Python Plugin: TUYA
Irate
- Domoticz version: 2020.2
Re: Python Plugin: TUYA
My Domoticz was on NAS Synology, I had some problems with the plugin by Xenomes (python and requests).
New instalation with Docker and now It's perfect.
Thank's to Xenomes
Thank's to Xenomes
NAS DS716II - Docker - RFX - RFLINK - Mysensors - ZWave
Domoticz 2021.1
Domoticz 2021.1
- Xenomes
- Domoticz version: 2025.2
Nice to hear that it is working!Irate wrote: Sunday 25 April 2021 18:11 My Domoticz was on NAS Synology, I had some problems with the plugin by Xenomes (python and requests).
Thank's to Xenomes
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
TroisSix
I really appreciate this plugin as it is working fine with my plugs, except rare http connections on these last days (haven't seen it before domoticz version 2021.01)
Anyway, I have some "wifi door detectors" appaired in SmartLife, but it doesn't appear in Domoticz, what should I do? (I activated the "add new devices", stop/start the plugin, it doesn't appear in the devices list
Thank you for your help
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
- Xenomes
Can you post a example?TroisSix wrote: Monday 26 April 2021 15:27 except rare http connections on these last days (haven't seen it before domoticz version 2021.01)
You can run the debug_discovery.py from the tools directory it will show if your device is detected by the tuyaapi.TroisSix wrote: Monday 26 April 2021 15:27 I have some "wifi door detectors" appaired in SmartLife, but it doesn't appear in Domoticz, what should I do? (I activated the "add new devices", stop/start the plugin, it doesn't appear in the devices list
TroisSix
New example on this mrning:
Yes, I have already used this script, and no it doesn't show my detectors. I don't know what to do...
Except I can use the tuya skill in Alexa, and activate a virtual switch of dz for each open/close action, for each device
2021-04-27 08:02:37.787 Error: Tuya Plugin: (Tuya Plugin) handleThread: ('Connection aborted.', OSError(101, 'Network is unreachable')) line 209Except I can use the tuya skill in Alexa, and activate a virtual switch of dz for each open/close action, for each device
- Xenomes
The device is not supported by api of Tuya. The only thing what you can do is to ask Tuya to add device to the API see https://github.com/Xenomes/Domoticz-TUY ... hould-i-doTroisSix wrote: Tuesday 27 April 2021 14:22 Yes, I have already used this script, and no it doesn't show my detectors. I don't know what to do...
Can you set the debugging on everything and post the messages before and after the error occurs?TroisSix wrote: Tuesday 27 April 2021 14:22 New example on this mrning:Code: Select all
TroisSix
@Xenomes,
I haven't seen any error since the last time, I'll keep you informed if got new ones
- Xenomes
TroisSix wrote: Friday 30 April 2021 14:11 @Xenomes,
I haven't seen any error since the last time, I'll keep you informed if got new ones![]()
TroisSix
I searched a long time on the web, forums, etc, and no one got it working with the api.
So for the one who are searching to get the status of their door/window sensors in Dz, I could do it
I share what I've done:
Hope it will help, I know it's not a Roll's Royce, but it works well for me
- I added some virtual switches in Domoticz, and I added the plugin Tuya in Amazon Alexa.
- then I configure the routines to activate / deactivate the virtual switches when a sensor is opened/closed.
Hello, I have a problem with your plugin :
First i created hardware tuya and i got this logs in domoticz :
2021-05-01 20:53:43.352 Active notification Subsystems: fcm, http (2/13)
2021-05-01 20:53:43.358 Starting shared server on: :::6144
2021-05-01 20:53:43.288 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-05-01 20:53:43.289 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-05-01 20:53:43.289 Status: Startup Path: D:\Programmes\Domoticz\
2021-05-01 20:53:43.344 Status: PluginSystem: Started, Python version '3.9.4'.
2021-05-01 20:53:43.353 Status: WebServer(HTTP) started on address: :: with port 8080
2021-05-01 20:53:43.356 Status: WebServer(SSL) started on address: :: with port 443
2021-05-01 20:53:43.358 Status: TCPServer: shared server started...
2021-05-01 20:53:43.359 Status: RxQueue: queue worker started...
2021-05-01 20:53:45.390 Status: NotificationSystem: thread started...
2021-05-01 20:53:45.391 Status: EventSystem: reset all events...
2021-05-01 20:53:45.393 Status: EventSystem: reset all device statuses...
2021-05-01 20:53:45.446 Status: Python EventSystem: Initalizing event module.
2021-05-01 20:53:45.447 Status: EventSystem: Started
2021-05-01 20:53:45.447 Status: EventSystem: Queue thread started...
2021-05-01 20:54:22.904 Test hardware started.
2021-05-01 20:54:22.904 Status: Test: (Test) Entering work loop.
2021-05-01 20:54:22.904 Status: Test: (Test) Started.
2021-05-01 20:54:23.139 Test: (Test) Waiting 60 seconds to connect TuyaApi login timeout
2021-05-01 20:54:23.137 Status: Test: (Test) Initialized version 1.0.8, author 'Wagner Oliveira'
2021-05-01 20:55:23.146 Test: (Test) TUYA plugin started
2021-05-01 20:55:23.146 Test: (Test) Debug logging mask set to: PYTHON CONNECTION
2021-05-01 20:55:23.146 Test: (Test) 'HardwareID':'2'
2021-05-01 20:55:23.146 Test: (Test) 'HomeFolder':'D:\Programmes\Domoticz\plugins\TUYA\'
2021-05-01 20:55:23.147 Test: (Test) 'StartupFolder':'D:\Programmes\Domoticz\'
2021-05-01 20:55:23.147 Test: (Test) 'UserDataFolder':'D:\Programmes\Domoticz\'
2021-05-01 20:55:23.147 Test: (Test) 'Database':'C:\ProgramData\Domoticz\domoticz.db'
2021-05-01 20:55:23.148 Test: (Test) 'Language':'en'
2021-05-01 20:55:23.148 Test: (Test) 'Version':'1.0.8'
2021-05-01 20:55:23.148 Test: (Test) 'Author':'Wagner Oliveira'
2021-05-01 20:55:23.148 Test: (Test) 'Name':'Test'
2021-05-01 20:55:23.149 Test: (Test) 'Port':'0'
2021-05-01 20:55:23.149 Test: (Test) 'Username':'*********'
2021-05-01 20:55:23.149 Test: (Test) 'Password':'*******'
2021-05-01 20:55:23.149 Test: (Test) 'Key':'tuya'
2021-05-01 20:55:23.149 Test: (Test) 'Mode1':'33'
2021-05-01 20:55:23.150 Test: (Test) 'Mode2':'smart_life'
2021-05-01 20:55:23.150 Test: (Test) 'Mode6':'18'
2021-05-01 20:55:23.151 Test: (Test) 'DomoticzVersion':'2021.1'
2021-05-01 20:55:23.151 Test: (Test) 'DomoticzHash':'8547c5b7e'
2021-05-01 20:55:23.151 Test: (Test) 'DomoticzBuildTime':'2021-04-17 17:29:11'
2021-05-01 20:55:23.151 Test: (Test) Device count: 0
2021-05-01 20:55:23.152 Test: (Test) in handlethread
2021-05-01 20:55:23.146 Error: Test hardware (2) thread seems to have ended unexpectedly
and domoticz crashed.
Then i relaunch domoticz and here are the logs that appeared :
2021-05-01 21:03:27.262 Active notification Subsystems: fcm, http (2/13)
2021-05-01 21:03:27.268 Starting shared server on: :::6144
2021-05-01 21:03:27.195 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-05-01 21:03:27.196 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-05-01 21:03:27.199 Status: Startup Path: D:\Programmes\Domoticz\
2021-05-01 21:03:27.255 Status: PluginSystem: Started, Python version '3.9.4'.
2021-05-01 21:03:27.263 Status: WebServer(HTTP) started on address: :: with port 8080
2021-05-01 21:03:27.266 Status: WebServer(SSL) started on address: :: with port 443
2021-05-01 21:03:27.268 Status: TCPServer: shared server started...
2021-05-01 21:03:27.268 Status: RxQueue: queue worker started...
2021-05-01 21:03:29.283 Test hardware started.
2021-05-01 21:03:29.534 Test: (Test) Waiting 60 seconds to connect TuyaApi login timeout
2021-05-01 21:03:29.283 Status: Test: (Test) Entering work loop.
2021-05-01 21:03:29.283 Status: Test: (Test) Started.
2021-05-01 21:03:29.284 Status: NotificationSystem: thread started...
2021-05-01 21:03:29.285 Status: EventSystem: reset all events...
2021-05-01 21:03:29.287 Status: EventSystem: reset all device statuses...
2021-05-01 21:03:29.336 Status: Python EventSystem: Initalizing event module.
2021-05-01 21:03:29.337 Status: EventSystem: Started
2021-05-01 21:03:29.337 Status: EventSystem: Queue thread started...
2021-05-01 21:03:29.533 Status: Test: (Test) Initialized version 1.0.8, author 'Wagner Oliveira'
2021-05-01 21:03:29.774 Status: PluginSystem: 1 plugins started.
2021-05-01 21:04:29.537 Test: (Test) TUYA plugin started
2021-05-01 21:04:29.537 Test: (Test) Debug logging mask set to: PYTHON CONNECTION
2021-05-01 21:04:29.537 Test: (Test) 'HardwareID':'2'
2021-05-01 21:04:29.537 Test: (Test) 'HomeFolder':'D:\Programmes\Domoticz\plugins\TUYA\'
2021-05-01 21:04:29.538 Test: (Test) 'StartupFolder':'D:\Programmes\Domoticz\'
2021-05-01 21:04:29.538 Test: (Test) 'UserDataFolder':'D:\Programmes\Domoticz\'
2021-05-01 21:04:29.538 Test: (Test) 'Database':'C:\ProgramData\Domoticz\domoticz.db'
2021-05-01 21:04:29.538 Test: (Test) 'Language':'en'
2021-05-01 21:04:29.539 Test: (Test) 'Version':'1.0.8'
2021-05-01 21:04:29.539 Test: (Test) 'Author':'Wagner Oliveira'
2021-05-01 21:04:29.539 Test: (Test) 'Name':'Test'
2021-05-01 21:04:29.539 Test: (Test) 'Port':'0'
2021-05-01 21:04:29.540 Test: (Test) 'Username':'********'
2021-05-01 21:04:29.540 Test: (Test) 'Password':'******'
2021-05-01 21:04:29.540 Test: (Test) 'Key':'tuya'
2021-05-01 21:04:29.540 Test: (Test) 'Mode1':'33'
2021-05-01 21:04:29.541 Test: (Test) 'Mode2':'smart_life'
2021-05-01 21:04:29.541 Test: (Test) 'Mode6':'18'
2021-05-01 21:04:29.541 Test: (Test) 'DomoticzVersion':'2021.1'
2021-05-01 21:04:29.541 Test: (Test) 'DomoticzHash':'8547c5b7e'
2021-05-01 21:04:29.541 Test: (Test) 'DomoticzBuildTime':'2021-04-17 17:29:11'
2021-05-01 21:04:29.542 Test: (Test) Device count: 0
2021-05-01 21:04:29.543 Test: (Test) in handlethread
2021-05-01 21:04:29.662 Test: (Test) onHeartbeat called time=1619895869.66255
2021-05-01 21:04:29.663 Test: (Test) in handlethread
2021-05-01 21:04:29.663 Test: (Test) Device count: 0
2021-05-01 21:04:31.147 Test: (Test) DEV name=Salon 4 state=True id=70770354c44f3393bc41 online=False
and it crash again and again.
I have well changed informations in "debug_discovery.py" and it well found my devices when i run it in console.
Could you help me please ?
(Sorry for my bad english, not my natural language)
- Xenomes
I have no idea why your Domoticz crash, but can you put the plug-in debug to all maybe we can get more info.Bobby08 wrote: Saturday 01 May 2021 21:25 Hello, I have a problem with your plugin :
Thanks for your quickness, i just check and this is the "all" tab i have copied.
Or maybe i don't understand
- Xenomes
Set the debug in the plug-in to all.
ok i changed the debug to all and the logs give me exactly same things as before
Am i supposed to see more things ?
- Xenomes
I think this is the problem you have Python version '3.9.4' running I am running the default Python Version: '3.7.3'.
Or the OS is the problem, never had tested Windows
ok i will try with your version then and i will inform you tomorrow.
Thank you a lot
Thank you a lot
Yeeeeesss with python 3.7.3 it finally works !!!
It was a long time i try to make this work, you're genius.
Thank you very much !!! <3
- Xenomes
Ok great!
Hi Xenomes, after some tests I have some others issues that i dont understand.
Here my debug_discovery.py :
Getting credentials
Got credentials
{ 'access_token': 'EUheu1544366034489mQR6HQjME85BjVp',
'expires_in': 864000,
'refresh_token': 'EUheu1544366034489mQR6HFyYbkUTEdB',
'token_type': 'bearer'}
Getting devices
Got devices
{ 'header': {'code': 'SUCCESS', 'payloadVersion': 1},
'payload': { 'devices': [ { 'data': { 'brightness': '255',
'color_mode': 'white',
'color_temp': 4600,
'online': False,
'state': 'true'},
'dev_type': 'light',
'ha_type': 'light',
'icon': 'https://images.tuyaeu.com/smart/icon/ay ... 2e1b1e.png',
'id': '70770354c44f3393bc41',
'name': 'Salon 4'},
'color_mode': 'colour',
'color_temp': 7282,
'online': True,
'state': 'false'},
'ha_type': 'light',
'icon': 'https://images.tuyaeu.com/smart/icon/ay ... f1c5cf.png',
'id': 'bf37a2254fdd9384a4rixk',
'name': 'Chambre'},
{ 'data': { 'brightness': '1000',
'online': True,
'state': 'false'},
'ha_type': 'light',
'icon': 'https://images.tuyaeu.com/smart/icon/15 ... s3lt_0.png',
'id': '351636742462ab1459fa',
'name': 'Ruban'},
'color_temp': 4600,
'online': True,
'state': 'false'},
'ha_type': 'light',
'id': '82276021c44f33cdc0f8',
'name': 'Salon 5'},
'online': True,
'state': 'false'},
'ha_type': 'light',
'icon': 'https://images.tuyaeu.com/smart/product_icon/dj.png',
'id': '60130676b4e62d50ddd7',
'name': 'Rose'},
'online': True,
'state': 'false'},
'ha_type': 'light',
'id': '74547806807d3a4648a8',
'name': 'Cuisine'},
'online': False,
'state': 'true'},
'ha_type': 'light',
'id': '60130676b4e62d50dc19',
'name': 'Ninja'},
'color_temp': 4600,
'online': False,
'state': 'false'},
'ha_type': 'light',
'id': '70770354dc4f22a71e15',
'name': 'Salon 3'},
'color_temp': 4600,
'online': True,
'state': 'false'},
'ha_type': 'light',
'id': '82276021c44f33cc3b2a',
'name': 'Salon 2'},
'color_temp': 4600,
'online': True,
'state': 'false'},
'ha_type': 'light',
'id': '82276021c44f33cda905',
'name': 'Salon 1'},
'online': False,
'state': 'true'},
'ha_type': 'light',
'id': '60130676b4e62d50f03f',
'name': 'Bureau'},
{ 'data': {},
'dev_type': 'scene',
'ha_type': 'scene',
'id': 'BVlmpmtwzdAkkgUx',
'name': 'Salon OFF'},
{ 'data': {},
'ha_type': 'scene',
'id': 'siXNsXHl4i6gmUVk',
'name': 'Salon ON'}],
'scenes': []}}
!!! NOW REMOVE THIS FILE, SO YOUR CREDENTIALS (username, password) WON'T LEAK !!!
In my Domoticz panel I only have the LED stripe that i can change colors, whereas all my lights are same type RGB and i only can change white warm.
Also my scenes do nothing when i click on it.
Getting credentials
Got credentials
Getting devices
Got devices
'color_temp': 4600,
'online': False,
'state': 'true'},
'ha_type': 'light',
'name': 'Salon 4'},
'color_temp': 7282,
'online': True,
'state': 'false'},
'ha_type': 'light',
'name': 'Chambre'},
'online': True,
'state': 'false'},
'ha_type': 'light',
'name': 'Ruban'},
'color_temp': 4600,
'online': True,
'state': 'false'},
'ha_type': 'light',
'name': 'Salon 5'},
'online': True,
'state': 'false'},
'ha_type': 'light',
'name': 'Rose'},
'online': True,
'state': 'false'},
'ha_type': 'light',
'name': 'Cuisine'},
'online': False,
'state': 'true'},
'ha_type': 'light',
'name': 'Ninja'},
'color_temp': 4600,
'online': False,
'state': 'false'},
'ha_type': 'light',
'name': 'Salon 3'},
'color_temp': 4600,
'online': True,
'state': 'false'},
'ha_type': 'light',
'name': 'Salon 2'},
'color_temp': 4600,
'online': True,
'state': 'false'},
'ha_type': 'light',
'name': 'Salon 1'},
'online': False,
'state': 'true'},
'ha_type': 'light',
'name': 'Bureau'},
{ 'data': {},
'ha_type': 'scene',
{ 'data': {},
'ha_type': 'scene',
'scenes': []}}
- Xenomes
That is a easy one, as mention in the readme:
⚠ RGBW(W) lights must be on a colour for correct detection ⚠
Users browsing this forum: eddieb and 1 guest
