- galadril
- Domoticz version: latest
Re: Domoticz app 2.0
If people like, you can always assist with translations!
https://crowdin.com/project/domoticz-for-android
brjhaverkamp
Thanks. Found it. I always pressed the message, which brought me to the Domiticz app itself. The inbox was "hidden" under the small arrow/V.galadril wrote: Thursday 11 March 2021 9:52 You could use the 'Inbox' button on a notification itself.
That should bring you right to your inbox.
But that resulted in a next request(sorry..) Is it possible to have a button directly in the inbox view that you arrive in, to remove all messages and a left/right swipe on individual messages?
Kind regards,
Bert
- galadril
Ill put it on my list:brjhaverkamp wrote: Friday 19 March 2021 7:46 Is it possible to have a button directly in the inbox view that you arrive in, to remove all messages and a left/right swipe on individual messages?
https://github.com/domoticz/domoticz-android/issues/631
brjhaverkamp
Great! Thanks.
- McMelloW
- Domoticz version: V2024.1
I have the paid version of the Domoticz App for Android version 0.2.302 (8479) running on my mobile.
When I try to connect the app via VPN (WireGuard) to my domoticz I cannot conect. I have to use a webbrowser to connect to Domoticz.
How can I connect the Domoticz app via VPN?
Greetings McMelloW
- McMelloW
Nobody is using the app and a VPN connection to reach Domoticz outside your local network?McMelloW wrote: Monday 12 April 2021 11:18 Hi,
Greetings McMelloW
Alain
- Domoticz version: 2022.1
I just tested it and it works for me. I also have the paid version and tested it through Bitdefender VPN on my Android (Galaxy S10+) phone.McMelloW wrote: Friday 16 April 2021 11:34Nobody is using the app and a VPN connection to reach Domoticz outside your local network?McMelloW wrote: Monday 12 April 2021 11:18 Hi,
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
- McMelloW
Did you set any special settings with the app or within Domoticz? My Domoticz is running on a Raspberry Pi 3B+Alain wrote: Sunday 02 May 2021 19:03 I just tested it and it works for me. I also have the paid version and tested it through Bitdefender VPN on my Android (Galaxy S10+) phone.
Greetings McMelloW
Alain
No, nothing special. Just the standard settings. I run Domoticz on a Ubuntu PC. I don't normally use a VPN for it, just tried it because of your question and it worked fine.McMelloW wrote: Tuesday 04 May 2021 20:43Did you set any special settings with the app or within Domoticz? My Domoticz is running on a Raspberry Pi 3B+Alain wrote: Sunday 02 May 2021 19:03 I just tested it and it works for me. I also have the paid version and tested it through Bitdefender VPN on my Android (Galaxy S10+) phone.
hansaplast31
I have a google free AOSP phone. Domoticz Lite works well, how can I get Domoticz Premium? I don't have the Google Play store, at least not the one I can make purchases with.
- jacobsentertainment
- Domoticz version: 2021-1
Suggestion for the app, geofence. I'm living in an border area where the network is not always perfect and sometimes it's between. But at the moment I'm outside my area the app reports I'm leaving and switches of the switch I setup for it but is unable to sync with Domoticz at home due to the network. After a while if I do check the system trough the app I find out that the switch is still on.
Is it possible that the app has an option to check with an variable interval to see if it's outside the geofence and still synchronises the switch?
- jvdz
- Domoticz version: 4.107
@galadril,
There is a new device defined in the current Beta for Roller/Shutter that includes a Stop button: This are the database field details: These are the 2 types added in Domoticz:
Could you have a look at adding support for that as this would be pretty convenient to be able to stop a roller/shutter at any time we like.
Cheers,
Jos
STYPE_BlindsPercentageWithStop, //21
STYPE_BlindsPercentageInvertedWithStop, //22
Cheers,
Jos
gael
I just updated to the beta version in order to get the new EnOcean goodness and it works fine, but the blinds set to "blinds + stop" don't even show up in the (paid) Android app.
It would be great if the new blinds widget would be added (with the percentage and stop button), or at least if it could show up like regular blinds with "open" and "close" buttons.
Cheers,
Gael
Cheers,
Gael
- Xenomes
- Domoticz version: 2025.2
Little request for a newer version the support of html symbols.
As mentioned in this link
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
- galadril
Created an issue on github and added support for the 2 blinds:
https://github.com/domoticz/domoticz-android/issues/647
- galadril
I've fixed this in the next updateXenomes wrote: Saturday 26 February 2022 10:16 Little request for a newer version the support of html symbols.
- galadril
New beta is rolling out with lots of important changes:
And also important:
- Added subscriptions instead of paid app
The premium app still stays to exist, but not receiving any more updates.
You can move to the latest Domoticz via the import/export settings.
- Added support for new blinds
- Support for Android 12
- Added HTTP Symbol support for selector values
- New icons
- Move logs/events/uservariables screen to advanced under settings
- Lots of UX changes
- Improvements for tablet screens
- Added rooms as chips on Dashboard screen
- Refresh translations- Added subscriptions instead of paid app
Hi, where can I submit a bug report?
The latest version seems to have removed the "User Variables" section from the app, which I use daily to set different values and tolerances for electricity prices, target temperatures etc
Hi, where can I submit a bug report?galadril wrote: Monday 20 June 2022 13:59 New beta is rolling out with lots of important changes:
And also important:Code: Select all
- Added support for new blinds - Support for Android 12 - Added HTTP Symbol support for selector values - New icons - Move logs/events/uservariables screen to advanced under settings - Lots of UX changes - Improvements for tablet screens - Added rooms as chips on Dashboard screen - Refresh translations
