Grayed-out UI item in Utility Sensors Topic is solved
- philchillbill
Re: Grayed-out UI item in Utility Sensors
@waaren, That fixed it for me too - many thanks !
The original post in viewtopic.php?p=128783#p128783 is then also incomplete regarding the hardware id because that's the tutorial I followed a few years ago to create that water meter.
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
- waaren
I don't know if it is reserved but it is in all my domoticz systems. Preferable I would connect the loose deviceid(s) with a dummy hardware but I could not tell from your list of hardware if you have such a hardware and connect it to internal is also OK.
- waaren
There was indeed room for confusion in that post and it advises to use API calls where it can be done much easier from within the GUI.philchillbill wrote: Monday 25 January 2021 17:43 @waaren, That fixed it for me too - many thanks !
by creating a dummy hardware from the hardware tab and use the button on that newly created hardware to create a new virtual device of type counter.
sammyke007
- Domoticz version: 2022.1
I've ran into the same "problem" today after updating to 2021.1. Fixing it with the sqlite3 commands did the magic. Tnx @waaren!
Bochelork
I've grayed out items with a lot of sensors. The reason is that the hardware is disabled, because I do not use the hardware plugins anymore. Data comes from scripts. E.g. Wunderground comes from my own script. I kept the sensors, but hardware is disabled. Updates are done with domoticz api or mqtt/in from scripts. Is there a way to show the sensors from disabled hardware NOT grayed out?
- waaren
No.Bochelork wrote: Monday 19 April 2021 13:51 Is there a way to show the sensors from disabled hardware NOT grayed out?
What you could do is define a "Dummy (Does nothing, use for virtual switches only)" hardware and connect the devices updated via JSON / MQTT using sqlite or similar to this 'hardware' using the following commands.
cd <domoticz dir>
sudo sqlite3 domoticz.db "UPDATE DeviceStatus SET HardwareID = (SELECT ID from Hardware WHERE Type = 15 ORDER BY ID DESC LIMIT 1) WHERE HARDWAREID IN (SELECT ID FROM Hardware WHERE Enabled = 0)"
Bochelork
Thanks, that worked! (typo Enabed ->Enabled)
Pantagruel
- Domoticz version: 4.10659
Thanks @waaren, The sqlite3 routine did the trick - Thanks !
As mentioned before, I too created an RFXMeter some years ago according to: viewtopic.php?p=128783#p128783.
The update to 2021.1 resulted in a grayed out UI item.
Again thanks for the fix!
- MadMedic
- Domoticz version: 2020.2
Used this helpfull guide too, with the appropiate idx's, worked like a charm.
was the watermeter sensor here, too. *Coincidence ?
Thnx anyway, guys !
Thnx anyway, guys !
"Life is too short for bad coffee"
- Domoticz version: 2025.1
Not a coincidence, the manual on the website https://ehoco.nl/watermeter-uitlezen-in ... on-script/ and the same forumtopic viewtopic.php?p=128783#p128783 is incorrect, resulting in this issue.MadMedic wrote: Monday 13 September 2021 17:43 Used this helpfull guide too, with the appropiate idx's, worked like a charm.
Thnx anyway, guys !
