He he... my brother's wife at times says if something happens to my husband, I either have to ask you or the neighbour to reboot the househeggink wrote: Tuesday 16 March 2021 10:34So, this is why I am in doubt and why I started this topic in the first place. Basically: will it always be a hassle with systems like Domoticz, Home Assistant etc? Will it always be tinkering? And at the same time: does switching to a system like Atom Homey, Fibaro Homecenter, Samsung Smart Things mean it will automatically work and always work? Or perhaps the issues that I am running into are mostly caused by using either older devices or cheap Chinese devices.
I know my brother was done with Domoticz and switched to Atom Homey and every now and then he asks:"When are you done tinkering with your home automation? When do you take the plunge?"
Agree. I happen to like the messing about with technology but I realise that the current system is fully dependent on me and heaven forbid me and my car have a close encounter with a tree at speed...
I just had another of those very important reasons for starting this topic...heggink wrote: Tuesday 16 March 2021 10:34 On your question, is OZW/ZW-node-js functional/stable enough compared to fibaro/homey/..? That's a good question. Is the hassle worth the flexibility? Comparing to zigbee, for me it is. I can make minor changes that allow me to keep it functional without major hassle.
Are some of the zwave issues solved in zw-node-js? Without the change to >255 devices in the python framework, and without a python plugin, there is time to look at the HA/zw-node-js forums and monitor people's issues reported and see how that's being experienced. I am in no rush but the moment a flexible alternative comes along, I will move.
Again, I noticed that some of the smoke detectors were not reporting temperature at the set interval. Checked the settings and AGAIN all my smoke detectors were reset to the default settings for all parameters. That raises some questions:
- What causes this resetting of parameters?
- Does this also happen if you include these smoke detectors in Fibaro HC or Atom Homey?
- Do other people using Domoticz and Fibaro smoke detectors also have these issues?
- Does this also happen with Fibaro 2nd gen smoke detectors or only with the 1st gen?
- Can I easily restore these parameters rather than setting them node by node?
- Etc....
