #4 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.054 Error: > #5 0xb6abc300 in start_thread (arg=0xaf5fe200) at pthread_create.c:477
2021-11-18 12:27:24.054 Error: > #6 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.054 Error: > Thread 12 (Thread 0xafdff200 (LWP 9170) "MainWorker"):
2021-11-18 12:27:24.054 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.054 Error: > #1 0x008d7a64 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2021-11-18 12:27:24.054 Error: > #2 0x0025de08 in MainWorker::Do_Work() ()
2021-11-18 12:27:24.054 Error: > #3 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.054 Error: > #4 0xb6abc300 in start_thread (arg=0xafdff200) at pthread_create.c:477
2021-11-18 12:27:24.054 Error: > #5 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.054 Error: > Thread 11 (Thread 0xb07fe200 (LWP 9169) "TCPServer"):
2021-11-18 12:27:24.054 Error: > #0 0xb698063c in epoll_wait (epfd=24, events=0xb07fd358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.054 Error: > #1 0x003d2384 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2021-11-18 12:27:24.054 Error: > #2 0x003d437c in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2021-11-18 12:27:24.054 Error: > #3 0x006d4d50 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<tcp::server::CTCPServer::StartServer(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#1}> > >::_M_run() ()
2021-11-18 12:27:24.054 Error: > #5 0xb6abc300 in start_thread (arg=0xb07fe200) at pthread_create.c:477
2021-11-18 12:27:24.054 Error: > Thread 10 (Thread 0xb0fff200 (LWP 9168) "Scheduler"):
2021-11-18 12:27:24.055 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.055 Error: > #1 0x008d7a64 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2021-11-18 12:27:24.055 Error: > #2 0x00286db8 in CScheduler::Do_Work() ()
2021-11-18 12:27:24.055 Error: > #3 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.055 Error: > #4 0xb6abc300 in start_thread (arg=0xb0fff200) at pthread_create.c:477
2021-11-18 12:27:24.055 Error: > #5 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.055 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-18 12:27:24.055 Error: > Thread 9 (Thread 0xb19fe200 (LWP 9167) "WebServer_443"):
2021-11-18 12:27:24.055 Error: > #0 0xb698063c in epoll_wait (epfd=17, events=0xb19fd328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.055 Error: > #1 0x003d2384 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2021-11-18 12:27:24.055 Error: > #2 0x003d437c in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
2021-11-18 12:27:24.055 Error: > #3 0x0071fe68 in http::server::server_base::run() ()
2021-11-18 12:27:24.055 Error: > #4 0x002d7b80 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#280}> > >::_M_run() ()
2021-11-18 12:27:24.055 Error: > #5 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.055 Error: > #6 0xb6abc300 in start_thread (arg=0xb19fe200) at pthread_create.c:477
2021-11-18 12:27:24.055 Error: > #7 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.055 Error: > Thread 8 (Thread 0xb21ff200 (LWP 9166) "Webem_ssncleane"):
2021-11-18 12:27:24.055 Error: > #0 0xb698063c in epoll_wait (epfd=21, events=0xb21fe358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.055 Error: > #3 0x006effe0 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2021-11-18 12:27:24.055 Error: > #4 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.055 Error: > #5 0xb6abc300 in start_thread (arg=0xb21ff200) at pthread_create.c:477
2021-11-18 12:27:24.055 Error: > #6 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.055 Error: > Thread 7 (Thread 0xb2b60200 (LWP 9165) "WebServer_8080"):
2021-11-18 12:27:24.055 Error: > #0 0xb698063c in epoll_wait (epfd=10, events=0xb2b5f328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.055 Error: > #6 0xb6abc300 in start_thread (arg=0xb2b60200) at pthread_create.c:477
2021-11-18 12:27:24.055 Error: > Thread 6 (Thread 0xb33bf200 (LWP 9164) "Webem_ssncleane"):
2021-11-18 12:27:24.055 Error: > #0 0xb698063c in epoll_wait (epfd=14, events=0xb33be358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2021-11-18 12:27:24.056 Error: > #3 0x006effe0 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2021-11-18 12:27:24.056 Error: > #4 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.056 Error: > #5 0xb6abc300 in start_thread (arg=0xb33bf200) at pthread_create.c:477
2021-11-18 12:27:24.056 Error: > #6 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.056 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2021-11-18 12:27:24.056 Error: > Thread 5 (Thread 0xb3bc0200 (LWP 9163) "InfluxPush"):
2021-11-18 12:27:24.056 Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
2021-11-18 12:27:24.056 Error: > #1 0x008d7a64 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
2021-11-18 12:27:24.056 Error: > #2 0x003915e8 in CInfluxPush::Do_Work() ()
2021-11-18 12:27:24.056 Error: > #3 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.056 Error: > #4 0xb6abc300 in start_thread (arg=0xb3bc0200) at pthread_create.c:477
2021-11-18 12:27:24.056 Error: > #5 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.056 Error: > Thread 4 (Thread 0xb493b200 (LWP 9162) "PluginMgr"):
2021-11-18 12:27:24.056 Error: > #2 0x00679054 in Plugins::CPluginSystem::Do_Work() ()
2021-11-18 12:27:24.056 Error: > #4 0xb6abc300 in start_thread (arg=0xb493b200) at pthread_create.c:477
2021-11-18 12:27:24.056 Error: > Thread 3 (Thread 0xb513c200 (LWP 9161) "SQLHelper"):
2021-11-18 12:27:24.056 Error: > #2 0x002a6d70 in CSQLHelper::Do_Work() ()
2021-11-18 12:27:24.056 Error: > #4 0xb6abc300 in start_thread (arg=0xb513c200) at pthread_create.c:477
2021-11-18 12:27:24.056 Error: > Thread 2 (Thread 0xb593d200 (LWP 9160) "Watchdog"):
2021-11-18 12:27:24.056 Error: > #0 0xb6940f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xb593cb70, req@entry=0xb593cb68, rem=0xb593cb80, rem@entry=0xb593cb78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2021-11-18 12:27:24.056 Error: > #1 0xb6941080 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0xb593cbb0) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2021-11-18 12:27:24.056 Error: > #2 0xb6947830 in __GI___nanosleep (requested_time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2021-11-18 12:27:24.056 Error: > #3 0x00223704 in sleep_milliseconds(long) ()
2021-11-18 12:27:24.056 Error: > #4 0x00290078 in Do_Watchdog_Work() ()
2021-11-18 12:27:24.056 Error: > #5 0x008f9ff4 in execute_native_thread_routine ()
2021-11-18 12:27:24.056 Error: > #6 0xb6abc300 in start_thread (arg=0xb593d200) at pthread_create.c:477
2021-11-18 12:27:24.056 Error: > #7 0xb6980208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
2021-11-18 12:27:24.056 Error: > Thread 1 (Thread 0xb6fc3240 (LWP 9159) "domoticz"):
2021-11-18 12:27:24.057 Error: > #0 0xb6940f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xbedf8300, req@entry=0xbedf82f8, rem=0xbedf8310, rem@entry=0xbedf8308) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2021-11-18 12:27:24.057 Error: > #1 0xb6941080 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0xbedf8340) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
2021-11-18 12:27:24.057 Error: > #2 0xb6947830 in __GI___nanosleep (requested_time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
2021-11-18 12:27:24.057 Error: > #3 0x00223670 in sleep_seconds(long) ()
2021-11-18 12:27:24.057 Error: > #4 0x001ae4ac in main ()
2021-11-18 12:27:24.057 Error: > Main thread:
2021-11-18 12:27:24.057 Error: > [Inferior 1 (process 9159) detached]
Segmentation fault
after deleting the plugin folder xiaomi-mirobot, domoticz comes back to live.
The problem is in the plugin i would say.
