Does not display the correct level brightness Zigate + domoticz
pfloryann
Post by pfloryann »
I noticed that for devices controlled by Zigate, Domoticz it does not retain the last set brightness level. For example i changed from 100% to 50%, Zigate send the command to device and this works but in Domoticz widget is same... domoticz show me 100% and not 50% brightness level.
I tested with Philips Hue lightstrip , Ikea Tradfri Bulb and Ikea Tradfri led power supply - all have the same problem.
I tested Xiaomi Wifi lightstrip and for this all is fine in Domoticz widget.
I using Domoticz 2020.2 (build 13116), Plugin: 4.12.223
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pipiche
Re: Does not display the correct level brightness Zigate + domoticz
Post by pipiche »
works for me on Domoticz build 13080, will check on 13116 are above ...
pipiche
Post by pipiche »
I do confirm this is happening on 13116 and not 13080 nor 13109
pfloryann
Post by pfloryann »
With 13118 and update plugin works for now
pipiche
Post by pipiche »
You right 13119 works
