dzvents Silent() seems not to be working
Re: dzvents Silent() seems not to be working
broker wrote: Monday 26 April 2021 11:23 [It depends on how much air there is in the suction pipe.
at least twice, three time a year.
You could control this by adding a virtual switch "Pomp ontluchten"
With below modified script the pump will be on manual control when this switch is active.
return
    on =
        devices =
            'Waterpomp',
            'Sproeier Voor',
            'Sproeier Achter',
            'Druppelslang',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Waterpump',
    execute = function(dz, device)
        local waterpump = dz.devices('Waterpomp')
        local backGardenSprinkler = dz.devices('Sproeier Achter')
        local frontGardenSprinkler = dz.devices('Sproeier Voor')
        local dripperHose = dz.devices('Druppelslang')
        local bleeding = dz.devices('Pomp ontluchten')
        local spraytime = 1
        local function hosesActive()
            local activeHoses = backGardenSprinkler.active and 1 or 0
            activeHoses = activeHoses + ( frontGardenSprinkler.active and 1  or 0 )
            activeHoses = activeHoses + ( dripperHose.active and 1  or 0 )
            return activeHoses
        local function switchWaterpump( sprayMinutes )
            if not(sprayMinutes) then
                dz.log('All hoses closed. Stop waterpump now', dz.LOG_DEBUG)
                waterpump.switchOff().checkFirst().silent()
                local delay = sprayMinutes * 60 - 5
                waterpump.cancelQueuedCommands()
                waterpump.switchOn().checkFirst().silent()
                waterpump.switchOff().silent().afterSec(delay)
                dz.log('Switching waterpump On for ' .. delay .. ' seconds ', dz.LOG_DEBUG)
        if device == waterpump and device.active then
            if bleeding.active then
                dz.log('Bleeding switch on; waterpump now on manual control!', dz.LOG_FORCE )
                return
            elseif hosesActive() > 0 then
                device.switchOff().silent().afterMin(spraytime)
                dz.log('One or more hoses active. Stop waterpump after ' .. spraytime .. ' minutes', dz.LOG_DEBUG )
                switchWaterpump()
            return
        if device.active then
            device.switchOff().silent().afterSec(spraytime * 60)
            dz.log('Switching ' .. device.name .. ' Off after ' .. spraytime .. ' minutes', dz.LOG_DEBUG )
            switchWaterpump( spraytime )
        elseif hosesActive() == 0 then
            switchWaterpump()
