Confused about which device belong to which zwave-node Topic is solved
Re: Confused about which device belong to which zwave-node
I'm amazed that this is not part of Domoticz (anymore), and how hard it is to actually find zwave devices that belongs to the same unit. So I implemented a quickfix on top of Version: 2020.2 (build 12660) (I guess it will work on latest as well).
Now each z-wave device/unit is listed as a separate hardware, and selecting the z-wave device/unit (hardware) will filter the list for all related domoticz devices. It's possible to select multiple z-wave devices/units simultaneously.
I can make a PR if it's interesting to get this addition merged. No guarantee it will get accepted though.
lost
Crossing fingers!paalkr wrote: Friday 02 April 2021 0:27 I can make a PR if it's interesting to get this addition merged. No guarantee it will get accepted thorough.
Plantje
Great work! Though, I am afraid it will not be accepted as gizmocuz has mentioned it is not a useful feature
- madpatrick
- Domoticz version: 2025.2
Maybe your can share the code as a diff.
Quite a tense discussion going on over at https://github.com/domoticz/domoticz/co ... 17e275f09b
Plantje
Yeah... I think rrozema gave up on that...
The PR got merged this morning
- jvdz
- Domoticz version: 4.107
dunno about rrozema, but I clearly did.....and not to ne a spoilsport, my 3 line change was alo committed and part of a beta release for a while.
Yes, I know. Let's hope it will stay this time... The code is identical to what you provided, I just rebased it to the new devices code.
- jvdz
I hope so too and else simply merge it into the source whenever I update. ( Which is not likely to be anytime soon with all the issues I read with latest version of openzwave and its issues inside Domoticz.)
Yes, It's always easy to just merge it locally if it eventually get removed againjvdz wrote: Wednesday 07 April 2021 22:49 I hope so too and else simply merge it into the source whenever I update. ( Which is not likely to be anytime soon with all the issues I read with latest version of openzwave and its issues inside Domoticz.)
I have been running on latest for a long time now. What are the zwave problems reported by other users?
- Domoticz version: 2025.1
Just to confirm so I can update the wiki: This change is now in stable 2021.1 ? I have no ZWave so cannot check.paalkr wrote: Friday 02 April 2021 0:27 I'm amazed that this is not part of Domoticz (anymore), and how hard it is to actually find zwave devices that belongs to the same unit. So I implemented a quickfix on top of Version: 2020.2 (build 12660) (I guess it will work on latest as well).
I'll have to look at the release notes to verify if it's in stable yet.
- waaren
Yes. In domoticz from build 13148waltervl wrote: Tuesday 04 May 2021 11:15 Just to confirm so I can update the wiki: This change is now in stable 2021.1 ? I have no ZWave so cannot check.
The domoticz release versions (aka stable) contain all fixes, updates , etc from earlier builds.
Plantje
This is working great! Really happy with this feature. Thanks!
harrykausl
- Domoticz version: 2021.1
I am now on 2021.1. How can I get the mixed device/hardware tab. In devices tab, I can only see the devices, idx are highlighted. But I don‘t see the hardware list as it is shown in the picture above in this thread.
- waaren
harrykausl wrote: Thursday 20 May 2021 22:43 I am now on 2021.1. How can I get the mixed device/hardware tab. In devices tab, I can only see the devices, idx are highlighted. But I don‘t see the hardware list as it is shown in the picture above in this thread.
harrykausl
lost
Also searched a bit for this one
Looks this does not always show all devices in a z-wave node: Using this bar only shows relay control from my Qubino Smart-Meter... But search using the old hex node ID method still shows all devices (V/I/W/Cos Phy...). Others I checked (not all) looks OK.
Can't see how to put an image (needs an external URL) directly in the forum to show this, but that's what's happening.
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
