LEt's say options like minimum level of alert to fire the notification . And the notification will give the alert level and it's message.
By the way taht makes me think of something, we don't have the capability to customize those notifications message. The template seems harcoded in the code and is not multilangugae. I'm french and i would be grateful to help and give the translations for all notifications in domoticz. (Are you ok with tha gizmocuz ?)
An other possibility (and by far the best and unfortunately longest to code) would be to customize the notifications integrated in domotociz:
I mean for example i have a temp humdity sensor on which i added a notification for temps lower than 19:
I could write something like : Temperature in bedroom Alert (title)
The temperature in the bedroom is lower than 19°. It is actually $(currentvaluesensor).
This is only an example.
This feature would be great. But at least if you don't want to implement such a feature or while waiting the implementation, i would like to receive my notification in french (actually i bypassed that by not using the integrated sensor/switch notification system, and using lua script instead), but ii would be better to use the integrated system. So i'm really grateful to help if you want me to give you all the translations
