Does not display the correct level brightness Zigate + domoticz
pfloryann
Domoticz version: 2025.2
Post by pfloryann »
I noticed that for devices controlled by Zigate, Domoticz it does not retain the last set brightness level. For example i changed from 100% to 50%, Zigate send the command to device and this works but in Domoticz widget is same... domoticz show me 100% and not 50% brightness level.
I tested with Philips Hue lightstrip , Ikea Tradfri Bulb and Ikea Tradfri led power supply - all have the same problem.
I tested Xiaomi Wifi lightstrip and for this all is fine in Domoticz widget.
I using Domoticz 2020.2 (build 13116), Plugin: 4.12.223
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
pipiche
Re: Does not display the correct level brightness Zigate + domoticz
Post by pipiche »
works for me on Domoticz build 13080, will check on 13116 are above ...
pipiche
Post by pipiche »
I do confirm this is happening on 13116 and not 13080 nor 13109
pfloryann
Post by pfloryann »
With 13118 and update plugin works for now
pipiche
Post by pipiche »
You right 13119 works
